[Charlie C. Kim : Macpaint => LaserJet]
Subject: [Charlie C. Kim : Macpaint => LaserJet]
Date: Fri, 18-Jan-85 05:57:01 EST
Article-I.D.: uw-beave.461
Posted: Fri Jan 18 05:57:01 1985
Date-Received: Sat, 19-Jan-85 01:03:45 EST
Lines: 299
10-Jan-85 04:21:59-PST,8883;000000000001
Return-Path:
Received: from columbia.arpa by SUMEX-AIM.ARPA with TCP; Thu 10 Jan 85 04:21:36-PST
Received: from CU20B.ARPA by columbia.arpa; Thu, 10 Jan 85 07:23:09 est
Date: Thu 10 Jan 85 07:21:49-EST
Subject: Macpaint => LaserJet
To: [email protected]
Following the dotted line below is a version of Ed Patterman's
MACIMP program modified for the HP LaserJet. There are many
enhancements which could be made (and some are listed in the
program), but briefly, you can print at any of the four
resolutions graphics resolutions (75, 100, 150, and 300 dots per
inch). In addition, you can dump the Macpaint file directly to
LaserJet if it is hooked up via a RS232 line. The output from
the LaserJet, which uses the Canon LBP-CX engine, looks very
crisp.
The code, as written, is restricted to Decsystem-20's. For
anyone who is thinking of converting the C version of MACIMP for
the LaserJet, be warned that the LaserJet requires an eight bit
data path with XON-XOFF. See the list Laser Lovers for more info
on hooking a LaserJet to a Unix machine. No further support of
this program by this author is anticipated: we only have the
LaserJet on demo and it's leaving tomorrow.
Charlie C. Kim
Columbia University
Center for Computing Activies
User Services
[To the Editor: an FTPable executable is in CU20B::PS:MACHP.EXE]
PROGRAM Machp ;
(* This program converts a Macintosh bitmap file into a form ready
to print on a HP LaserJet. It is a derivative of MACimp.
As MACimp, MacHp has been proven to work with:
o MACPAINT files
o Screen dumps (created with COMMAND-SHIFT-3)
It will not work with MACwrite files.
Macimp was
Written by Ed Pattermann (PATTERMANN@SUMEX), SUMEX Computer Project
Copyright 1984 @ Stanford University
Macimp was
Rewritten for the HP LaserJet (mostly a matter of stripping)
by Charlie C. Kim, Columbia University, January, 1985.
Much of the following comes directly from the original with obvious changes:
MAChp converts a Macintosh bitmap file into a HP LaserJet
file. It is also capable of driving the LaserJet directly
(just specify the terminal number). The crux of this
program is understanding the format of the Macintosh
bitmap file.
First, the Macintosh file ; This format is the common
interchange format for full-page bitmap images on the Macintosh.
The first 512 bytes of the file are the header. The first four bytes
comprise the version number, followed by 38*8 = 304 bytes of
patterns. The remaining 204 bytes of the header are reserved for
future expansion. If the version number is zero, the patterns are
ignored. Hence, programs that wish to create files to be read into
MACpaint can just write out 512 bytes of zero as the header.
Following the header are 720 compressed scanlines of data which form
the 576 wide by 720 tall bitmap. The bitmap is compressed as follows ;
Any run of three or more equal bytes is compressed into a count byte
and a single data byte. Runs of unequal bytes are passed on literally,
preceded also by a count byte. i.e.
count = -1..-127 --> replicate byte 2..128 times
count = 0.. 127 --> copy 1..128 bytes uncompressed
count = -128 ignored for backward compatibility
The format used by the HP LaserJet for graphics is simple. You must
setup graphics with the following commands:
* t # R
* r # A
where # is replaced by some number. The first command
sets the resolution of the machine in dots per inch. The
only legal values are 75, 100, 150, and 300. The second
command defines the offset from the right margin.
Each scan line must be prefixed by the following graphics transfer
command:
* b # W
where the # specifies the number of following bytes. The
interpretation of the bytes is: bit on - print black, bit
off - do nothing. The bits are order high order to low
order and all 8 bits of a byte are used.
Graphics mode is terminated by the command:
* r B
and from this point on text may be printed.
Reset commands ( E) are used to ensure that the
previous page is cleared out and the current page is
printed respectively. (Note, the preceeding reset command
has no effect during a graphics transfer command.)
Things for someone to do:
1) Indent margins differently for different resolutions
2) Provide support for Landscape mode
3) Fix things so you can output to a file without resets: thus
allowing someone to include a picture in a document.
The reason the resets are retained is to allow direct
spooling to the HP LaserJet.
include 'pas:pascmd.pas';
include 'pas:csl.pas';
include 'pas:extern.pas';
Const
esc = 27;
VAR
(* VARIABLES *)
i,j,k,l : integer ;
bytes : integer ;
opcode : integer ;
dpi : Integer;
databyte : char;
(* COMMAND TABLE FOR PARSING MAGNIFICATION FACTORS *)
magtbl : table ;
(* FOR PARSING TOPS20 FILES *)
macjfn : integer ;
outjfn : integer ;
impjfn : integer ;
inlength : integer ;
infilename : PACKED ARRAY [1..80] OF char ;
outfilename : PACKED ARRAY [1..80] OF char ;
macfile : FILE OF char ;
impfile : FILE OF char ;
BEGIN
magtbl := tbmak(4) ;
tbadd(magtbl,1,'100 ',0);
tbadd(magtbl,2,'150 ',0);
tbadd(magtbl,3,'300 ',0);
tbadd(magtbl,0,'75 ',0);
Writeln(tty,'MAChp - A Macintosh bitmap file to LaserJet conversion program') ;
cmini('Macintosh filename to be converted > ');
cmhlp('Name of Macintosh file ') ;
cmifi(macfile) ; inlength := cmatom(infilename) ; cmcfm ;
cmini('Output file name > ') ;
cmhlp('Enter local file name') ;
gjgen(400000000000B) ; gjext('hp') ;
cmdef('hp:'); { logical name pointing to printer }
{ port }
cmfil(impfile) ; i := cmatom(outfilename) ; cmcfm ;
cmini('Enter magnification desired [75,100,150,300; best = 75] > ') ;
cmdef('75') ; { if its the best... }
j := cmkey(magtbl) ;
cmcfm;
(* ADJUST TOP AND LEFT MARGINS DEPENDING on resolution *)
(* should be done! *)
CASE j OF
0: dpi := 75;
1: dpi := 100;
2: dpi := 150;
3: dpi := 300;
END ;
(* INITIALIZE INPUT FILE *)
Reset(macfile,infilename,'/B:08') ;
macjfn := curjfn(macfile) ;
macjfn := rh(macjfn) ;
(* INITIALIZE OUTPUT FILE *)
Rewrite(impfile,outfilename,'/B:08') ;
impjfn := curjfn(impfile) ;
impjfn := rh(impjfn) ;
(* WRITE OUR DOCUMENT HEADER AND INITIAL IMPRESS COMMANDS *)
{ Reset printer, set printer resolution, set left margin }
Write(impfile,chr(esc),'E',chr(esc),'*t',dpi:0,'R',chr(esc),'*r0A');
(* READ IN HEADER *)
{ This allows `piped' output, so it gets left alone instead of being }
{ changed to a sfptr... }
FOR i := 1 TO 512 DO jsys(bin,1; macjfn ; j,databyte) ;
(* READ IN DATA BYTES *)
Writeln(tty,'Processing ',infilename:inlength,' ') ;
FOR i := 1 TO 720 DO
BEGIN
if i mod 20 = 0 then write(tty,'.'); { let's see what's going on }
write(impfile,chr(esc),'*b72W');
WHILE bytes 127 THEN
BEGIN
opcode := 256-opcode+1 ;
FOR l := 1 TO opcode DO
BEGIN
impfile^:=databyte;
put(impfile);
END ;
END
ELSE
BEGIN
opcode := opcode + 1 ;
BEGIN
impfile^:=databyte;
put(impfile);
END ;
END;
bytes := bytes + opcode ;
END; (* WHILE BYTES 72 THEN
BEGIN
Writeln(tty,'[FAILED]') ;
Writeln(tty,'Input file is not a macintosh bitmap file') ;
close(macfile) ;
jsys(haltf) ;
END ;
bytes := 0 ;
END; (* FOR I := 1 TO 720 *)
(* WRITE OUT ENDING HP COMMANDS *)
write(impfile,chr(esc),'*rB',chr(esc),'E'); { end graphics mode and reset }
(* WERE DONE *)
close(impfile) ; close(macfile) ;
Writeln(tty,'[OK]')
END.
Mail-From: INFO-MAC-REQUEST created at 10-Jan-85 21:43:53
Return-Path:
ReSent-date: Thu 10 Jan 85 21:43:53-PST
ReSent-From: John Mark Agosta
ReSent-To: info-mac: ;
crisp.
Charlie C. Kim
Columbia University
User Services
[An FTPable executable is in CU20B::PS:MACHP.EXE]
[The copy of the source is in MACHP.C -jma ]
