macget.c, version for Beta MacTerm
Subject: macget.c, version for Beta MacTerm
Date: Thu, 2-Aug-84 20:46:36 EDT
Article-I.D.: uw-beaver>.1386
Posted: Thu Aug 2 20:46:36 1984
Date-Received: Sat, 4-Aug-84 02:16:01 EDT
Lines: 476
See cover letter for macput.c.
Note:
for systems other than 4.2 and apollo aux with no "rename"
system call, compile with the option -DNO_RENAME
Dave Johnson
ddj%[email protected]
cut here
#include
#include
#include
#include
#ifdef NO_RENAME
#define rename(old, new) link(old, new); unlink(old)
#endif
/* Mac time of 00:00:00 GMT, Jan 1, 1970 */
#define TIMEDIFF 0x7c25b080
#define RECORDBYTES 132
#define DATABYTES 128
#define NAMEBYTES 63
#define RETRIES 10
#define SOHTIMO 10
#define LINTIMO 20
#define CHRTIMO 1
#define MAXRECNO 0xff
#define BYTEMASK 0xff
#define TMO -1
#define DUP '\000'
#define SOH '\001'
#define EOT '\004'
#define ACK '\006'
#define NAK '\025'
#define CAN '\030'
#define EEF '\032'
#define ESC '\033'
#define H_NLENOFF 1
#define H_NAMEOFF 2
/* 65 80 is the FInfo structure */
#define H_TYPEOFF 65
#define H_AUTHOFF 69
#define H_LOCKOFF 81
#define H_DLENOFF 83
#define H_RLENOFF 87
#define H_CTIMOFF 91
#define H_MTIMOFF 95
#define H_OLD_DLENOFF 81
#define H_OLD_RLENOFF 85
#define TEXT 0
#define DATA 1
#define RSRC 2
#define FULL 3
int mode, txtmode;
int pre_beta; /* -o flag; for compatibility with MacTerminal Version -0.15X */
struct macheader {
char m_name[NAMEBYTES+1];
char m_type[4];
char m_author[4];
long m_datalen;
long m_rsrclen;
long m_createtime;
long m_modifytime;
} mh;
struct filenames {
char f_info[256];
char f_data[256];
char f_rsrc[256];
} files;
char tmpname[16];
int lastack;
char buf[DATABYTES];
* macget -- receive file from macintosh using xmodem protocol
* Dave Johnson, Brown University Computer Science
* (c) 1984 Brown University
* may be used but not sold without permission
* created ddj 5/22/84
* revised ddj 6/29/84 -- added [-rdu] options
* revised ddj 7/16/84 -- protocol changes for MacTerminal Beta Version 0.5X
* revised ddj 7/31/84 -- pre-4.2 signal bugs fixed in timedout()
char usage[] = "usage: \"macget [-o] [-rdu] [filename]\"\n";
main(ac, av)
char **av;
char *name;
mode = FULL;
name = "";
ac--; av++;
while (ac) {
if (av[0][0] == '-') {
switch (av[0][1]) {
case 'r':
mode = RSRC;
break;
case 'd':
mode = DATA;
break;
case 'u':
mode = TEXT;
break;
case 'o':
pre_beta++;
break;
default:
fprintf(stderr, usage);
exit(1);
else {
name = av[0];
ac--; av++;
setup_tty();
if (send_sync() == ACK) {
txtmode = 0;
recv_hdr(name);
if (mode == TEXT) txtmode++;
recv_file(files.f_data, mh.m_datalen, 1);
txtmode = 0;
recv_file(files.f_rsrc, mh.m_rsrclen, 0);
reset_tty();
recv_hdr(name)
char *name;
long get4();
int n;
FILE *fp;
char *np;
strcpy(tmpname, "#machdrXXXXXX");
mktemp(tmpname);
recv_file(tmpname, (long)DATABYTES, 1);
fp = fopen(tmpname, "r");
if (fp == NULL) {
perror("temp file");
cleanup(-1);
fread(buf, 1, DATABYTES, fp);
fclose(fp);
if (name && *name) {
n = strlen(name);
if (n > NAMEBYTES) n = NAMEBYTES;
strncpy(mh.m_name, name, n);
mh.m_name[n] = '\0';
else {
n = buf[H_NLENOFF] & BYTEMASK;
strncpy(mh.m_name, buf + H_NAMEOFF, n);
for (np = mh.m_name; *np; np++)
if (*np == ' ') *np = '_';
if (mode == FULL) {
sprintf(files.f_info, "%s.info", mh.m_name);
rename(tmpname, files.f_info);
tmpname[0] = '\0';
sprintf(files.f_data, "%s.data", mh.m_name);
sprintf(files.f_rsrc, "%s.rsrc", mh.m_name);
else {
unlink(tmpname);
tmpname[0] = '\0';
switch (mode) {
case RSRC:
sprintf(files.f_data, "/dev/null");
break;
case DATA:
sprintf(files.f_rsrc, "/dev/null");
break;
case TEXT:
sprintf(files.f_data, "%s.text", mh.m_name);
break;
strncpy(mh.m_type, buf + H_TYPEOFF, 4);
strncpy(mh.m_author, buf + H_AUTHOFF, 4);
if (pre_beta) {
mh.m_datalen = get4(buf + H_OLD_DLENOFF);
mh.m_rsrclen = get4(buf + H_OLD_RLENOFF);
else {
mh.m_datalen = get4(buf + H_DLENOFF);
mh.m_rsrclen = get4(buf + H_RLENOFF);
mh.m_createtime = get4(buf + H_CTIMOFF);
mh.m_modifytime = get4(buf + H_MTIMOFF);
recv_file(fname, bytes, more)
char *fname;
long bytes;
int more;
register int status, n;
FILE *outf;
int naks = 0;
lastack = 0;
outf = fopen(fname, "w");
if (outf == NULL) {
perror(fname);
cleanup(-1);
for (;;) {
status = rec_read(buf, DATABYTES);
switch (status) {
case EOT:
if (!pre_beta)
tputc(ACK);
if (more)
tputc(NAK);
fclose(outf);
return;
case ACK:
tputc(ACK);
naks = 0;
n = (bytes > DATABYTES) ? DATABYTES : bytes;
bytes -= n;
fwrite(buf, n, 1, outf);
break;
case DUP:
tputc(ACK);
naks = 0;
break;
case NAK:
purge(CHRTIMO);
if (naks++ < RETRIES) {
tputc(NAK);
break;
/* fall through */
case CAN:
tputc(CAN);
fclose(outf);
/* unlink fname? */
cleanup(-1);
/* NOTREACHED */
send_sync()
int c;
for (;;) {
c = tgetc(60);
switch (c) {
case ESC:
break;
case CAN:
case EOT:
case TMO:
return c;
default:
continue;
c = tgetc(1);
if (c != 'a')
continue;
tputc(ACK);
return ACK;
rec_read(buf, recsize)
char buf[];
int recsize;
int c, rec, rec_bar, cksum;
c = tgetc(SOHTIMO);
switch (c) {
case TMO:
default:
return NAK;
case EOT:
return EOT;
case CAN:
return CAN;
case SOH:
/* read header */
rec = tgetc(CHRTIMO);
if (rec == TMO)
return NAK;
rec_bar = tgetc(CHRTIMO);
if (rec_bar == TMO)
return NAK;
/* check header */
if (rec != MAXRECNO - rec_bar) return NAK;
/* fill buffer */
cksum = tgetrec(buf, recsize, LINTIMO);
if (cksum == TMO)
return NAK;
/* get checksum */
c = tgetc(CHRTIMO);
if (c == TMO)
return NAK;
if (c != (cksum & BYTEMASK))
return NAK;
/* check record number */
if (rec == lastack)
return DUP;
if (rec != ((lastack + 1) & MAXRECNO))
return CAN;
else {
lastack = rec;
return ACK;
/* NOTREACHED */
purge(timeout)
int timeout;
int c;
do {
c = tgetc(timeout);
} while (c != TMO);
static int ttyfd;
static FILE *ttyf;
jmp_buf timobuf;
tgetrec(buf, count, timeout)
char *buf;
int count, timeout;
char *bp;
int i, cksum;
if (setjmp(timobuf))
return TMO;
alarm(timeout);
i = fread(buf, 1, count, ttyf);
alarm(0);
if (i != count)
return TMO;
cksum = 0;
bp = buf;
for (i = 0; i < count; bp++, i++) {
cksum += *bp;
if (txtmode && *bp == '\r')
*bp = '\n';
return cksum;
tgetc(timeout)
int timeout;
int c;
return TMO;
alarm(timeout);
c = getc(ttyf);
alarm(0);
if (c == -1) /* probably hung up or logged off */
return EOT;
else
return c & BYTEMASK;
tputc(c)
char c;
write(ttyfd, &c, 1);
timedout()
signal(SIGALRM, timedout); /* for pre-4.2 systems */
longjmp(timobuf, 1);
static struct sgttyb otty, ntty;
/* should turn messages off */
setup_tty()
int cleanup();
int timedout();
ttyf = stdin;
ttyfd = fileno(stdin);
ioctl(ttyfd, TIOCGETP, &otty);
signal(SIGHUP, cleanup);
signal(SIGINT, cleanup);
signal(SIGQUIT, cleanup);
signal(SIGTERM, cleanup);
ntty = otty;
ntty.sg_flags = RAW|ANYP;
ioctl(ttyfd, TIOCSETP, &ntty);
reset_tty()
sleep(2); /* should wait for output to drain */
ioctl(ttyfd, TIOCSETP, &otty);
cleanup(sig)
int sig;
if (tmpname[0] != '\0')
unlink(tmpname);
reset_tty();
exit(sig);
long
get4(bp)
char *bp;
register int i;
long value = 0;
for (i = 0; i < 4; i++) {
value <<= 8;
value |= (*bp & BYTEMASK);
bp++;
return value;
