Tekalike, a Tektronix terminal emulator
Path: utzoo!watmath!clyde!bonnie!akgua!whuxlm!harpo!decvax!tektronix!uw-beaver!info-mac
Subject: Tekalike, a Tektronix terminal emulator
Date: Fri, 16-Nov-84 21:15:50 EST
Article-I.D.: uw-beave.2264
Posted: Fri Nov 16 21:15:50 1984
Date-Received: Sun, 18-Nov-84 04:48:38 EST
Sender: yenbut@uw-beave
Lines: 58
I have been evaluating a Tektronix emulator named 'Tekalike' for a few weeks
now. As a terminal emulator, it has a few problems. Its default fonts are
ALL proportional-spaced. Consequently, systems assuming fixed width fonts
(most do obviously) produce table-like displays that don't quite line up on
Tekalike. There is no font menu item to change it's default fonts within the
context of the program. I have not tried doing resource-mover things to it
yet. It also does not seem to be able to force a ^S typed from the keyboard
down the line while the screen is being filled with text. It does support
XON/XOFF, however. It cannot be used to save a session like MacTerminal; no
vertical scroll bar is provided.
After all of these negative things, let's now turn to the 'good' stuff. It is
a nice Tektronix graphics terminal. Supports up to 4014 and 4016 graphics
terminals, including color. As to output devices, it supports Imagewriter
AND Apple, Houston Instruments, and HP PLOTTERS!!! (this includes color
ones). I have NOT connected a plotter to try out that section of the program
personally, however. Color is drawn in patterns on the Mac screen, but is
proported to appear correctly on the plotters. Features not supported (it
says this in the documentation) are line styles (dotted, dot-dash, etc.),
incremental plot mode, special point plot mode, and hard copy requests from
the host. I have had NO problems using UNIX's tek driver; I don't really
know what the middle-two omissions are all about.
One can 'record' a graphics session into a file. This file contains the
actual graphics codes sent from the host. One can reopen old recordings to
play them back. The neat stuff is that one can ZOOM-in on a recording AT
FULL TEKTRONIX RESOLUTION. As 4014 is 3180X4096, one does not encounter Mac
quantization when ones zooms. To accomplish the zoom, one gets a 'pointing
hand' cursor, draws an arbitrarily shaped rectangle ala MacPaint, an the
program redraws the recording so that the portion selected fills the screen.
One can zoom again, and again, and again... There are three output screen
sizes that one can select: Full screen (excluding menu bar), Tekalike
screen, and MacPaint screen. The second size preserves the aspect ratio of
the plot while the first does not; essentially, these two are the
full-screen options. The latter scales the plot down so that it will fit in
the MacPaint editing window so that Cut/Paste of a whole plot can be made.
Tekalike will save whatever plot one has on the screen as a MacPaint
document. The saving and screen size are all available at any level of zoom.
These zoom, screen size, and save features allow one to get Tektronix plots
into the MacPaint world so that further editing can be made to 'jazz' them
up.
The documentation is good. The remaining problem is the price: $250. The
company producing the program is :
Mesa Graphics
P.O. Box 506
Los Alamos, NM 87544
As a concluding statement, I am going to buy it for the graphics terminal
aspect, but I will have to also purchase MacTerminal for a good terminal
emulator.
Don Johnson
Electrical Engineering Dept.
Rice University
