Type Switcher Pro
Type Switcher Pro
Download: http://archive.info-mac.org/cfg/type-switcher-pro.hqx
Type Switcher Pro makes changing the types and creators of all
your mismatched documents easy. Simply drag, drop, and change. A popup menu
of stored types/creators saves further time.
Requirements: Appearance Manager, Icon Services (Mac OS 8.5), Navigation
Services, Applescript
-Michael Piatek
