full scale macpaint printing on Imagen
Subject: full scale macpaint printing on Imagen
Date: Thu, 9-Aug-84 00:17:53 EDT
Article-I.D.: uw-beaver>.1393
Posted: Thu Aug 9 00:17:53 1984
Date-Received: Sat, 4-Aug-84 02:18:21 EDT
Lines: 31
A new C program to print MacPaint documents on Imagen printers has
been made available on SUMEX for FTP. The source is stored in
[sumex]paintimp.c (approx 6.5 Kbytes)
Paintimp is usable with each of the 240, 300, and 480 dot/inch
Imagens, and also features side-by-side printing of two pictures
per page, at 66% reduction (50% for the 300 dpi model).
The "-2" option request 2-up printing, and you can specify resolutions
other than 240 by using either "-r 300" or "-r 480". Use macget -d to
receive the paint document you wish printed.
Currently, paintimp relies on your spooler to prepend an impress
document header on the file; for example,
paintimp filename.data | lpr -Pimagen -v (for 4.2 spooler)
or
paintimp file.data | ipr (for imagen 4.1 spooler)
may work, or you can add a line to the beginning of the routine
write_imphdr() to write out a line like "@document(language impress)"
to stdout, if your spooler doesn't handle that for you.
Send me any bugfixes/improvements, thanks. After I'm pretty sure
the code is in good order, I'll post it to net.sources for the uucp
world.
Dave Johnson
ddj%[email protected]
{ihnp4,decvax}!brunix!ddj (uucp)
