PowerPCheck 3.2 FAT
PowerPCheck 3.2 FAT
Download: http://archive.info-mac.org/cfg/power-p ... 32-fat.hqx
PowerPCheck 3.2 FAT - PowerPCheck is a cool drag & drop utility that looks for
native PowerPC code inside applications, control panels, extensions and all other
executable files. It can check individual files as well as folders or entire
disks; it inspects both the data fork and the resource fork of each file and
creates a detailed text report of all the native code it finds.
