setfolders
setfolders
Download: http://archive.info-mac.org/cfg/set-folders.hqx
Title: SetFolder
Version: 1.0
Platform: Macintosh
OS: 7.0
Category: DeskTop Utility
Licence: Shareware
Author: Lorenzo Puleo
URL: http://space.tin.it/arte/lpuleo/
Download at: http://www.geocities.com/Paris/3902/dow ... olders.sit
Description:
Before preparing a CD masterization, it's needed to control the current
settings for all the Folders you will copy: position, order view,
size... This shareware, in only one step, read the settings from the
main folder you choose, and set as well all the subfolders (and
subfolders, and sub...)
