Low Battery
simey--
4 MB
Low Battery
Post by simey-- »
Is there a trick to switch on iPod when it's on low battery?
Re: Low Battery
You have to plug it in and wait a few seconds for it to charge just a little before it'll turn back on.
simey--
4 MB
Re: Low Battery
Post by simey-- »
If I plug it in, it takes 10 minutes. If I am phoning via Skype, I want to go on immediatly after plugging in!
Re: Low Battery
It shouldn't take literally ten minutes to turn your phone back on after a dead battery. Am I not understanding the situation correctly? You are talking about when your battery becomes so drained your phone switches off and shows the low battery symbol right?
joezmad
Re: Low Battery
Post by joezmad »
My battery runs out in about 1 hour of playing games and using the Internet
