Invert Video
Invert Video
Download: http://archive.info-mac.org/cfg/invert-video.hqx
This very small application is used to invert all of the colors on your
monitor(s).
Although all colors are inverted, the white text on a black background is
much easier for some people to see.
If your graphics card does not save the inverted state between restarts,
you can place this application ( or an alias of it ) in the Startup Items
folder.
This software is E-WARE... E-mail me if you use it.
Enjoy
jeff
