Fix for broken .hcx files
Subject: Fix for broken .hcx files
Date: Sun, 27-Jan-85 23:52:39 EST
Article-I.D.: uw-beave.605
Posted: Sun Jan 27 23:52:39 1985
Date-Received: Tue, 29-Jan-85 05:47:59 EST
Lines: 19
Apparently the only problem is an extra CRLF sequence at the end of each
line. Resulting in output like this:
*** END OF DATA
*** CRC:F001
This would explain why binhex couldn't find the checksum. Anyway, I
deleted the blank lines and the 'broken' file (dataflow.hcx in this case)
worked fine.
I suggest modifying binhex so that blank lines are ignored, it possible,
as the superfluous CRLF problem is a common one when transferring files
between operating systems.
- Ralph Hyre
