Modula Corp's Modula-2: preliminary review
Path: utzoo!watmath!clyde!burl!ulysses!mhuxr!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: Modula Corp's Modula-2: preliminary review
Date: Thu, 17-Jan-85 06:20:54 EST
Article-I.D.: uw-beave.438
Posted: Thu Jan 17 06:20:54 1985
Date-Received: Fri, 18-Jan-85 02:38:29 EST
Lines: 56
I recently had the opportunity to use Modula Corp's Modula 2 (M2) for the
mac. It compiles into pseudocode. Comes with all the standard
modules, plus several for interfacing with the mac (including
quickdraw and toolbox). I didn't use any of the mac-specific stuff,
so I can't comment on how complete it is. The compiler is fairly
slow--there are four passes, plus I think it's written in M2. The
linker, however, is quite fast.
I really liked programming in M2. The great thing about it is that
you can do separate compilation AND be assured that things are being
type-checked across compilation boundaries (C users take note). Also,
since definition and implementation modules are separate, and the
compiler only needs the definition modules, you can change the code in
a module, recompile ONLY that module, and relink, and you're in
business. (Provided the change in code doesn't also require a change
in specification.) Because the compiler has to look at so many files,
it's slow if you use a disk. But I was running on a 512K mac with a
ramdisk and some other amenities (see below), and it was great.
Because it's pseudocompiled, M2 is not suitable for development, but
for other stuff it's currently my language of choice on the mac.
The only serious problem I've noticed is that ADDRESS types are not
compatible with CARDINAL and INTEGER. I suspect this has something to
do with the fact that ADDRESSes are 4 bytes, the others only 2. The
problem is that I can't do address arithmetic easily. (The old Pascal
variant record trick doesn't help much, since there are two CARDINALs
to an ADDRESS.)
The disk I got was full of M2 stuff; not even room for a system file.
However, by throwing enough junk away, I was able to fit everything
comfortably on one disk. I used the Font Mover, the Desk Accessory
Mover and MockWrite. These last two are put out by CE Software, I
think is the name, from somewhere in the midwest. The disks are
copyable so should be floating around your neighborhood. MockWrite is
a DA which is a simple text editor.
HOW TO GET THE ENTIRE M2 SYSTEM (ALMOST) ON ONE DISK:
1. Throw away all files except: the compiler and Compiler Stuff
folder; the linker; the "tools" Modula-2 and Modula 2; the SYM and REL
files. (Yes, throw away the editor).
2. Take a system file and use the font mover to get rid of ALL fonts
you can.
3. Use the Desk Accessory Mover to get rid of all desk accessories
from the system file and install MockWrite.
4. Put the system file and a finder onto the M2 disk.
Now you can use MockWrite to write programs, saving you lots of space
plus the pain of switching applications. If you have a ramdisk, you
can copy the system to it, speeding some things up a lot.
--Jonathan Amsterdam (JBA@MIT-OZ)
