Speek key vs mice
Speek key vs mice
Subject: Speek key vs mice
Date: Tue, 27-Nov-84 05:54:55 EST
Article-I.D.: uw-beave.2340
Posted: Tue Nov 27 05:54:55 1984
Date-Received: Wed, 28-Nov-84 04:15:16 EST
Sender: root@uw-beave
Lines: 40
I think what you see here is a hardware vs software discrepency. There
is no reason why koala couldn't come up with a touchpad for the mac that
would function exactly like the mouse for any application which doesn't try
to read the mouse directly from the hardware ports.
(I know of none as yet) The only thing that they would have to do on
the outside is to remove one of the buttons. (There really isn't any way
to provide a 2 button mouse for the mac.)
Trackballs, bit (stylus) pads, joysicks, touchpads, etc. are all acceptable
substitutes for mice and there is no reason why such devices will not come on
the market as mouse substitutes for the mac.
The main difference, however, is not the hardware, but the software.
In a good Mac program, the mouse is central, and there is no escaping it.
The speed-key software tries to "fool" the application program that it
is using the keyboard, and not the mouse. Unfortunately, most non-mouse
driven programs are modal which keeps all functions from being available
to the user at any one time. While many Mac programs cannot be said to
be modeless, mostly due to memory constraints, you certainly don't see
the plewthora of modes as on, lets say, symphony, degrading the mouse
to not being much better than the keyboard.
Even the simplest mouse movements, however, can be useful, for example,
for positioning the cursor in a screen editor or spreadsheet. The methods
of dragging and autoscrolling to make selections, however, don't make
it to many noin-mouse oriented products with a "fake mouse." and you
eventually have to go back to the keyboard for evewrything but the most
mundane functions.
The Macintosh will always remain head and sholders above the IBM PC
when it comes to user-interface issues, while the IBM will probably
always have a broader variety of business software to fill every
possible niche.
Just because an IBM has a mouse doesn't make it a Macintosh unless the
particular package was designed with the mouse in mind from the start
(i.e. mouse required to run) and even then, the programmer probably
chose his own set of user interface standards which might be consistent
within his own program but which are not seen anywhere outside.
