TriVectus Kicho 1.5 - Keyboard Enhancement Utility
Download: http://archive.info-mac.org/cfg/tirvectus-kicho-15.hqx
Kicho is a small background-only application that modifies the
behavior of the caps-lock key such that when caps-lock is on, typing
with the shift key produces lower-case letters, similar to the
behavior of the caps-lock key on PCs and Apple IIs.
Version 1.5 adds the following options:
* Completely disable the caps-lock key
* Disable the help key
* Play subtle key-click sounds as keys are pressed
Because Kicho is an application and not an extension or control
panel, it can be activated and deactivated on-the-fly, without
restarting, and is unlikely to cause system conflicts. However, being
a background application, it's still invisible to the user.
Kicho requires Mac OS 8 and a PowerPC processor. It is sold as
shareware at a price of $10 for a single-user license. Site and
worldwide licenses are available.
Home web site: http://www.trivectus.com/
Contact: [email protected]
