new SUMacC release
new SUMacC release
Subject: new SUMacC release
Date: Tue, 20-Nov-84 00:40:34 EST
Article-I.D.: uw-beave.2294
Posted: Tue Nov 20 00:40:34 1984
Date-Received: Wed, 28-Nov-84 03:24:37 EST
Sender: yenbut@uw-beave
Lines: 156
SUMacC ORDERING INFORMATION (Version 2.0, 11/84)
WHAT YOU GET
SUMacC is the Stanford / UNIX Macintosh C development environment, a
collection of programs that allows you to "cross-develop" Macintosh
applications on your UNIX system and then download them to the Mac for
execution. Some advantages of this approach: (1) The per-programmer
cost for using SUMacC is almost zero; other systems require per
person, a Lisa ($4000), or a Mac stand-alone C compiler plus 2nd disk
drive ($500 + $300). (2) You program in a full Bell Labs PCC C
compiler with all the UNIX support tools: emacs, make, cshell, lint,
lex, yacc, grep, diff, lpr, etc. (3) The large disks and memory on
your UNIX system result in faster editing and compilation. (4) When
applebus / ethernet connections become available, executing a file
directly from your UNIX 'file server' should take no longer than
loading it off a SONY disk.
Included with the package are Macintosh library / header / lint files,
UNIX commands (such as rmaker, macget/put, mac-to-laserprinter),
example / test programs, workshop header files (for reference), manual
pages, and documentation. Source is included for all of the above.
Since the compiler / loader is derived from the Bell Labs PCC, only
binaries are provided for these.
Example / test programs in C include: macscrawl (sketcher),
grow (from the workshop), insane (float test), alert (tests alert-dialogs),
calendar (desk accessory), ramdisk, hangman, kermit, mini-finder,
printspooler (desk accessory).
WHAT YOU NEED
Your UNIX should be a VAX running 4.1 or 4.2 BSD, or Eunice (UNIX under VMS).
SUMacC has also been "ported" (by others) to a number of different UNIX
systems (Pyramid, SUN, Metheus, System V, etc.) While we do not provide
compiler binaries for systems other than the VAX, a list of sites (including
those with ports) and porting hints are included. [See sumacc.sites
on host SUMEX].
You also need a Mac disk containing MacTerminal (.15 or later; 1.1 seems
to be the latest). Your RS232 serial connection between the Mac and UNIX
should be 9600 baud with a full 8 bit transparent data path. I.e. terminal
switchers or "network" connections may interfere with the "modem7" protocol
used in downloading. Lower baud rates will work, but are not recommended.
Buy Inside Mac ($100) plus updates and supplement ($100) from Apple.
Handy but not required: occasional access to a Lisa, since Apple currently
only releases new code in Pascal; for example you may want to translate a new
header or interface file into C on your own if you need it desparately.
WHAT'S NEW
SUMacC was originally released in June 84. This release incorporates
all bug fixes since then, new contributed programs, header / interface
file changes including Apple's revised name upper/lower case
conventions, new workshop reference files, vms eunice binaries, and an
increased C compiler symbol table size.
CAVEAT EMPTOR
The package is under a Stanford copyright which must be retained on all
copies of this software. Any fixes or enhancements made to the package
should be reported back to us, for incorporation into future releases.
While we will attempt to fix bugs and provide new features, no warrantee
is expressed or implied. You are basically on your own.
SUMacC currently does not support segmentation, so on a 'thin' Mac you
are limited to about 80K bytes of program. There are no restrictions
on the size of SUMacC programs, other than the available physical
memory. (The Apple Workshop pascal compiler generates PC-relative
code, so its segments are limited to 32K bytes each. SUMacC
dynamically relocates the program at run-time, by following relocation
chains run-length encoded though the "unused" high order byte of long
word addresses.)
Some esoteric features of the official Apple Mac Workshop environment
(a moving target) have not yet been tested (or converted): Graf3D,
rare rmaker types, new imagewriter / laser printer support, Applebus, etc.
C library and header files will always be somewhat behind in tracking
the Pascal versions since Apple only releases code in Pascal.
ACKNOWLEDGEMENTS
The 68000 C compiler used by SUMacC is the Bell Labs (Johnson) portable
C compiler, ported by Chris Terman of MIT and used in the MIT NU
project and the Stanford SUN system. The assembler is by Mike Patrick,
also of MIT. This same compiler / assembler / loader is used in many
of the 68K UNIX boxes currently on the market. Many modifications and
bug fixes have been applied by folks at Stanford, MIT, and Lucasfilm:
Jeff Mogul, Bill Nowicki, John Seamons, Vaughan Pratt, Eric Ostrom, and
a cast of thousands.
Dave Johnson of Brown Univ. contributed the excellent macget/macput
programs that make downloading painless. Among the many people
contributing improvements, new example programs, and bug fixes are:
Mike Schuster of CALTECH, Dan Winkler and Steve Engle of Harvard, Bill
Schilit at Columbia, Joe Pallas and Steve Gross at Stanford, John
Seamons at Lucasfilm, John Peterson at Utah, Ben Hyde of Intermetrics,
Bruce Horn of Apple/Adobe, Van Jacobson at LBL, and many others. Thank
you all!
TO ORDER A MAGNETIC TAPE
The tape duplication company below will send a 1600 bpi, UNIX tar tape
(1200 feet) for $65. This includes the reel of tape and surface
(book rate) postage. They will accept checks or PO's (payable to Data
Processing Services).
Maria Code
Data Processing Services
SUMacC distribution tape
1371 Sydney Drive
Sunnyvale, CA 94087
(408) 735 8006
You may wish to include more money for postage to get faster delivery:
Additional postage rates.
US only.
$2.50 airmail
outside US.
$2.50 surface (2 months to Europe!)
$4.00 airmail North America (Canada/Mexico)
$7.00 airmail Europe
$10.00 airmail elsewhere (Africa, Asia, etc.)
FTP INSTRUCTIONS
For those with ARPANET access, the package is also available as a tar
file located on sumacc.tar. Since the tar file has become so
large, it is in two pieces. sumacc.tar contains the main package, and
ws.tar contains the workshop reference files. It is stored both on
SUMEX-AIM (California) and COLUMBIA-20 (New York), so you should pick
the host closest to you. It would be appreciated if you performed the
file transfer during off hours as it takes about a half-hour under best
conditions. At two in the afternoon it would take much more time than
this and be an annoying additional load on our systems. If more than
one group in your area wants a copy, please try to coordinate things so
you only get it from us once.
The hosts mentioned above are not UNIX hosts, so you must be extra
careful in performing the file transfer to ensure you get all eight
bits. On your side you must set the transfer mode to 'TENEX' or 'TYPE
L 8' (ask your FTP guru if unsure). We picked these distribution hosts
because they happen to have direct Arpanet connections (as opposed to
routing through gateways).
If you take a copy, please send me (croft@sumex) a note so I can
maintain a list of users.
