TrashCleaner 2
TrashCleaner 2
Download: http://archive.info-mac.org/cfg/trash-cleaner-201.hqx
TrashCleaner is a Contextual Menu Plug-in for Macintosh PowerPC under System 8.
When you select the trash with the control key down, TrashCleaner proposes you menus:
* to create in the trash a folder for each disk and arranges the files accordingly.
* to empty the trash *only* for the disk chosen.
This new version 2, more powerful, includes an installer, dialog preferences for the opening of trash and for the
management of network disks, progress dialogs like-Finder, etc.
TrashCleaner works now in collaboration with the system and the finder instead of directly manipulating files and folders.
All tidying and cleaning routines are optimized and can now run in background.
Web site: http://www.ses.fr/trashcleaner
Keywords
trashcleaner,trash,clean,cleaner,tidying,cleaning,contextual,menu,contextualmenu
