Keys Off 1.2.1
Keys Off 1.2.1
Download: http://archive.info-mac.org/cfg/keys-off-121.hqx
Keys Off makes it easy to prevent anyone from tampering with your
Macintosh. Once you tell Keys Off how you want your Mac protected,
pressing a single Hot Key will activate that protection. Type in the
password you have chosen and the protection is removed. Version 1.2 adds
many new options while providing a new and cleaner user-interface.
Unlike a screen saver with a password, Keys Off allows your Mac to
display data normally while remaining protected. Plus, the protection
offered by Keys Off can be highly customized. You can lock out the
keyboard, menu bar, mouse clicks, power key, command-key shortcuts, or
disk insertions, individually, or in any combination you choose. This
makes it perfect in situations where you want your Mac to run a program
or demonstration, yet you still want to prevent anyone from tampering
with it.
Many users are finding that Keys Off has become an indispensable tool in
their day-to-day tasks: salespeople who want to prevent tampering with
their demonstration Macs, people who want to ensure their Mac is safe
while away from their desk at work, teachers who need a Macintosh to
remain active without students being able to modify it, parents who want
to their Mac child-proofed, and many others.
Keys Off is shareware and is also available from Blue Globe Software's
web site at: .
System 7 is required.
