Quit Menu for Finder 7.6 or 7.6.1 This is a ResEdit file. Needs: ResEdit and
Finder 7.6 or 7.6.1 Instuctions included. Adds a Quit Menu in the Finder menu Bar
what lets you quit the active Finder by choosing the Quit Finder in the Drop down
Menu.
