SPY 2.52US (US version)
Download: http://archive.info-mac.org/cfg/spy-252-us.hqx
SPY 2.52US ©1996-97 Pascal CARDON
What is Spy ?
+ Spy shows a list of all the processes which are actives, even the
background processes.
+ Spy gives you some details like launch time, used CPU time, memory heaps
display.
+ Spy allows you to bring one of the processes to the front by 'double
clicking' its name.
+ Spy allows you to kill a process by 'option double clicking' its name.
+ Spy remembers its window's position.
+ You may resize the window to see just the part you want.
+ Spy is very useful if you want to manage your memory usage by avoiding to
keep lot of programs actives, or by adjusting their memory size.
What's new ?
V 2.52 (September 04, 97)
+ Now Spy is a FAT application
+ New multitask scheme : previous releases prevented the computer to come
in sleep mode (only for PowerBook and some recent Macintosh)
+ Removed a cosmetic bug about the display of the selection
SHAREWARE
+ Spy is a 10$ US Shareware (or 50FF or any other currency).
+ You should send me directly the shareware fee at
Pascal CARDON
17, cours du Buisson
77186 NOISIEL
FRANCE
or use the enclosed KAGI SHAREWARE Register program to pay me with cash,
check, Visa card Š
