RAM Charger 8.1
RAM Charger 8.1
Download: http://archive.info-mac.org/cfg/ram-cha ... ler-81.hqx
RAM Charger 8 (May 11, 1998 v8.1)
Keywords: OptiMem RAM Charger Doubler Software Memory
Upgrade Utility Control Panel Macintosh Jump Syncronys System
Enhancement Extension More About This Mac
Description:
RAM Charger 8 is a new, major upgrade to OptiMem RAM Charger:
the breakthrough technology that makes a fundamental
improvement in the way Mac applications use memory. It not only
makes a whole lot more of your memory usable, for keeping more
applications and documents open, it also makes your memory more
flexible and reliable. RAM Charger 8 is easier to use, yet offers more
control over how memory is distributed.
A RAM Charged app can open initially into a minimal size block of
memory--then resize automatically--right out to the limits of the
memory in your machine. Cuts down on application-related "Not
Enough Memory" errors and crashes.
If you use virtual memory or RAM Doubler, RAM Charger 8 helps
you get a lot more into your extended memory space, too. Works on
ANY MAC, including Pluses, SEs, Classics, LCs and Power Macs (works
with Modern Memory Manager and System 7.5, too).
This complete copy of RAM Charger operates for two weeks after
installation. Full documentation is included.
Requirement: Any Mac Running System 7 or Mac OS 8
Contact:
Jump Development Group
1228 Malvern Ave
Pittsburgh, PA 15217
Phone: 412-681-2692
Fax: 412-681-2163
e-mail: [email protected]
http://www.jumpdev.com
