Mousigator 0.5.5 -- a cursor focusing tool
Download: http://archive.info-mac.org/cfg/mousigator-055.hqx
Mousigator is a system extension that enables cursor focusing. Cursor
focusing allows you to select a window, focus it, by simply moving the
mouse on top of the window; you don't have to click.
Features:
* Actively see which window is about to be focused
* Focuses nearly all windows, including floating windows
* It's fast
* Smart handling of window focusing via window lingering
* Uses only 40K of system memory
Recent Changes:
* Introduced browsing methods
* Caps Lock now cancels focusing instead of toggling it
* Command now toggles focusing
* Tweaked window focusing a bit
* Turning Mousigator off leaves it off after a restart
* Better error messages and better reporting of them
* Fixed problem with false virus alerts with SAM and MacOS 8.x
System Requirements:
MacOS 7.x or higher
..._Tim Humphrey_...
http://www.shack.org/zzhumphreyt/mousigator
