PrintDesk 1.5.6
PrintDesk 1.5.6
Download: http://archive.info-mac.org/cfg/printdesk-15-lite.hqx
PrintDesk 1.5.6
Printdesk Server - high performance, easy to use, flexible print server
software for the Macintosh and the Power Macintosh. It is the solution of
choice for all organisations, large and small, who would like to provide
their network users with immediate access to all shared printers and
image setters. With Printdesk, users never have to wait for someone
else's job to finish printing before gaining access to a shared printer -
a major boost in productivity.
Installation and configuration of the Printdesk software is simple and
can be accomplished in less than 10 minutes, by anyone familiar with the
MacOS. Printdesk does not require a dedicated workstation. Recommended
System 7.5.3 rev.2 or better. It will run with as little as 8 mb of RAM.
