MACTERMINAL: ANSWERBACK AND REMOTE SETTING
Path: utzoo!watmath!clyde!burl!ulysses!cbosgd!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: MACTERMINAL: ANSWERBACK AND REMOTE SETTING
Date: Thu, 8-Nov-84 03:46:02 EST
Article-I.D.: uw-beave.2152
Posted: Thu Nov 8 03:46:02 1984
Date-Received: Fri, 9-Nov-84 07:48:10 EST
Sender: yenbut@uw-beave
Lines: 21
When I send the usual login terminal identification query (^[[c) from our
Unix system to MacTerminal 1.1, (in vt100 mode) the response always seems
to be ^[[E;V , regardless of MacTerm's answerback message setting. This is
OK, as the response suffices to distinguish MacTerm from other terminals
around here; however, I am mystified. How does MacTerm's answerback
feature work; ie, what is the query that elicits the "answerback message"
response? Why do I get ^[[E;V ? This doesn't look like a standard VT100
response. Is this documented anywhere?
On a related topic, is it possible to set MacTerm's parameters--
specifically, bits/char and parity--remotely? If so, how? For example, 7
bits/char is the required setting to get the attention of our ALS, but--
once logged on--8 bits/char seems to work best with macput/get in Unix. It
ought to be possible to set some things remotely via a login script. It is
a nuisance to have to manually reset parameters every time you log on.
Any help, advice, or pointers to same will be gratefully received.
--John Clark
clark@rand-unix
