Re: How to manage disks
Path: utzoo!watmath!clyde!burl!ulysses!mhuxl!ihnp4!zehntel!tektronix!uw-beaver!info-mac
Subject: Re: How to manage disks
Date: Sat, 28-Jul-84 17:53:25 EDT
Article-I.D.: uw-beave.1345
Posted: Sat Jul 28 17:53:25 1984
Date-Received: Mon, 30-Jul-84 00:46:23 EDT
Lines: 18
In order to support multiple output devices, the Macintosh prints
documents by first making a print file (in a standard format) and then
invoking a driver program wich is named in the boot sector (Imagewriter in
most cases, this can be changed by the Boot Configure utility) Therefore,
it is necessary for there to be available space on the system disk (I would
guess 50-80K would be a good number). The way to handle this situation is
to let the system disk be just that, the system disk. Pile on all the fonts
you would ever use, enjoy a huge (and consistent) scrapbook, and have all
the desk accessories you would ever need. Even with all the fonts available
now, I doubt that you would use more than 300K. Put MacWrite and MacPaint
on the same disk as your documents, you should still have >250K available,
quite enough for any application. I think that when the demand dies down
(and Sony can produce enough double-sided drives) some of the problems will
be solved (800K should be enough for lots of fonts, drivers, and
accessories).
_emt
