Re: Behaviour of InvalRect
Posting-Version: version B 2.10.1 6/24/83; site spuxll.UUCP
Path: utzoo!watmath!clyde!bonnie!akgua!whuxlm!spuxll!ech
Subject: Re: Behaviour of InvalRect
Date: Tue, 18-Dec-84 16:25:12 EST
Article-I.D.: spuxll.594
Posted: Tue Dec 18 16:25:12 1984
Date-Received: Thu, 20-Dec-84 02:25:57 EST
References:
Organization: AT&T Information Systems, South Plainfield NJ
Lines: 20
Almost right. the paintWhite flag affects what the Window Manager does
when a window gets EXPOSED as a result of a window in front of it being
closed, moved to the back, or moved. I.e. the Window manager
- paints the exposed area white, then
- adds the exposed area to the invalid region with something that
might as well be InvalRect.
The other side of your problem is that TECalText and TEUpdate seem to be
a bit braindamaged about the precise case you describe (I have been here!).
i.e., the window gets WIDER, so there are fewer lines of text, but the
no-longer-relevant stuff at the bottom stays. Yecch.
Seems that in this case the ONLY option you have -- or at least, one that
works -- is to use EraseRect to clear window's portRect, then invoke
TEUpdate.
To reiterate: paintWhite ONLY affects regions the WMgr "knows" just got
exposed.
=Ned=
