Re: hooking up Mac with a modem
Posting-Version: version B 2.10 beta 3/9/83; site cosivax.UUCP
Path: utzoo!watmath!clyde!burl!ulysses!gamma!mb2c!uofm-cv!cosivax!dbo
Subject: Re: hooking up Mac with a modem
Date: Thu, 19-Jul-84 19:11:51 EDT
Article-I.D.: cosivax.159
Posted: Thu Jul 19 19:11:51 1984
Date-Received: Fri, 20-Jul-84 07:27:09 EDT
References:
Organization: COSI, Ann Arbor, MI
Lines: 20
Hooking a Mac up with a modem is actually very simple. The db9
connectors are readily available and if you have any skill with
a soldering iron a db9 db25 adapter will take about 15 minutes
to put together. The connector just uses a reduced number of the
rs232 signals, not a completely different interface.
One of the early issues of ST.Mac had a diagram
showing which pins on the mac side went to which pins on the modem
side. Using this diagram I made a cable by substituting the appropriate
db25 pins for the corresponding db9 signals (on the modem side).
If anyone is interested I can post the specifics.
The Apple modem is (as I understand from rumors) a Hayes compatible,
so all it does to dial is transmit the appropriate Hayes command to
dial. I have a U.S. Robotics modem that works fine with the pre-release
MacTerminal.
-Doug
sb1!mb2c!uofm-cv!cosivax!dbo
