I have an unsual problem. I have setup my itouch - 2G OS2.1 to sync with our exchange server at work. My email and contacts all sync perfectly, however, my calendar does not sync. I have several friends here who also have iTouchs and iPhone who have it all set up the exact same way and their calendars all sync.
Any ideas? I've gone so far as to wipe my iTouch and start fresh with no luck.
MS Exchange Sync Issue - Calendar only problem
Re: MS Exchange Sync Issue - Calendar only problem
Does your calendar not have events from within the past month? I think by default it only goes a month back.
- 1 MB
Even I was having the same problem. I went to the vendor from I had purchased the Iphone. He sync the calendar of my iphone. So I suggest you that you should go to the vendor
According to this page iPhone OS 3.1 update includes "Improved Exchange calendar syncing and invitation handling" - maybe this will solve your problem?
