RemoteMouse&Keys 1.0.1
Download: http://archive.info-mac.org/cfg/remote- ... ys-101.hqx
This is an update to the freeware utility (Control Panel) RemoteMouse&Keys,
moving the version to 1.0.1. This fixes a shrunken window effect in MacOS
8.
RemoteMouse&Keys allows one to use two Macintoshs from one keyboard and
mouse. For example, one an have a laptop and a desktop machine connected by
an appletalk cable, and control one from the other.
