ABSpeak stuff
ABSpeak stuff
Path: utzoo!watmath!clyde!burl!ulysses!mhuxr!mhuxt!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: ABSpeak stuff
Date: Wed, 12-Dec-84 14:16:53 EST
Article-I.D.: uw-beave.155
Posted: Wed Dec 12 14:16:53 1984
Date-Received: Fri, 14-Dec-84 06:11:18 EST
Lines: 1429
Here is ABSpeak, along with some of the pertinent source files:
ABSpeak.dl - dl format of the application. To those requesting
BINHEX form, sorry, I don't have a working formatter.
I'll mail a BINHEX form as soon as I can.
speak.R - extracts the phoneme-to-speech translator from
the Smoothtalker demo application. The application
is named Finder on the demo disk, I renamed it
Smoothtalker.
speak.c - contains the hook mSpeak which you call to speak.
This nub loads the resource, fiddles arguments, and
jumps into the code (More about arguments below).
speak.h - just a header file for mSpeak.
ABSpeak.c - the source for ABSpeak
ABSpeak.R - resources for ABSpeak
info.txt - some more anonymous information
You will have to do some hacking to get compile ABSpeak on your own
development system. I used Consulair's Mac C along with Apple's MDS.
Mac C passes args in registers D0, D1, ..., so you will have to recode
the mSpeak and _dlogFilter hooks to match your local conventions. Also,
I didn't include any of the header files, most are like SUMACC's, except
for buffered IO routines, so you will have to replace the calls to
delete, create, open, close, read, and write with something appropriate
if you want to implement ABSpeak's open and save functions.
Enjoy,
Mike Schuster
@cit-20
info.txt
SmoothTalker(tm) Phoneme Codes
(SmoothTalker is a trademark of First Byte)
Phoneme codes are always one lower-case letter or two upper-case
letters:
vowels: Short form: Long form:
A AE as in CAT EY as in BAIT
E EH as in KETTLE IY as in BEET
I IH as in KIT AY as in BITE
O AA as in COT OW as in BOAT
U AH as in CUT UW as in BOOT
AO intermediate O as in CAUGHT
UH intermediate U as in BOOK
AX schwa sound as in AGAINST
OY diphthong in BOY
AW diphthong in LOUD
ER as in FURTHER
consonants:
b B in Bun
CH CH in CHin
d D in Dun
f F in Fun
g G in Gun (hard g)
h H in Hit
j G in Gin (soft g)
k K in Kin
l L in Lit
m M in Mit
n N in Nit
p P in Pun
r R in Run
s S in Sun
SH SH in SHun (unvoiced SH)
ZH S in pleaSure (voiced SH)
t T in Ton
TH TH in THin (unvoiced TH)
DH TH in THen (voiced TH)
v V in Vim
w W in Won
WH WH in WHich
y Y in Yon
z Z in Zen
NG NG in siNG
Inflections:
\ inflect downward
/ inflect upward
[ shorten the following phoneme
] lengthen the following phoneme
Parameter changes:
Vn = set volume where n=0 for soft through n=9 for loud
n = set pitch where n=0 for low through n=9 for high
Sn = set speed where n=0 for slow through n=9 for fast
T = set tone to Treble (high tinny sound)
B = set tone to Bass (sounds more normal)
Example:
English: "the freedom of speech"
Phonemes: V6S25DHAXf9rIYS9d5AHS6m3AHv S79spy0IYCH
V6 Volume 6
S2 Speed 2
5 Pitch 5
DH AX "the"
f "f"
9 Pitch 9
rIY "ree"
S9 Speed 9
d "d"
5 Pitch 5
AH "o"
S6 Speed 6
m "m"
3 Pitch 3
AHv "of"
S7 Speed 7
9 Pitch 9
spy "spee.."
0 Pitch 0
IYCH "..eech"
speak.R
* obtain male speaker
speak.Rsrc
RSRC????
Type MSPK = GNRL
,1 (32)
.R
smoothtalker CODE 2
speak.c
// Speak.c
#include "MacDefs.h"
Handle mSpeaker = 0;
short mSpeak(text, volume, pitch, speed)
char *text;
short volume;
short pitch;
short speed;
#asm
include MacTraps.D
; push parameters
clr.w -(sp)
move.l d0,-(sp)
move.w d1,-(sp)
move.w d2,-(sp)
move.w d3,-(sp)
; get handle to code
tst.l mSpeaker(a5)
bne.w @speak
; get speaker
clr.l -(sp)
move.l 'MSPK',-(sp)
move.w #1,-(sp)
_GetResource
move.l (sp)+,d0
beq.w @nospeak
move.l d0,mSpeaker(a5)
move.l d0,a0
_HLock
; invoke speaker
@speak
move.l mSpeaker(a5),a0
move.l (a0),a0
adda.l #4,a0
jsr (a0)
move.w (sp)+,d0
rts
; no speaker to invoke
@nospeak
lea 10(sp),sp
move.w (sp)+,d0
#endasm
speak.h
// Speak.h
extern short mSpeak(/* char *text; short volume; short pitch; short speed; */);
ABSpeak.c
// ABSpeak.c
#include "Events.h"
#include "Quickdraw.h"
#include "Window.h"
#include "Textedit.h"
#include "Control.h"
#include "Dialog.h"
#include "Packages.h"
#include "CIO.h"
#include "Speak.h"
extern char *CtoPStr();
extern char *PtoCStr();
// resource ids
#define npronErr 1
#define dlogId 1
#define quitId 1
#define speakAId 2
#define speakBId 3
#define textAId 4
#define textBId 5
#define openAId 6
#define openBId 7
#define saveAId 8
#define saveBId 9
Point putWhere = {129, 104};
Point getWhere = {113, 83};
long getType = 'TEXT';
char putAPrompt[] = {"Save A text in:"};
char putBPrompt[] = {"Save B text in:"};
short dlogFilter(dlog, event, item)
DialogRecord *dlog;
EventRecord *event;
short *item;
if (dlog->editField >= 0 &&
event->what == keyDown &&
event->modifiers & cmdKey)
switch ((unsigned char) (event->message & 0xFF))
case 'x':
case 'X':
TECut(dlog->textH);
break;
case 'c':
case 'C':
TECopy(dlog->textH);
case 'V':
case 'v':
TEPaste(dlog->textH);
break;
*item = dlog->editField + 1;
return -1;
else
return 0;
short _dlogFilter(dlog, event, item)
DialogRecord *dlog;
EventRecord *event;
short *item;
#asm
move.l 4(sp),d2
move.l 8(sp),d1
move.l 12(sp),d0
jsr dlogFilter
move.w d0,16(sp)
move.l (sp)+,a0
lea 12(sp),sp
jmp (a0)
#endasm
main()
DialogPtr dlog;
short item;
TEInit();
InitDialogs(0);
InitCursor();
CtoPStr(putAPrompt);
CtoPStr(putBPrompt);
mSpeak(CtoPStr(" "), 5, 5, 6);
dlog = GetNewDialog(dlogId, 0, -1);
do
ModalDialog(&_dlogFilter, &item);
switch (item)
case speakAId:
speakText(dlog, textAId);
break;
case speakBId:
speakText(dlog, textBId);
break;
case saveAId:
saveText(dlog, textAId, putAPrompt);
break;
case saveBId:
saveText(dlog, textBId, putBPrompt);
break;
case openAId:
openText(dlog, textAId);
break;
case openBId:
openText(dlog, textBId);
break;
case quitId:
break;
while (item != quitId);
DisposeDialog(dlog);
speakText(dlog, textId)
DialogPtr dlog;
short textId;
short result;
Handle hand;
Rect rect;
char text[256];
GetDItem(dlog, textId, &result, &hand, &rect);
GetIText(hand, text);
result = mSpeak(text, 5, 5, 6);
if (result > 0)
SelIText(dlog, textId, result - 1, result);
mSpeak(*(hand = (Handle) GetResource('STR ', npronErr)), 5, 5, 6);
saveText(dlog, textId, prompt)
DialogPtr dlog;
short textId;
char *prompt;
short result;
short file;
Handle hand;
Rect rect;
SFReply reply;
char text[256];
SFPutFile(&putWhere, prompt, "", 0, &reply);
if (reply.good)
PtoCStr(&reply.Namelength);
delete(&reply.Namelength, reply.vRefNum);
create(&reply.Namelength, reply.vRefNum);
setSig(&reply.Namelength, reply.vRefNum, 'TEXT', 'EDIT');
file = open(&reply.Namelength, reply.vRefNum, WRITE|ACCESSPATH);
write(file, text+1, ((long) text[0]) & 0xFF);
close(file);
openText(dlog, textId)
DialogPtr dlog;
short textId;
short result;
short file;
Handle hand;
Rect rect;
SFReply reply;
char text[256];
SFGetFile(&getWhere, "", 0, 1, &getType, 0, &reply);
if (reply.good)
file = open(PtoCStr(&reply.Namelength), reply.vRefNum, READ|ACCESSPATH);
text[0] = (getEOF(file) <= 255) ? getEOF(file) : 255;
read(file, text+1, ((long) text[0]) & 0xFF);
close(file);
SetIText(hand, text);
ABSpeak.R
* ABSpeak.R
* Resources for ABSpeak
ABSpeak
APPLABSP
Include ABSpeak.rsrc
Include Speak.rsrc
* That is not pronouncable
Type STR
,1
S4DHAEtIHzS23nAHtS4prAX6nAWn4sAXb3]l
Type DLOG
,1
Dialog
29 16 335 496
Visable NoGoAway
1
0
1
Type DITL
,1
15
button
207 8 225 72
Quit
button
15 8 33 72
Speak A
button
111 8 129 72
Speak B
editText
16 88 96 464
* ABC Song
editText
112 88 192 464
3S2EY bIY 7sIY dIY 8IY EHf 7jIY S55EYCH AY 4jEY kEY 3S7EHl ++
EHm EHn OWh 1pIY S46kyUW AHr 5EHs tIY yUW 4vIY 6dAHblyUW ++
5EHkz 6wAY 1zIY S62nAW AY 7nOW mAY 8EY bIY 7s]IYz ++
6tEHl mIY 5wAHt yUW 4THIHnk AHv 2]mIY
button
47 8 65 72
Open A
button
143 8 161 72
Open B
button
79 8 97 72
Save A
button
175 8 193 72
Save B
staticText
208 84 224 488
AE pAt/EY Ate/EH pEt/IY bE/IH hIt/AY sIze/AA cOt/OW gO
staticText
224 84 240 488
AH cUt/UW cOO/AO fOr/UH tOOk/AX thE/OY bOY/AW lOUd/ER fUR
staticText
240 84 256 488
b Bib/CH CHew/d DeeD/f Fit/g GaG/h Hat/j Just/k KiCK
staticText
256 84 272 488
l seLf/m MuM/n No/p PoP/r Run/s SauCe/SH SHy/ZH viSion
staticText
272 84 288 488
t To/TH THin/DH THe/v oF/w Wag/WH WHere/y Yes/z siZe
staticText
288 84 304 488
NG siNG/V# vol/S# speed/# pitch/B base/T treb/]/[/\//
ABSpeak.dl
@@@@@A@@@@@@GFCF@@@@GECF@@@@@@IJFG@HFA@@@AKBF@@@@@EHFA@@@B@HFK@FDJ
@BFG@BG@JNFA@@@AINDAOJOINJC@CH@ADBFKDJBBCL@@@@@EN@IBD@HBOL@@@ECAOL
OOJM@ADBIBE@FKC@DHLAHBOJOOIJFG@H@LDA@@@AFG@BEBE@FA@@@BC@@HNI@@@C@@
AFFF@FA@CJOIKBFFHBDBGH@ADBDLMOGOONC@CH@ADBDNGEEBDAFGMLECE@@LE@@@@D
FMNJF@HDBAMO@ABDG@@AABCJOIHJFG@H@H@F@@@KFG@BG@@CFA@@@B@DG@@DFA@@@A
FHBFGL@@MOOKOOBHGL@@MOOIOOB@GJOIEDC@CJOOC@CBCJOIEJEEDADCOJONCBCFCL
@@LGDJACACLC@@MOOOOOBDDIGD@BAHAJDJADFJOLAFHDAHAJDJAEFK@BAOAFDJADFJ
OLAFHDEALJOONHEALKOON@CF@ABDDIGD@EDJADFJOLAFIJDJAE@@@@@@AH@@@@@@BH
@@@@@ACL@@@@@@@H@@@@@@B@@@@@COCL@@@AJIO@@@@@AEKD@@@@@@@ADBJGDNEFOO
N@FABFB@@MEIH@BO@@@DD@@@LJBKD@ONOLJHFNJHONJIABDNKJ@@ODDJH@FF@DDNKJ
@BOJJIOD@@@@@@@@DBJGBOCLDCDODDDECOCL@@OOJIJ@B@AOFG@@@@M@BO@@DBJGBO
CLDCDODDDECOCL@@@AJIJ@DAOJOOMFBBEOB@AA@BH@@@OOOOOOEHH@B@H@B@EOBHDH
J@BEBH@@EMHDJ@BIB@E@CBAH@BDA@@GOCDAHCFAHDHLBDHLCBFDMIGLBIGLCBDDMCN
@A@BDA@@@NFG@@@@A@B@@CJAANFFFFBFDHBDDHMELBMELCC@@CNBDHECD@FK@FDBEK
DNOJOOOHB@EDELDHEAHDFKDHB@AHBBAHCJ@@DHD@N@DHCL@@ND@HFG@@@@@NEC@@FG
BJBBGJOOELMCLABB@I@BDF@@@CFGADECDFFG@HBEHAE@@@DNOJOOLNCEHAE@@@DNOJ
OOLFAEHAE@@@DNOJOOKNDCOBA@@@DNOJOOMFBO@JB@DLJ@BJBO@LJIJCBDEOBBDJBF
DJBHDJDNGEBBEOBMDOOOOLBMDI@@@DDBH@B@D@DNMADNENBHFN@@@DKIOL@@@@@@@@
FGOBBNFNOOOLB@D@DNMDDJH@FK@HDJHAFK@@@@A@F@@JDJHAFL@@@@A@DDH@DDHAF@
@NDDHAFA@JDDHADNGEDDH@DNOJOOOFBN@ADHDGLNL@CO@GBN@@DHDGLNLALBL@MNEO
DHDGDBDGMBHGDNGEDJH@FK@HDJHAFK@@@@A@F@@JDJHAFL@@@@ABDDH@DDHAF@A@DD
HAFA@LDDH@DDHADNGEDDH@DNOJOOODDJH@FGCJDBDGKBH@FE@NEBDGDJH@FK@@@@@N
NCHHDNOJOOO@DJDGFGBLNBHHBO@BBD@ADBHANCHIKDH@FE@DIDH@EBDAECDGFO@FNB
HHDNOJOONNB@@BBDAODNGEBBCLGOOOOOOODBH@DNGEB@@ADBHADNGEB@D@DJAHFFOL
BBDHECDHI@HHFL@JDDD@CB@@ACB@ECDAFNOJA@H@DNGEB@D@BBD@DBHAABAHFG@JEC
DAABMHEALIOOOLDBAAB@D@DNGEDJ@AFG@D@@DB@D@@DAOJ@@@FC@HBB@D@@@@@DNGE
DBJGDNEFOOO@DHNN@@@GOOO@B@FNOOO@DJFH@@JDFMA@B@FNOOOD@LE@@@@CFF@FA@
CL@@@AF@@BDB@@DJ@@FG@NBBFNOOODC@BI@@@N@BD@@A@@DJD@FG@@@@HHB@FNOOOD
B@BH@@@B@BH@@@@@@@OODNOJ@@BLB@FNOOO@BOBH@@J@JIMFDNOJ@@DNB@FNOOO@BO
BH@@J@JIMEB@FNOOO@BOBH@@J@JIMKDNOJ@@CFDNOJ@@CB@LH@@@@@@@GHFGLN@LH@
@@@@@@EHFGLF@LH@@@@@@@FCFGLL@LH@@@@@@@DCFGLD@LH@@@@@@@EFFGLF@LH@@@
@@@@GFFGKNB@FNOOO@C@BH@@JDEBD@B@FNOOOHC@H@C@CLOOOODNENEHHODNGEDBD@
DNENEHHODNGEBDBO@@@DBBBO@@@HB@BO@@@LDNKJOOBFCOD@@@A@B@EODONO@@@LDN
M@DNGEDBJGDNEFOOOFJILLDBJGJIGKJHE@DANMONMLB@@HDNKJONKHDANMONNLB@@H
DNKJONJNDAOJ@CG@B@@HDNKJONJDB@@HBBCL@@@@@@@EBDCL@@@@@@@EBFCL@@@@@@
@FDNKJ@CEFDBJGCOCL@@@ADBJGBOCLOOOOOOOOJIGLB@EOBMDHOOOHDHGJOOHFDHFN
OOOFJIIAC@BNOOOFDNOJ@@HBB@BNOOOHBBCL@@@@@@@DDNKJ@@KFDNOJ@@ILB@BNOO
OHBBCL@@@@@@@EDNKJ@@JDDNOJ@@HJB@BNOOOHBBCL@@@@@@@DDANMONMLBD@HDNKJ
@ABHDNOJ@@GBB@BNOOOHBBCL@@@@@@@EDANMONNLBD@HDNKJ@AA@DNOJ@@EJB@BNOO
OHBBCL@@@@@@@DDNKJ@ANNDNOJ@@DHB@BNOOOHBBCL@@@@@@@EDNKJ@AMLDNOJ@@CF
DNOJ@@CBDNOJ@@BN@LD@@@@BFG@@OOGJ@LD@@@@CFGHD@LD@@@@HFGI@@LD@@@@IFG
JB@LD@@@@FFGKD@LD@@@@GFGL@@LD@@@@AFGLL@LFN@@@AOOOFFF@@OOCJBOBNOOOH
JIHCDNENEHHODNGEDBJGDNEFONNFDHNN@@@COOODBOBNOOODCOBNOOOJDHFNOOOBDH
FNOONNDHFNOONFJIHMBOBNOONNDHFNONNFJII@DANNONNFB@@HBBCL@@@@@@@EBDCL
@@@@@@@EBFCL@@@@@@@FDNKJ@BBDCMD@OOOBDJFNOOOBFO@@@@DDBOBNOOODCOBNOO
OJC@BNOOOBECD@CO@@COBNOOOBJIGNDBJGBOCLECEDEBB@COCL@@@AJIJ@B@EOBMDH
OONNB@A@BBCL@@@@@@@EBDCL@@@@@@@EBFCL@@@@@@@FDNKJ@AMFDNENEHHODNGEDB
JGDNEFONIFDHNN@@@GOOO@BOBNOOO@COBNOOOFDHFNOONNDHFNOONHDHFNOON@JIHM
DANMONM@B@@HBBBNOOOHDAOJ@AINBD@HDBHCDANNOOIFBH@HDNKJ@BAHDJBNOOIFFG
@@@@JFDANNOOJ@B@@HDNKJOLMBCBBNOOILDHLADANNOOJ@B@@HBDCL@@@@J@@IDNKJ
@FCDCBBNOOILDHLADANNOOJ@B@@HBDCL@@@@J@@HDNKJ@FANCBBNOOILDHLADANNOO
J@B@@HBDCLEDDEEHEDBFCLDEDDDIEDDNKJ@GCLCBBNOOILDHLADANNOOJ@B@@HBDCL
@@@@@@@JDNKJ@GHLCMD@OONLBOBNOONHDHFNONIFJII@ADBNONIFDHHBDHLB@BHB@@
@@@@OOC@BNOONLDHL@DANNONIGBB@HBFCL@@@@J@@CDNKJ@IMDC@BNOONLDHL@DNKJ
@HCFDNENEHHODNGEDBJGDNEFONIJDHNN@@@COOODBOBNOOODCOBNOOOJDHFNOOOBDH
FNOONLDHFNOONDJIHMDANMONMDB@@HDAOJ@@KBBB@HDBHBBFCL@@@@@@@ADANMONMH
BH@HDBHEDANNOOIJBL@HDNKJ@@NDDJBNOOIJFG@@@@HFDANNOOJDB@@HDNKJOKMHB@
@HCBBNOOJ@DHLABDCL@@@@@@@IDNKJ@FMNCMD@OOO@C@BNOOO@DHL@DNKJ@MLB@LH@
@@@@@@OOFN@NBO@@C@BNOOO@DHL@DNKJ@MJNF@@FB@CL@@@@@@OOAMD@ONIJADBNON
IJDHHBDHLB@BHB@@@@@@OOC@BNOOO@DHL@DANNONIKBB@HBFCL@@@@J@@BDNKJ@I@F
C@BNOOO@DHL@DNKJ@GFHBOBNOONLDHFNONIJJIHOEHDODNENEHHODNGEB@@@@@@@DB
FGBO@@CO@ACO@BCO@CDJJMONLLFF@@@@ALDBJGBOCJ@@C@COCL@@@AJIJ@B@AOFG@@
@@ALBKD@ONLLB@D@J@BIB@FMONLLB@E@MAOL@@@@@@@DDNI@C@AODNGEDONO@@@JC@
AODNGEDMECE@DK@@@@B@D@BOA@BO@ABO@BCO@CBO@DBO@EBO@FCOCL@@@BJINJDNGE
B@DOBBD@BOAABO@ABO@BCO@CBO@DBO@EBO@FCOBH@@@FBOBH@@@HCOCL@@@DJINJDN
GEB@D@BOA@BO@ABO@BBO@CBO@DCOCL@@@AJINJDNGEB@D@BOA@BO@ABO@BBO@CBO@D
CO@EBO@FCOCL@@@CJINJDNGEDAOJ@@@FC@HAB@D@@@@@DNGEDJHAFF@@@@@JDBH@B@
D@DNOJ@@AJB@D@BBDAEBHHEEDBA@MIEGLJOOOLIBHIDDHAECHAB@D@A@HADNGEB@D@
BBDADNOJ@@@DABMHEALJOOOLDNGEKBH@FL@@@@@DB@@ADNGEKBH@FL@@@@A@DJHAFK
@@@@@HB@@ADNOJ@@@DDBH@DNGEKBH@FO@@@@@DB@@ADNGEB@D@BBDABDA@B@IABBHB
DNGEKBH@FN@@@@A@MBHBKBH@FO@@@@@HE@L@DNOJ@@@DDBH@DNGEDJHAFG@@@@A@B@
D@BBDABCE@@@@@CCDB@@@DB@HAB@DADNGEDJH@FG@@@@ADB@D@KBFH@@@DFG@@@@@J
B@BH@@@@DNOJOONJB@D@DNGEB@D@BDA@DBHCDJHBFG@@@@BLBDDBKBFJ@@@DFG@@@@
@LBF@BBDBJ@@@@DNOJOONHDJHCFG@@@@@NBFDCBGFJ@@@@@@@@DNOJ@@@FB@JJ@@@@
B@DBDNGEBD@@DAOH@@@@@H@A@@@HFG@@@@BHB@CL@@@@@@@JJAANFF@@@@ALBBDHB@
CL@@@@@B@JJAANBCDH@@@FBB@IDANMONLDB@@HDNKJOOF@DNGECB@@DHLADANMONLD
B@@HDNKJOOHDB@@HFG@@@@ABBBFH@@@FJ@AOB@@IFG@@@@@FB@DIJ@AODNGEDJHAFL
@@@@@FB@D@C@HADNGEB@D@C@A@FG@@@@@HDHL@BB@@DBE@B@@ADNGEB@D@BBDADBBI
@@CJDBBI@@CKBCDB@@CBDBJI@@@LDBFI@@A@CCFH@@@D@@AHBCDB@@B@CCGL@@@A@@
BLDNGEB@D@BBDADJBI@@CJFG@@@@AHDBBI@@CJCBBI@@A@FNOJDHLADANH@@AHB@@H
DNKJOOIHDNGEDHNGN@@@B@D@BBDAB@BH@@@HBBBH@@A@IBJI@@CFDNKJONG@DJH@FG
@@@@EFBO@@B@BO@@@DBBBO@@@HDNKJOOKBB@FO@@@HAAGL@@@A@@CJBAFH@@CF@@BN
BAEO@@BDB@@HBBBO@@@HDNKJOMO@@LD@OOLKFF@@@@ADB@BO@@@DBBBO@@@H@BHA@@
@@J@@CDNKJOMMFBB@@B@EGDANH@@AHB@@HDNKJOOBDDONO@@@LDNGEBBDADJBI@@CK
FG@@@@A@DBBI@@CKBDCL@@@@JD@CDNKJOOGBDNGEBBDABCDB@@CFBDCL@@@@JD@BDN
KJOOF@DNGEDBJGDNEFOOO@DHNN@@@COOODIALHBMDHOOO@MNOLOOODCBBNOOOJ@BDA
OL@@DHLAB@CL@@@@@B@@DNKJOMM@BMD@OONDC@BNOOOJ@BD@@@A@DJD@FG@NB@CL@@
@@@@IJJAANBMDHOOO@BN@HFG@LB@BNOONDJAANBMDHOONLBN@HFG@LB@BNOONDJAAN
BMDHOONHBN@HFG@@@@NDB@FNOOO@CAFNOOOJ@@@FB@FNOOO@DBFH@@AHB@FNOOO@BA
FNOOND@@@HB@FNOOO@DBJH@@@LC@BNOOOFDHL@DNKJ@IJJB@FNOOO@BAD@@@A@DJH@
FL@@@@AHB@FNOOO@BBFNOOO@CCFH@@AB@@AHB@FNOOO@DBJH@@A@CDBNOOOFDHLBDA
NMONLHB@@HBBBNOOO@DNKJOMEJB@FNOOO@MAOL@@@@@@BBBBFNOOO@BCDH@@AJB@BN
OOO@BB@HBDBNOONLDNKJONBBB@FNOOO@MAOL@@@@@@ENBBFNOOO@BCDH@@ANB@BNOO
O@BB@HBDBNOONHDNKJON@BB@FNOOO@B@BNOOO@BBBH@@AJDBHBDNKJONM@B@FNOOO@
BBFNOOO@B@BNOOO@BBBI@@ANBDBH@@@HDNKJONKHB@FNOOO@BBFH@@AJB@FNOOO@BA
FI@@CB@@ADB@FNOOO@DNENEHHODNGEBB@@B@BMONLHDNKJOLNBDNGEDBJGDNEFOOOD
BMD@OOOHCBBNOOOJDHLADANMONLHB@@HDNKJOLNBBMDHOOODBN@HFG@@@@BDB@FNOO
ODBBFH@@AJB@FI@@CBJ@AOB@FNOOODBBFH@@ANB@FI@@CBJ@AOB@FNOOODJ@AODNEN
EHHODNGEDBJGDNEFOOGNDHNN@@@GOOO@DANNOOK@B@@HBBBNOOO@BDCL@@@@@@D@DN
KJOKMFBMDHOOI@CMFNOOOFOOIDDBBNOOIHCBBNOOOJDHLADANNOOGNB@@HDNKJOKJL
DNENEHHODNGEDBJGDNEFOOCNDHNN@@@GOOO@DANNOOK@B@@HBBBNOOO@BDCL@@@@@@
D@DNKJOKIBBMDHOOE@CMFNOOOFOOEDDBBNOOEHDANNOOG@B@@HBBBNOOOHBDCL@@@@
@@D@DNKJOKG@BMDHOOEJDANNOOCNB@@HBBCL@@@@J@@KDNKJOKE@DNENEHHODNGEDB
JGDNEFOOJLDHNN@@@OOONLDANNOOJLB@@HBBBNOONLBDCL@@@@@@D@DNKJOKCFBBFN
OOODBCDH@@ABB@FNOOODCAFNOOOB@@AFB@FNOOODDBBH@@AJB@FNOOODDBFH@@ALCB
BNOOOJDHLAB@BNOOODDNKJOJOJDNENEHHODNGEDBJGDNEFOOIJDHNN@@@OOONLCBBN
OOOBDHLAB@BNOONLDANNOOILBD@HBFCL@@@@J@@LDNKJOOHFCMD@OOIJB@FNOOODB@
JNOOKLB@FNOOOHB@JNOOL@C@BNOOIJDNENEHHODNGEDBJGDNEFOOIJDHNN@@@OOONL
CBBNOOOBDHLAB@BNOONLDANNOOILBD@HBFCL@@@@J@@LDNKJOODBCMD@OOIJDJFNOO
IJFF@@@@BLBMFNOOODOOKLBMFNOOOHOOL@CBBNOOOBDHLAB@BNOONLDANNOOILBD@H
BFCL@@@@J@@MDNKJOOA@CMD@OOIJC@BNOOIJDNENEHHODNGEDBJGDNEFOOGHDHNN@@
@GOOO@CBBNOOOJDHLAB@CLOOOOOOOODNKJOKBNBMDHOONLDANNOOJLB@@HBBBNOOO@
BDCL@@@@@@D@DNKJOJBBBMDHOOHLCMFNOOOFOOI@DBBNOOIDC@BNOOOJ@BD@@@@CAM
D@OOIEDJJNOONLFG@JB@FNOONLBBFH@@@FF@@BICLIBMDIOOIFCBBNOOOJ@BDA@@@D
DJDAFG@FC@CLJ@@JF@@DC@CLJ@@@DHL@BO@@DANNOOGJB@@HBBAODNKJOIL@DJD@FG
@FC@BNOOHJF@@DC@BNOOIBCMD@OOGHDJFNOOHJFG@@@@A@B@CLOOOOOOOODNKJOJMB
DNOJ@@ADDJJNOONLFG@@@@@LB@FNOONLCAFNOOIB@@@DDJFNOOHJFF@@@@ABCBBNOO
OJDHLAC@BNOOIBDHL@DNKJOKMJC@BNOOGHDNENEHHODNGEDBJGDNEFOOL@BMD@OOOH
C@BNOOOJDHL@DNKJ@@EHCMD@OOL@DJFNOOL@FF@@@@BFCMFNOOOJOOMJDANNOOLBB@
@HBBCL@@@@J@@ADNKJOIBNDHL@BB@@DANNOOL@B@@HDNKJOJGLDJFNOOL@FF@@@@AF
C@BNOOOJDHL@DNKJOJDDC@BNOOOJDHL@DNKJOLM@C@BNOOL@DNENEHHODNGEDBJGDN
EFOOL@BMD@OOOHDBFNOOL@C@BNOOOJDHL@DNKJOLJBBMDHOOODBN@HFG@@@@INB@FN
OOODB@BNOOODBBBH@@AJDNKJOK@HB@FNOOODB@BNOOODBBBH@@ANDNKJOJOHB@FNOO
ODB@BNOOODBBBH@@AJDNKJOJDLB@FNOOODB@BNOOODBBBH@@ANDNKJOJCLB@FNOOOD
C@BH@@@F@BD@@@@BDJD@FG@@@@CFCMFNOOOJOOMJB@FNOOODBMFH@@A@OOMNDANNOO
LBB@@HBBCL@@@@J@ABDNKJOHFFDHL@BB@@B@FNOOODMAOL@@@@@@AHB@@HDNKJOIJN
B@FNOOODMAOL@@@@@@AHB@@HDBHADNKJOIJHCMD@OOL@CMFNOOOJOOMJDANNOOLBB@
@HBBCL@@@@J@DEDNKJOHBFDHL@BB@@DANNOOL@B@@HDNKJOIGDC@BNOOL@DNENEHHO
DNGEDBJGDNEFOOLBDHNN@@@COOODCMFNOOOFOOMJBMFNOOOHOONFDANNOOLBB@@HBB
CL@@@@J@A@DNKJOGNFDJD@FG@HC@BNOOMBDHL@F@@DB@BNOONJDNENEHHODNGEDBJG
DNEFOONHDHNN@@@OOONLC@BNOONNDHL@DNKJOKGJBMDHOONHBN@HFG@@@AC@MNOLOO
OH@LFNJ@@BOOOJFFAJB@FNOONHBBFNOONHBBBH@@A@IBJI@@@LB@BNOOODDNKJOGM@
F@@DB@BNOOODBMD@OOODBMD@OON@DJJNOOODFG@@@@MLB@FNOONHBBFH@@AJB@FNOO
NHBDFI@@CBMENH@@@HB@FNOONHBB@JIBJH@@ADB@BNOOODDNKJOGIDBMD@OONDB@FN
OONHB@BNOONHBBBH@@AJDNKJOHN@@LFNJ@@BOOOJFF@@@@AJB@FNOONHB@BH@@ADBB
BNOOO@BDBNOONDDNKJOGEBDNOJ@@DDB@FNOONHB@BNOOO@BBBH@@ADBDBNOONDDNKJ
OGCJB@FNOONHBBFH@@AJACGL@@@A@@CKB@FNOONHBBBH@@@LMBJNOONDB@FNOONHB@
BH@@A@DNKJOGDDB@FNOONHBAD@@@A@B@BNOONDIAJNOOODB@BNOONDMAJNOOO@C@BN
OONNDHL@BBBNOONDBDCL@@@@@@@CDNKJ@ACLDHL@BB@@B@FNOONHMAOL@@@@@@AHB@
@HDNKJOGOLDNOJOOB@B@FNOONHMAOL@@@@@@AHB@@HBBBNOON@DNKJOGO@DNENEHHO
DNGEMNOLOOLNCMFNOONNOOLNBMFNOOO@OOMFBMFNOOODOOMJDBFNOONBDBJNOONDCB
BNOOOJDHLADANNOOKFB@@HDNKJOFEDDJD@FG@F@LFNOOMIOOLFFG@HC@BNOOLFDHL@
F@@DB@BNOOMNDNENEHHODNGEDBJGDNEFOOO@DHNN@@@GOOO@B@FNOOODCAFNOOOB@@
AHCBBNOOOJDHLAB@BNOOODDNKJOFABDNENEHHODNGEDBJGDNEFOOLFBMD@OOOHCMFN
OOOJOOMNDANNOOLFB@@HBBCL@@@@J@@FDNKJOENLDNENEHHODNGEDBJGDNEFOOODBM
D@OOOHC@BNOOOJDHL@DNKJOIIBBMDHOOODBN@HFG@@@@B@B@FNOOODBBFNOOODMCOL
@@@@@@AHB@@IBBBH@@@LDNKJOGAHDNENEHHODNGEMNOLOOLNCMFNOOOJOOMJDANNOO
LBB@@HBBCL@@@@J@AHDNKJOEI@DJD@FG@HC@BNOOMBDHL@F@@DB@BNOOO@DNENEHHO
DNGEDBJGDNEFOONLDHNN@@@GOOO@C@BNOOOBDHL@DNKJOIBDBMDHOONLBN@HFG@@@A
MHMNOLOOONDBFNOONJ@LFN@@@AOOOJFF@DDBH@F@AJ@LFN@@@COOOJFF@JB@FNOONL
B@BH@@@LF@@HB@FNOONLB@BH@@A@BBBNOOODMBH@B@FNOONLBADA@@@LB@FNOONLDJ
JH@@@LFL@@@@ADB@FNOONLDBJH@@@LCMGLOOMHOONJDNOJ@@BJB@FNOONLBBFNOONL
B@BH@@@LK@JI@@A@FO@@@@AFB@FNOONLBBFNOONLBCFH@@A@@@@LCMGLOOMIOONJB@
FNOONLBBFNOONLBDFI@@AJBBFNOONLB@BI@@@LBBBJ@@CFBDBH@@@HDNKJOECBDJH@
FG@@@@@FDNOJ@@NHB@FNOONLBBFNOONLBDFI@@ANBBFNOONLB@BI@@@LBBBJ@@CFBD
BH@@@HDNKJOE@HDJH@FG@@@@EFB@FNOONLMAOL@@@@@@ANBBFNOONLMCOL@@@@@@AJ
B@@IBB@HDNKJODMJB@FNOONLB@BNOONLBBBH@@ANDNKJOFILB@FNOONLBBFH@@AJB@
FNOONLBDBI@@CFMDJH@@@HB@FNOONLB@BNOONLBBBH@@ANDNKJOFIBDNOJ@@FNB@FN
OONLB@BNOONLBBBH@@AJDNKJOFFDB@FNOONLB@BNOONLBBBH@@ANDNKJOFEDB@FNOO
NLBBFNOONLBDBI@@@HDDHBB@BH@@@LL@HBB@FNOONLBO@@B@BNOONLBBBH@@AJBDAO
DNKJOFDFB@FNOONLBBFH@@AJB@FNOONLBDBI@@CFMDJH@@@HB@FNOONLB@BNOONLBB
BH@@ANDNKJOFBBB@FNOONLBBFH@@AJB@FNOONLBDFI@@CBMENH@@@LB@FNOONLBBFH
@@AJIENI@@CFB@FNOONLBADJ@@ADCBBNOONJDHLAB@FNOONLMAOL@@@@@@AHB@@HDN
KJODOBDNENEHHODNGEMNOLOOLNCMFNOOOBOOMBCMFNOOOJOONFBMFNOOODOONHDANN
OOKJB@@HBBCL@@@@J@DDDNKJOCENDNENEHHODNGEDBJGDNEFOOODBMD@OOOHC@BNOO
OJDHL@DNKJOG@DBMDHOOODBN@HFG@@@@B@B@FNOOODBBFNOOODMCOL@@@@@@AHB@@I
BBBH@@A@DNKJODHJDNENEHHODNGEMNOLOOLNCMFNOOOJOOMJDANNOOLBB@@HBBCL@@
@@J@AADNKJOC@BDJD@FG@HC@BNOOMBDHL@F@@DB@BNOOMNDNENEHHODNGEDBJGDNEF
OOO@DHNN@@@COOODC@BNOOOFDHL@DNKJOFIFBMDHOOO@BN@HFG@@@@FBDJJNOOOHFL
@@@@@LC@CLOOLNDNENEHHODNGEB@FNOOO@BAFNOOOH@@A@B@FNOOO@BBFNOOO@B@BH
@@@LK@JI@@A@FO@@@@AJC@BNOOOFDHL@DBHABDCL@@@@@@@BDNKJOMABDNENEHHODN
GEB@FNOOO@MAOL@@@@@@AHB@@HDBHADNKJOCMJDNENEHHODNGEMNOLOOLNCMFNOOOF
OOMFBMFNOOOHOOMJDANNOOKNB@@HBBCL@@@@J@ABDNKJOBDLDNENEHHODNGEDBJGDN
EFOOG@DHNN@@@GOOO@DANNOOK@B@@HBBBNOOO@BDCL@@@@@@D@DNKJOBCBBMDHOOHB
CMFNOOOFOOHFCBBNOOOJDHLADANNOOG@B@@HDNKJOB@LDNENEHHODNGEDBJGDNEFOO
GBDHNN@@@COOODDANNOOKDB@@HBBBNOOODBDCL@@@@@@D@DNKJOAOBBMDHOOHFDANN
OOGDB@@HBBCL@@@@J@ADDNKJOAMBCMD@OOGBB@FNOOOHC@JNOOHJC@BNOOGBDNENEH
HODNGE@@@@@AANOOHA@A@@@@CL@AOOONM@@@@@@@HA@AOOONMB@@@@@@FH@AOOONMD
@@@@@@GA@AOOONMF@@@@@@EC@COOONMHEDDEEHED@@OOONML@@@@@@EC@@OOONMM@@
@@@@FA@@OOONMN@@@@@@GF@@OOONMO@@@@@@FE@@OOONN@@@@@@@B@@@OOONNA@@@@
@@DA@@OOONNB@@@@@@B@@@OOONNC@@@@@@GD@@OOONND@@@@@@FE@@OOONNE@@@@@@
GH@@OOONNF@@@@@@GD@@OOONNG@@@@@@B@@@OOONNH@@@@@@FI@@OOONNI@@@@@@FN
@@OOONNJ@@@@@@CJ@@OOONNL@@@@@@EC@@OOONNM@@@@@@FA@@OOONNN@@@@@@GF@@
OOONNO@@@@@@FE@@OOONO@@@@@@@B@@@OOONOA@@@@@@DB@@OOONOB@@@@@@B@@@OO
ONOC@@@@@@GD@@OOONOD@@@@@@FE@@OOONOE@@@@@@GH@@OOONOF@@@@@@GD@@OOON
OG@@@@@@B@@@OOONOH@@@@@@FI@@OOONOI@@@@@@FN@@OOONOJ@@@@@@CJ@@@@EJLH
@@@H@@@ADJFOOLO@DNEFOMKHDHNNCLOHOMKHBBFN@@@NA@AI@BD@@@OOCMD@OONDFG
@@@D@FDBFNOONLDBFNOONNDANNOMMLEBFNOONLC@BNOONLK@FNOONDFN@@@AMDA@AI
@L@@@@GNFN@@@ALB@L@@@@B@FM@@@AKJ@L@@@@DAFM@@@@HD@L@@@@EJFN@@@@GL@L
@@@@DBFF@FA@CL@@EFF@FN@L@@@@EDFF@L@LAA@@DHFGBLA@CL@@EGF@EL@L@@@@EC
FFA@@LAA@@DHFGAJFA@@@AFD@FD@@@DAF@DF@L@@@@EFFF@JFA@@@AED@FD@@@DKF@
CFCB@@NADHADCKA@DMEBFNOONLA@AI@L@@@@DAFM@@@AE@@L@@@@EJFN@@@ADHAB@@
MDCKA@CANC@B@BDB@@OOK@GKB@BFFF@@@ACDC@@BNB@HA@CK@@GF@L@@@@OOFG@@@A
BDEBFNOONNCBBNOONNAAH@A@@@F@@@OOCJDADADADHDADEDEDHDAEGEGDHEEDHDIDH
DAEIEEEGDEEIEDDHDDDHDADODIEIDCDHECDHDOEGDAEHEJDHDEEBDOEIDNDGEBFIFC
FHFAGBFDB@E@FAGEFLB@ECG@GBFAFGGEFE@@@@@N@K@B@@AB@A@F@@@@@@@@@D@M@@
@@AB@O@J@E@@@DAB@HAB@F@D@C@BBHBB@G@ABCBFBDACAG@IBE@LAE@H@EAIBIBGAM
OOOOOOOOOOOOOOOOOO@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@CHCGCFCECDCCCBCAC@
BOBN@@@@@@@@@@@@@@D@DADBDCDDDEDFDGDHDIDJDKDLDMDNDOE@EAEBECOOEFEEOO
OOOOBKCIBL@@@@@@OO@NOO@OOOABAAAOOOA@@MAJAKALOO@JOOB@AD@KOOAFBAOOAN
AH@@@@@@@@@@BHDCBIB@DCFOG@GIGBFIFGFHGDB@CACICHCDBLB@DFFIGBGCGDB@DB
GIGDFEEBFNOONLA@AI@L@@@@CIFN@J@D@@@@C@FM@DDHH@DNGEEHHOC@BNOONLF@@@
@BAJDBBNOONIEBFNOONNCBBNOONNDBC@A@@@G@@EI@FN@@@JNGD@AMD@OOODAMD@OO
OEDBBNOONFDBBNOONJDBDGC@BN@@@HCMD@OON@DEOJEENBAMGB@@@@OOMNBFGH@BFF
C@CL@BNBAGKL@@GO@@@@EED@FJOFMFOL@@ADCFCL@@@JAMGL@@GOOOONDBFNOOOHDB
CH@BF@@BCI@@OH@@NOOOON@HKI@@@G@@NONAONC@BN@@@LEBD@CMD@OOOJ@LD@@@@G
FO@L@DD@@@@GCMD@OOOHC@CL@@@GFA@@@AIJDBFNOOOLAMGL@@@AOONGCMGL@@@AOO
NLC@BNOONLDBDBDANNOMMLADC@@@@@AMDBOONH@L@B@@BJFLDJDBD@A@BNOONINID@
CB@@M@D@M@DAM@DBNCD@DKOJ@AHHCBCE@@@@DBBNOONCFA@@ACGLA@BNOONHM@@@@B
D@@@OODKOJEGFDCBCE@@@@EBBNOONCFA@@ACFBAMFNOONHOONIDBBNOONFF@@@@A@B
@L@B@@BNFLAN@D@B@@BJAMDBOONFF@@@@@O@NE@CEDNNOONF@@FN@@@COONIFEE@F@
@@ACG@@L@B@@CHFLAN@D@B@@BMIDBN@@@KNG@BAMDBOOODDJBNOONIFF@@@@LBAMDB
OOOEF@@@@@KJ@L@B@@D@FLCB@L@B@@CHFF@N@DBN@@@JOOODEKBNOOOEF@@@@@J@@F
BN@@@JOOODEJBNOOOEF@@@@@IB@L@B@@EAFG@JDDFNOONIFFLLFA@@ACAD@L@B@@DJ
FLBFDHHBMDFN@@@H@DDB@@DEFN@BDBDB@LDB@@@IFO@BGD@ICMDBOON@DEOJEDFNAM
GBB@@@OOMNF@ED@L@B@@EEFLCDCMFNOOOLOOOHDHHBMDFN@@@L@DDB@@DNFN@BGD@A
@LDB@@@GFOABCMDBOOOJ@DDB@@@GMDFNOOOLCMDBOOOHGD@GC@@BFA@@@@DDF@AJ@B
DB@@@ACMDBOOOLC@BNOOOJ@DD@@@@GFL@BDBD@MDD@CMDBOOOHEBFNOONLC@BNOONN
K@FNOONLFD@@ONI@DBD@DLNNCLOHOMKHDNENB@EOMOOL@@@@@@@JCNH@DNM@@B@@@@
@GK@CH@BF@FGB@EMLANC@AEB@AADCH@AFMKDCH@AFMFGOJMCCI@@NOOOONMCCH@BF@
K@CH@BF@FFNFDNGEOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOJ@EJJ@ALB@AOOOOOOOOMJ@AN@@AOOOOEN@BMJ@ANF@A@OOIOJ@EOB@A
OOOOOOOOOOOOOJ@E@@@FOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOON@A@D@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOA@@BEH@BOOOOEH@B
BH@BGF@EJJ@ACJ@BEH@BDL@BEH@BEH@BOJ@BEN@BG@@BGL@BHH@BNB@BJF@BKB@BOO
OOEH@BKH@BAN@COOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOON@AOOOO@D@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOA@@BEH@BOOOOEH@BBH@BGF
@EJJ@ACJ@BEH@BDL@BEH@BEH@BOJ@BEN@BG@@BGL@BCIOINB@BJF@BOD@BOOOOEH@B
JMOGAN@COOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON
@AOOOOOOOO@D@BOOOOOOOOOOOOOOOOOOOOOOOOEH@BEH@BOOOOEH@BBH@BGF@EJJ@A
CJ@BEH@BDL@BEH@BEH@BOJ@BEN@BG@@BGL@BLJ@BNB@BJF@BOD@BOOOOEH@BEB@HAN
@COOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON@AOOOO
OOOOOOOO@D@BOOOOOOOOOOOOOOOOOOOOEH@BEH@BOOOOEH@BBH@BGF@EJJ@ACJ@BEH
@BDL@BEH@BEH@BOJ@BEN@BG@@BGL@BCIOINB@BJF@BCF@COOOOEH@BDN@CAN@COOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON@AOOOOOOOOOO
OOOOOO@D@BOOOOOOOOOOOOOOOOEH@BEH@BOOOOEH@BMGOMHIOJJJ@ACJ@BEH@BDL@B
EH@BEH@BOJ@BEN@BG@@BGL@BCIOINB@BJF@BOOOOOOOOEH@BG@@HAN@COOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON@AOOOOOOOOOOOOOOOO
OOOO@D@BOOOOOOOOOOOOEH@BEH@BOOOOEH@BBH@BGF@EJJ@ACJ@BEH@BDL@BEH@BEH
@BOJ@BEN@BG@@BGL@BBD@CNB@BJF@BCF@COOOOEH@BDN@CAN@COOOOOOOOOOOO@D@B
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON@AOOOOOOOOOOOOOOOOOOOOOO
OO@D@BOOOOOOOOA@@BA@@BOOOOEH@BBH@BGF@EJJ@ACJ@BEH@BDL@BEH@BEH@BOJ@B
EN@BG@@BGL@BF@@CNB@BJF@BCF@COOOOEH@BDN@CAN@COOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON@AOOOOOOOOOOOOOOOOEH@BOOOOOOOO
@D@BOOOOEH@BEH@BOOOOEH@BBH@BGF@EJJ@ACJ@BEH@BDL@BEH@BEH@BOJ@BEN@BG@
@BGL@BF@@CNB@BJF@BCF@COOOOEH@BFL@CAN@COOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOON@AOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO@D
@BA@@BEH@BOOOOEH@BBH@BGF@EJJ@ACJ@BEH@BDL@BEH@BEH@BOJ@BEN@BG@@BGL@B
F@@CNB@BJF@BCF@COOOOEH@BFL@CAN@COOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOHJ@CLF@CIF@CIF@CLF@CLF@CLF@CLF@CLF@CLF@CCF@F
JH@CJH@CJH@CJH@CJH@CJH@CLF@CKD@CLF@CJH@CLF@CJH@CJH@CJH@CJH@CLF@CKD
@CKD@CLF@CLF@CLF@CLF@CLF@CLF@CLF@CLF@CLF@CLF@CLF@CLF@CLF@COOOOOOOO
OOOOOOOOOOOOOOOOMH@CCH@DCH@DCH@DCH@DNJ@CCH@DCH@DCH@DCH@DOL@CCF@FCF
@FOL@COL@COL@COL@COL@CAD@DOL@CMH@CMH@CMH@COL@CMH@CMH@CMH@COL@COL@C
OOOOMH@CMH@CCH@DBF@DCH@DCH@DCH@DCH@DCH@DCH@DCH@DCH@DOOOOOOOOOOOOOO
OOOOOOOOOODJ@DOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOOOOOOOOCF@FOOOO
OOOOGF@ECF@FCJ@BOOOOCF@FOOOOOOOOCF@FCF@FCF@FCF@FCF@FCF@FCF@FOOOOOO
OOOOOOOOOO@@@FOOOOOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOOOOOOOOOOOOOOOOOOOO
OOOOE@@DFB@DGD@DGD@DHF@DHF@DGD@DHF@DIH@DIH@DE@@DLB@DE@@DJJ@DE@@DK@
@DK@@DK@@DE@@DE@@DLB@DLB@DE@@DE@@DE@@DE@@DLN@DE@@DE@@DE@@DFB@DE@@D
HF@DLN@DE@@DGD@DGD@DFB@DHF@DIH@DGD@DHF@DOOOOOOOOOOOOOOOOOOOOOOOONF
@DCJ@ECJ@EBH@EBH@EBH@EBH@EBH@EOH@DOH@DCJ@EAF@ECJ@ECJ@E@J@ENF@DCJ@E
CJ@ECJ@ECJ@EAF@ECJ@EAF@ECJ@EAF@ECJ@ECJ@EAF@EAF@ECJ@ECJ@EAF@ECJ@EAF
@ECJ@EBH@ECJ@ECJ@ECJ@EOH@DBH@ECJ@EOOOOOOOOOOOOOOOOOOOOOOOODL@EFJ@E
FJ@EFJ@EFJ@EFJ@EFJ@EFJ@EFJ@EFJ@EFJ@EFJ@EDL@EDL@EDL@EGF@EDL@ECJ@BDL
@EDL@EDL@EDL@EDL@EDL@EDL@EDL@EFJ@EHB@EHB@EFJ@EFJ@EDL@EFJ@EID@EFJ@E
FJ@EFJ@EFJ@EFJ@EFJ@EFJ@EFJ@EOOOOOOOOOOOOOOOOOOOOOOOOON@AEJ@FEJ@FEJ
@FEJ@FEJ@FEJ@FEJ@FEJ@FEJ@FOOOOOOOOCF@FOOOOCF@FGF@EGF@ECJ@BOOOOOOOO
OOOOOOOOOOOOOOOOCF@FOOOOEJ@FCF@FCF@FOOOOEJ@FOOOOEJ@FEJ@FOOOOEJ@FEJ
@FEJ@FEJ@FEJ@FEJ@FEJ@FOOOOOOOOOOOOOOOOOOOOOOOOIJ@EKB@EKB@EKB@EKN@E
KN@EKN@EKN@ELJ@ELJ@ELJ@ELJ@EMF@EOOOOLJ@EMF@EMF@ECJ@BMF@EMF@EMF@EMF
@ELJ@EMF@ELJ@EMF@ELJ@ELJ@ELJ@ELJ@EKB@EMF@ELJ@ELJ@ELJ@EKB@EKB@EKB@E
LJ@ELJ@EKN@EKN@EOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOONB
@EOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOGF@EOOOOCJ@BOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOCF@FOOOOOOOOOOOOOOOO@@@FOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOD@ENH@ENH@ENH@ENH@ENH@ENH@E
NH@ENH@EOOOOOOOOOOOOCF@FOOOOGF@EOOOOCF@FCF@FOOOOOOOOOOOOOOOOOOOOOO
OOOOOOCF@FNN@ECF@FOOOOOOOOOOOOOD@E@@@FOOOONH@ENH@ENH@ENH@ENH@ENH@E
NH@EOOOOOOOOOOOOOOOOOOOOOOOOMJ@AOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ
@EMJ@AOOOOOOOOMJ@A@J@EGF@EOOOOCJ@BOOOOCF@FOOOOOOOOOOOOOOOOOOOOOOOO
OOOOEH@BCF@FOOOOOOOOOOOOOOOO@@@FOOOOOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOO
OOOOOOOOOOOOOOOOOOOOOON@@AOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOOOO
OOOOOOOOOOOOOOOOGF@EOOOOCJ@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOCF@FCF
@FCF@FOOOOOOOOOOOOOJ@E@@@FOOOOOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOJ@EOOOOOOOO
OOOOOOOOOOOOOOOOOOOO@L@F@L@FAH@F@L@FOOOOAH@F@L@FBD@FBD@FOOOOOOOOOO
OOOOOOOOOOGF@ECF@FCJ@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOC@@FCF@FCF@F
OOOOOOOOOOOOOOOO@@@FOOOOAH@F@L@F@L@FOOOOBD@FAH@FOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOCL@FCL@FCL@FCL@FCL@FCL@FCL@FCL@FCL@FOOOOOOOOOOOOOOOO
OOOOGF@EOOOOCJ@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOEH@BOOOOCF@FOOOOOO
OODH@FEH@B@@@FOOOOCL@FCL@FCL@FCL@FCL@FCL@FCL@FOOOOOOOOOOOOOOOOOOOO
OOOODN@FHOOMHOOMHOOMHOOMHOOMHOOMHOOMHOOMHOOMOOOOOOOOOOOOOOOOOOOOGF
@EOOOOCJ@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOHOOMHOOMHOOMHOOMHOOMHOOMHOOMOOOOOOOOOOOOOOOOOOOOOOOOON
@AEJ@FEJ@FEJ@FEJ@FEJ@FEJ@FEJ@FEJ@FEJ@FOOOOOOOOOOOOOOOOOOOOGB@FOOOO
CJ@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOCF@FOOOOOOOOOOOOOOOOOO
OOOOOOEJ@FEJ@FEJ@FEJ@FEJ@FEJ@FEJ@FOOOOOOOOOOOOOOOOOOOOOOOOGN@FI@@F
JN@FJN@FLF@FLF@FMB@FND@FND@FND@FEH@BEH@BO@@FEH@BOL@FAD@GJJ@ACJ@BGN
@FGN@FEH@BEH@BO@@FO@@FBL@GOOOOOOOOO@@FO@@FOOOOO@@FGN@FDD@GO@@FOOOO
MB@FJN@FI@@FE@@GND@FJN@FFB@GOOOOOOOOOOOOOOOOOOOOOOOOH@@GFN@GFN@GFN
@GGD@GFN@GGD@GFN@GGD@GGD@GEH@BH@@GOOOOH@@GOOOOGF@EOOOOCJ@BH@@GH@@G
H@@GH@@GOOOOH@@GEH@BOOOOH@@GOOOOH@@GOOOOH@@GH@@GH@@GH@@GOOOOGD@GFN
@GFN@GGD@GGD@GFN@GFN@GOOOOOOOOOOOOOOOOOOOOOOOOON@AOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOEH@BEH@BOOOOOOOOHL@GGF@EOOOOIB@GOOOOIN@GOOOOEH
@BOOOOOOOOEH@BIB@GJJ@GOOOOOOOOOOOOLB@GOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOLH@GOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOEH@BOOOOMD@GOOOON@@GOOOOOOOOOOOOOOOOOOOO
OOOOEH@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOONL@GNL@GNL@GNL@GNL@GNL@GNL@G
OH@GOH@GEH@BEH@BOOOOOOOOOOOOEH@BOOOOCJ@BOOOODL@BOOOOOOOOOOOOOOOOOO
OOEH@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOONL@GNL@GOOOOA@@HOOOONL@G
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOBB@HBN@HBN@HCJ@HCJ@HCJ@HDF@HDF@HDF
@HOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
DF@HOOOOOOOOOOOOBB@HOOOOBN@HOOOOOOOOCJ@HBN@HBB@HDF@HDF@HCJ@HBN@HOO
OOOOOOOOOOOOOOOOOOOOOOON@ADGOMEB@HEB@HKAOLG@@HKAOLKAOLGF@HGF@HEH@B
EH@BOOOOEH@BBH@BEH@BJJ@ACJ@BEH@BDL@BOOOOOOOOOJ@BOOOOOOOOEH@BOOOOOO
OOOOOOOOOOHN@HOOOOOOOOOOOOOOOOKAOLEB@HKB@HM@@HGF@HKAOLOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOML@HML@HML@HOD@HML@HOD@HML@HOD@HOD@HOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOEH@BOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOD@HML@HML@HOD@HOD@HML@H@F@IOOOOOOOOOOOOOO
OOOOOOOOOOOOOOAH@IAH@IAH@IAH@IAH@IAH@IAH@IAH@IAH@IOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOAH@IAH@IAH@IAH@IAH@IAH@IAH@IOOOOOOOOOOOOOOOOOOOO
OOOOON@AOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOEH@BEH@BOOOOEH@BBH@BGF
@EJJ@ACJ@BEH@BDL@BEH@BEH@BOJ@BEN@BG@@BGL@BHH@BNB@BJF@BOOOOOOOOEH@B
DMOGAN@COOOO@D@BOOOO@D@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON
@AOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOA@@BEH@BOOOOEH@BBH@BGF@EJJ@A
CJ@BEH@BDL@BEH@BEH@BOJ@BEN@BG@@BGL@BHH@BNB@BJF@BOOOOOOOOEH@BKH@BAN
@COOOOOOOO@D@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON@AOOOO
OOOOAN@IOOOOOOOOOOOOOOOOOOOOOOOOEH@BEH@BEH@BEH@BBH@BGF@EJJ@ACJ@BEH
@BDL@BEH@BEH@BOJ@BEN@BG@@BGL@BHH@BNB@BJF@BOOOOOOOOEH@BDMOGAN@COOOO
OOOOOOOO@D@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON@ABD@IOOOOOO
OOOOOOCF@IOOOOOOOOOOOOOOOOA@@BEH@BOOOOEH@BBH@BGF@EJJ@ACJ@BEH@BDL@B
EH@BEH@BOJ@BEN@BG@@BGL@BF@@COOOOJF@BOOOOOOOOEH@BCL@IAN@COOOOOOOOOO
OOCF@I@D@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON@AOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOA@@BEH@BOOOOEH@BBH@BGF@EJJ@ACJ@BEH@BDL@BEH@BEH
@BOJ@BEN@BG@@BGL@BHH@BNB@BJF@BOOOOOOOOEH@BKH@BAN@COOOOOOOOOOOOOOOO
OOOO@D@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON@AOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOA@@BEH@BOOOOEH@BBH@BGF@EJJ@ACJ@BEH@BDL@BEH@BEH@BOJ@B
EN@BG@@BGL@BOOOONB@BJF@BOOOOOOOOEH@BCL@IAN@COOOOOOOOOOOOOOOOOOOOOO
OO@D@BCL@IOOOOOOOOOOOOOOOOOOOOOOOOON@AKB@HEB@HEB@HKAOLHOOGKAOLKAOL
GF@HGF@HA@@BEH@BOOOOEH@BBH@BGF@EJJ@ACJ@BEH@BDL@BEH@BEH@BOJ@BEN@BG@
@BGL@BDH@INB@BJF@BOOOOHN@HEH@BOOOOAN@COOOOKAOLEB@HKB@HM@@HGF@HKAOL
@D@BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON@EI@LDA
OOOOFGBBDJDAFKAFFAANF@AJDCOJDCNDCBBI@@@BNBEAFDNDFA@@@@BBFG@J@JDAOO
OOFA@@@@CLDNGEDEOKA@E@COBJ@@@DFA@@COMHCBAON@EIFJNNDNGECBCL@@D@CD@A
COBI@@@HDAOKA@CEFKMLDCOJDBCBAMKAA@@@A@MLEALIOOOHFA@@DCGLDNGEDEOKA@
AHCDBJ@@@DN@EJFK@HBO@JCB@BFANNBDEOFA@@COIDDNGEEM@IFH@HOOOODL@@FHLH
OOOOJC@FFHLFOOOOOF@BFHLHOOOOJMBKFHLFOOOOEM@AFHLDOOOOHO@DFHLJOOOOJA
@IFHLHOOOOAABNFHLBCF@@EEBNFHLCCL@@IIBNFHLDDB@@BK@GFHLDOOOONE@IFHLF
OOOOOHCEFHLDED@@EM@IFH@DEJ@@BI@JL@@@OOOOOA@NFJHAFF@@CF@OFLHBFL@@OA
@NFJHAOOOOMC@DO@@@OOOOOG@GHL@@OOOOI@@@O@@@OOOOII@JNF@@OOOO@OCAG@HA
I@@@EGCAFNHAIF@@INCAFLHAIL@@NDCAFLHAJB@@BJCBFLHAJH@@G@CBFJHAJN@@KE
CBFHLAOOOOOB@MGHHAKJ@@HFAEGHHAL@@@KBADGHHALF@@HFAEGHHALL@@OB@MGHHA
OOOO@HAMFLHAMH@@BDADFNHAMN@@FKADFNHAND@@BDADFNHANJ@@@HAMFLHAOOOOOA
@NFJHAOF@@CF@OFLHAOL@@OA@NFJHAOOOO@G@DFHLDOOOOCJ@CFJLFOOOOJA@AFHHH
OOOOAL@KFHLHOOOOF@@KFHLBOOOONG@FFHLDOOOOEO@FFHLFOOOOEMCEOB@@OOOODM
@HFHLDCH@AIA@HFHLDCN@AME@HFHLDDD@AAI@IFHLDOOOOJD@KFHLFE@@ANH@KFHLF
EF@AHLA@FHLFOOOOKC@GFHLHOOOOBL@LFHLJOOOONE@IFHLDFN@ACAC@FHLCGD@AGE
C@FHLCGJ@AGJBEFHLCH@@AKNBEFHLDOOOOOF@BFHLDHL@ANB@LFHLDIB@ABF@MFHLD
IH@AFJ@MFHLDIN@AJN@MFHLDOOOOG@@LFHLJOOOOOHCEFHLCK@@AABBAFLLEKF@AOH
CEFHLCKL@AEHBAGO@AOOOOOHCEFHLALH@ANE@AGDLCLN@AOHCEFHLCMD@AEM@IFH@A
OOOOHIB@FJ@@OOOODJABLH@@OOOONFCE@CLANL@ADK@DFHLCOOOOOHCEFHLAOH@AJA
@AFHHDOOOOOHCEFHLGOOOOOHCEFHLC@J@BEM@IFH@DOOOODHA@FHHAAF@BM@A@FHHA
AL@BANAFFHHABB@BEM@IFH@AOOOOOHCEFHLCBN@BKIC@@C@ACD@BKNABGBLAOOOOOH
CEFHLCD@@BKIC@@C@ADF@BNE@AGDLEOOOOOHCEFHLCEB@BEM@IFH@DOOOOOHCEFHLC
OOOOOHCEFHLBFD@BMBAEGHLAFJ@B@@@@GHLAOOOOAH@AFJLAGF@BLBALFLLAOOOODK
@DFHLCHB@BJL@NFJHAOOOOCFBEFHLAHN@BOBBDFHLAID@BJNBDFHLAIJ@BFJBDFHLA
J@@BBFBDFHLAOOOODBAEFHLAJL@BONADFHLAOOOOKC@GFHLDOOOOGL@OFHLAKN@BL@
@OFHLALD@B@DA@FHLAOOOOIOBIFHLBM@@BNCBIFHLBMF@BBGBJFHLBML@BFKBJFHLB
OOOOFBAFFHLANH@BJFAFFHLANN@BNJAFFHLAOOOODL@@FHLDOOOOOJAGFHLA@@@CCN
AHFHLA@F@CFO@GFHLA@L@C@GACFHLAAB@CDKACFHLAAH@CLKC@FHLAOOOOEO@FFHLB
OOOODKBHFHLBBJ@C@GBHFHLBC@@CLCBGFHLBOOOOHOBHFHLACL@CMCBHFHLADB@CAG
BIFHLADH@CEKBIFHLAOOOOHBAHFHLBED@CLFAHFHLBEJ@C@JAIFHLBOOOOLMBMFHLB
FF@CHIBMFHLBOOOOKBAKFHLAGB@COFAKFHLAGH@CCJALFHLAGN@CGNALFHLAHD@CNG
@FFHLDOOOOEM@IFH@DI@@CGO@CO@@AOOOOEM@IFH@DIL@CGO@CO@@AJB@CEIBCO@@A
OOOOEM@IFH@HJN@CKD@LCL@AOOOOEM@IFH@HKJ@CGO@CO@@AL@@CEM@IFH@FOOOOEM
@IFH@DLL@CGO@CO@@AMB@COHCEFHLAOOOOOHCEFHLDMN@CEM@IFH@DND@CEJANFD@A
OOOOEM@IFH@DO@@CA@AOFD@AOF@CEM@IFH@DOOOOOHCEFHLD@B@DEM@IFH@D@H@DA@
AOFD@A@N@DEM@IFH@HOOOOEM@IFH@HAJ@DEJANFD@AB@@DEM@IFH@HOOOOEM@IFH@H
BL@DEK@EMH@ACB@DMG@EO@@AOOOOEM@IFH@HCN@DILANLH@ADD@DEM@IFH@DOOOOIF
AOI@@@OOOOEM@IFH@HEF@DNNAOHN@AEL@DEM@IFH@DOOOOEM@IFH@DFH@DMCACHB@A
FN@DADAAKD@AOOOOEM@IFH@DGJ@DMCACHB@AH@@DEIBCO@@AOOOOEM@IFH@DHL@DNN
AOHN@AIB@DMABBO@@AOOOOEM@IFH@DIN@DNNAOHN@AJD@DJOBJLL@AOOOOOHCEFHLH
OOOOEM@IFH@DKF@DNNAOHN@AKL@DEM@IFH@DOOOOEM@IFH@DLH@DNNAOHN@AOOOOEM
@IFH@HMD@DMFAMNH@AMJ@DJOBJLL@AN@@DOHCEFHLAOOOOKNABGBLDNL@DOHCEFHLC
OB@DHOACFH@AOOOOOHCEFHLAON@DKNABGBLC@D@ECN@NKL@AOOOOKNABGBLDA@@EOH
CEFHLCOOOOKNABGBLDAL@EHOACFH@ABB@EEM@IFH@AOOOOOHCEFHLABN@EKNABGBLC
CD@ECN@NKL@AOOOOOHCEFHLAD@@EKNABGBLCDF@EHOACFH@AOOOOABBAFLLAEB@EOH
CEFHLBEH@EEHBAGO@AEN@EABBAFLLAFD@EOHCEFHLCOOOOEHBAGO@AG@@ENFCE@CLA
OOOOOHCEFHLDGL@EABBAFLLDOOOOEM@IFH@DHH@EABBAFLLDHN@EEM@IFH@DOOOOGD
BBIJ@AOOOO@BBFCA@AJ@@EOHCEFHLAJF@ENE@AGDLEJL@EOHCEFHLCOOOOBO@BDF@A
KH@EBNAGFH@AOOOO@BBFCA@ALD@ENFCE@CLAOOOOJD@BHD@AM@@EOHCEFHLAOOOO@B
BFCA@AML@EEM@IFH@DOOOONE@IFHLAOOOO@FABFH@AOOOOOHCEFHLHOOOO@FABFH@A
OOOONFCE@CLAOOOOOHCEFHLA@F@FEO@FFHLCOOOOMC@DO@@AAB@FJHBAFHLAOOOOMC
@DO@@AAN@FNLBAFHLAOOOOMC@DO@@ABJ@FC@BBFHLAOOOOGOBGFHLDOOOOEM@IFH@D
OOOO@@@@GHLADB@FMBAEGHLAOOOOEM@IFH@DOOOOOHCEFHLCED@FHIB@FJ@@OOOOJL
@NFJHAF@@FDK@DFHLAFF@FKIC@@C@AFL@FNFCE@CLAOOOOOHCEFHLCGH@FEM@IFH@C
OOOOGNAAFHLDHD@FLBAAFHLDHJ@FOHCEFHLCOOOOBFBDFHLAIF@FFJBDFHLAIL@FJN
BDFHLAJB@FOBBDFHLAJH@FCFBEFHLAOOOOFKBJFHLBKD@FBGBJFHLBKJ@FNCBIFHLB
L@@FIOBIFHLBOOOOGBAGFHLDLL@FKFAGFHLDOOOOLCBGFHLAMH@F@GBHFHLAMN@FDK
BHFHLAOOOOHIBMFHLBNJ@FLMBMFHLBOOOOGNAAFHLAOF@FLBAAFHLAOOOOGNAAFHLA
@B@GLBAAFHLA@H@GOHCEFHLC@N@GKNABGBLDOOOOGNAAFHLAAJ@GLBAAFHLAB@@GOH
CEFHLDBF@GABBAFLLDOOOOGNAAFHLBCB@GLBAAFHLBCH@GAH@AFJLACN@GLBALFLLA
OOOO@G@DFHLDDJ@GNG@FFHLDOOOOEBAOFHHAEF@GDEB@FHHAEL@GLNB@FHHAOOOO@G
@DFHLDFH@GG@@LFHLDOOOOFB@BFDHAOOOONABCFJHAGJ@GBKBFFHHAOOOOCJ@CFJLD
HF@GOHCEFHLCOOOOJA@AFHHDOOOOJA@AFHHHIH@GNE@AGDLHOOOOJA@AFHHDJD@GOH
CEFHLCOOOOFOBFFHLAK@@GKCBFFHLAKF@GOGBFFHLAKL@GCKBGFHLAOOOOF@@KFHLD
OOOOAL@KFHLHLN@GOHCEFHLGOOOOAL@KFHLDMJ@GOHCEFHLCOOOOAL@KFHLHNF@GNE
@AGDLHOOOOBEBKFHLBOB@GFIBKFHLBOOOOKNBEFHLBON@GGJBEFHLB@D@HGEC@FHLA
@J@HCAC@FHLAOOOOIACDFHLBAF@HMECDFHLBAL@HAICEFHLBOOOOADAAKD@@BH@HNF
CE@CLAOOOOEIBCO@@@CD@HNFCE@CLAOOOOMABBO@@@D@@HNFCE@CLAOOOOMABBO@@@
DL@HNFCE@CLAOOOODNAIFHLAEH@HIBAIFHLAEN@HMFAIFHLAFD@HAJAJFHLAFJ@HEN
AJFHLAOOOO@JAIFHLBOOOOGNALFHLAGL@HCJALFHLAHB@HOFAKFHLAHH@HKBAKFHLA
OOOOOICBFHLAID@HCMCCFHLAIJ@HHACCFHLAJ@@HLECCFHLAJF@H@ICDFHLAJL@HDM
CDFHLAOOOO@DA@FHLAKH@HL@@OFHLAKN@HGL@OFHLALD@HDNAMFHLALJ@HIBAMFHLA
OOOOMMBNFHLBMF@HBABOFHHBOOOOJBAJFHLANB@HNFAJFHLANH@HBJAKFHLANN@HFN
AKFHLAOOOOKMBLFHLAOJ@H@ABMFHLA@@@IDEBMFHLAOOOOOABKFHLA@L@ICEBLFHLA
AB@IGIBLFHLAOOOOEO@FFHLAOOOOF@@KFHLDOOOOFEBOFHLABJ@IJIBOFHLAC@@INM
BOFHLAOOOOEO@FFHLDOOOOBABOFHHBDB@IMMBNFHLBOOOOOHCEFHLDDN@I@G@DFHLB
OOOOODOEOFOKOLOMONOO@@@A@B@C@D@F@G@JBOIGFKFIHGIHFILDGJHIEIJGEJJGNI
CHHFFJJLGDGFFIGKJGCIFJGHMHEIGIIGGLHEHHGJFIJHFGHIHGIIGGIGIHGIHGHGIH
IHIGGIGHIHELHDKHGIHHHHHHKFM@N@O@OHOLONOO@@@A@B@D@HA@B@D@CLJLIDKEKJ
HGHEJKIEEJHJHEFKGGHEKNNB@NOCDFAMNDBMMALMLFEBMNMBDMLLKCEMDDFLLCCKKM
DCIMFELHDJLIJJDEELKGECLMGDDHIHJ@KCLDMHNDNNOG@@@IADALBHCHDGEHIEKGHG
JHDMEEMEFKHFHLCLICMHDLFGIJFENBKM@NGELEJEJJCNCINALKCLIEHLEDNFCODELI
CMGELEHIHGJFHIGJEIKCMGDMDHLDJFIJDKHGIHFIIGHIGIFKEKEHLCLKBMHDKIGELG
ELFGJGGHKDJJCNDHKDKGFMCILEFLFFLDHLEGKFHHIGHIGHJDLEJGGJDNCHMBMFGKDL
EJICNDGMBMICLJDHMBLKBNEGKDLGFHJGGJEKLCMDN@O@OHOJONOO@@@A@B@D@HAEB@
CECMDLDFMAOBCO@OCBOAMLBNCKLDKELEKGELGHIEKFFIIGGIFFJGGLDHLDGLDLKCMC
JLCMCLFEMBMFCNANLAOBDNBLNANDCMCKLELCLMANJBNNOAOCOFOJOLONOO@@@A@C@F
@I@L@NA@CLGFIIGJFFGJGIJIGJHEHJFGJFFGIMMCCLH@HNDJLAALHBLOCFJDFLLFKJ
EFDHKJEFEDFIGJJFGIHGJJJJGFGHFIHGFFEJFGJJGIHHGJOHOIOJOKOLOMONOO@@@A
@B@C@D@E@F@GFJHGIFHGIHHFHIHHGGJJFIHHJFGJHIKNHBHNIFDJLIDGJGGEFHHEFI
KHFGGIGIHIIGJFHHGIGHHJHHHGIHHGHIIGIGIIGHHHGIHHIGIHOGOHOIOJOKOLOMON
OO@@@A@B@C@D@G@I@OIIIIJHIIHJIIHJHJHIJHIIIJHKHHJIJJHIJHKHJHIIIIIIHJ
GJIHJGJIHIIIIIIIIIHIKHIIIIIJHIJIHJIHJIIIIHKHHJIIIIIIIIIIIIIJHIIIII
L@MONJO@OEOLONOO@@@A@B@D@HA@AOC@IHGHILICCOCAMELNAFLDMGDKIKLCKKDMEE
IEELKEFEFLKEFFHLEEEKKLDEJLHGEFJJGFGKNOO@OAOBOHOKONOO@@@A@B@D@E@G@L
@OFHFJGGHHGGIJHGIHGGJIHHIJFKONC@IKKJHEGMIBEMMIDEHFKMGEKKDDMMHGFFEK
LFEJMDELKIIGEENJEFKKDFKJIIFFFKIEKFFGNOOBOGOHOJOKONOO@@@A@B@D@G@J@L
ABIHHLL@@LKLOBCJCCMLIKDDIIFLIFGFELGJJDFJHJKEIGGIJGIJEIHHIJGHGGHIIG
IGIFIHIHGHGHJGHIGHGJFJHGHIFIIGIGHIKKE@KKKNECJFELJGKDFKIFHGHKFFIFIK
EIKIKNNHO@OHOLONOO@@@A@B@D@HA@ACBMDHKFIJJKJEEIFHJHGFKLEFEGLDDDMOOC
ACCCNLLNIBKNMDDDFECFLNJDEKKKKKDEDDHLIKGGGGKKLEJEDJJCFNEEJEMIGEEEDH
LHKFFKO@OHOIOJOKOLOMONOO@@@A@B@C@D@E@HDNIIHIHJHIHJIHIHIJJJHHJIIJII
IIJNNFCLJHMIDMLHGEHLGFIJIIGGIIKHGJLHIIGJIIIIJJHHHJIJHJIJHIIIJIIIIJ
IHIJIHJIHJIHMON@NNO@OHOMONOO@@@A@B@D@H@MAIB@GKLL@BOMCLLBCNKDKLBIJE
LDLLGDDKFJKJFEHIFKKDKHHGIIFFIGHJHIHIFFIHHIGJGHHGHJHHGGIFJHHFJJHGGH
HGHHHIIIHFFGIKGHHGIHFHIIFJGHJGGGFKHHGGIGHKEIGHIFIHHGHKEHKFFFFGKKKD
KGEDLHFKJIGHEDKKJGEKKFFEEEGLKJGEGGFGHJJFHJJGHGFEIJHIKIEEFGHKKHEGGH
HHGIHIIJHEEIJJGHEIJFOEOFOGOHOIOKONOO@@@A@B@D@E@F@G@HBNGHIGHIGHHHII
IIJHHHGFGHFFIKMOFLOCAKA@GKFHNJGGHFDHJGKOKJMIFEHEDHFFJJIJGIFFIHILJI
IKEFJEFFIHFIJGGJHGIJIGJHNCNLOAOCOIOLONOO@@@A@C@E@I@JAAANANKFN@LGGN
FAENMFCANOAAMLKDDDNNAFDLKFFJIFCJLJHCFIKKEEFKJDJJIKDGIJKHFDFJKJEDDL
JFFFIKDGKKJDDKLDGKKCJHFMHEECLFM@MNOBOHOKONOO@@@A@C@E@HA@AJBODJFJJG
JHJEGFHJFJHJEELFEKIEKDMOEANK@CLEMNKLMDBIEICLNFELEDEGFMJDLJCDKGFKLJ
DLECLICMKDILEFIFFLEELIDJKEKHFGHEO@OAOBOEOHOJOLOO@@@A@C@D@G@I@LA@FL
IDGLGGKHFFGIMJBHMJEFGGMMCEIKJJECNGJJFGFHFJMJDFLFJGDHOH@KHILJDELDJM
JEFHGFMKFFLHCGKKKGEHKGEGMLAKKDKMCHMEEMGFIGILFEGMGFJDJMHDGIIHJIFFMG
DKGILHDHJFGKHKGFLCHJJIFJIFLEFLGFLGFGKEKLALKGIDJHLFDMIFKIEEMJEJLCFL
KCMLBILGFFODEKHFLGFJIGEJGLJBMJDHKELLCGIHNLNMNNOCOHOKOMOO@@@A@B@E@H
@NA@AEGKJDDILLLCDFKLHHGIDEKJKJFFHGGKFIKFEGIJLGFIIDCINMGF@@ONKDCIKL
ICHKMFCEEMLIDDGKLGFEGKJEEJJKKDHIHGHKEGKKDFJJJFDLKEJGDJKJGELIDGGKLE
JFEIIIJFGLDFJKGFIKFGJFHIIJEHJJHEHKFJKDFLFEKJHGJFGHEINDELGDDKLGKFHE
GHFILIGKGDDIKJKHHJFDFHLJOGOHOIOJOKOLONOO@@@A@B@C@D@E@F@IFMFFJEJJAN
OBHKFCIJFINIEHICDMMGMIFFFCFINOICCHHIHGMMEEHIFIKFFJHGKJFEGHGKLHIGFB
KKGKIEKFGGIJEINHGFBJLIIHFHKCGHNMDFHGEMFEOO@DFFKOGAJHHLHCGNJDFHJKKF
DLFDKHHKLGGFDIGLGIKGIHCHHHKIJGFIFHIGGKHJGEHJIHFFHJNEFJJEFGKNIEDFIN
GIFGJGIGDJLHHKFDLKBHMGFJKCGJHIIIM@N@NOOHOIOLONOO@@@A@B@C@D@OA@B@BM
IHIHHHHHGIHHHHGIHGIGHHHJIHKKGHJHFFHFFGFHFGIGGJGHIIHHJHIIIIHIHIGHGH
FHGFHGHGIGJHHJHHHHIGHHHHIGHHHGHIHFIIKEMBN@O@OHOLONOO@@@A@B@D@HA@B@
D@CLLIDJKKEJHHGEFLKDEELLGCLKEEFLON@@NOBCLFMC@NOMBBKNLBMNMAANNLBDLH
ECLNLBCLNDGKHEDDDNDCJJIKEFLKDGJIKFDLKDHFNOO@OAOCOJOLONOO@@@A@B@D@F
@K@OAA@NHIIIHFHGHGIGJGHGIIIHIIGGFGJLOLKCABFLOMJCA@DLOMKECDEKMMLKED
EFIKKIIDDCJFKLKFFDFJLKKJHFFFHIKFHFDGGIJJHGFHNDNOO@OEOGOKONOO@@@A@B
@D@H@M@OAEHJIFEHGEFKEKKJHKKHGHIEIGFEKGMMKDMN@ALDAGGHLIKILHEDKHHELN
KFMHFEEDDEDEKHLFLLKEJKEGKLJDKMBBNDAKKEKLJHLKDHLENNOFOGOHOKOMONOO@@
@A@B@C@E@F@H@O@OIIHGIHGKEKHFJGIIGHGIFIFFLLMEGNCCKFHIIGIFCFJIFJLIFH
HIHIIKLDGIGDGKIJEELEANJELHFLDEKKEHJGIEFJIHGIKEHHHJFGM@MJNAO@OGOLON
OO@@@A@C@D@HAAB@BNJDKIGFEJJHEELJFDLKGFJFGLDILDKNCALOEBIHMLCANMCCIJ
JFDJLDDMLEDKLLJCJLMCEFLGFEGHFGHFFIFELJCLLFFJEJLDJIJEHJFFNHOBOCOFOI
OKONOO@@@A@B@D@H@M@NACGJKFDJJFFKHIFJIFFKKDIJFEKHHHHKEJHIHFHJHFHKEK
FIGHGHHGJJFFKGEJKIEKKDFIGIGKLFCHIEEMLFCLFEHFKKGCML@HODCLLHBFNECIMI
CHMDBLKJDGMECJLEFHLFEFKJEFLHEGJEMMN@NFO@OFOJOM@@@C@F@JACAMBMCLFKDK
JFGIIGEIKIGHIHFFIKGDLFDKKGLOH@KM@DOGNLEFFCALMGFJLBEKGJMEIKDCIJEKKK
GFHGEKHGKFEKFFIKIHHHFGJEIJFIKFHIGHL@M@MNO@OHOLONOO@@@A@B@D@HA@AEBJ
FGIFKFEGJJKILDDIFEKKILDELFDKLLOO@AJCBNOLODACNFENMCBDFMNMCMCDCMLKLC
CHKFKNFEFDDLKFIJEDLLEFJDKIEKLEEIHJHIFEM@MGNCOAOHOLONOO@@@A@B@D@HA@
ADBLFFFKEHILFGFDLKGFFGFEKLLDHEELGKOLAAMKLNBCNFCLNFFECKMIEGJDDLILFE
DKKIFKHDLGEKJEEJHFKGIJFEHLEFHFILEEIKGIEJIFMCMLNCOCOHOIONOO@@@A@B@D
@HA@AKBDCLJLFDKHFIFKEIIGKKFEKKKHDFLFIMNB@NOCECBONACJLJJFCHLEMMBEML
LFCDLMFCFFKKEKEKFFLKCGKLIEFGLFHGFFJJJGEJKIJFDKL@M@N@O@OHOLONOO@@@A
@B@D@HA@B@D@HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHNLNMNNOAOIOLONOO
@@@A@B@D@G@JABADDKGIJHFFDJGIKLKGJGEHKGJONB@JJCEKLLKCCDKFHMMLGDDKLJ
LLLFECEFKGGJHDDDHKMJKKIEJJFJMHEEFDEJFFLEEFIHHLKIKGEIIININJNNOCOIOL
OMOO@@@A@B@D@H@K@LAABNHIIIGIJHJIGJIFHJFFJGDKGGKONDMNE@DGBBKGGKMLKL
IEGGDIIKKKJKJDDEDCFIIKLLKLLEGHEDEHEEJKDKKGHIJHIIHJGGGHGEIIINKELHML
NHO@OFOH@A@E@JA@AIBID@FBHFLDEMKBGMKDGHHKEDMLBEMLCFKGKGGGLKBKMDEHLG
FGJJJCILEMBDNJCDLMCCMGKGFELJDJJFDKLFHDHLGHJFCKMGDEIMIBKLJBLNAEMMAF
OBDGLMCFFKIIKCDMLFAMNCCJLEKGCINIAGNGDIJEIJHHCLMBFMLBDNKBFMKCCNJBLE
LJEEFMIDCLNBDKLKCDMHMLNENLOEOLONOO@@@A@C@G@HA@AKCCFMCDMKKECCOFBIHN
EAKMMDCENMADNEKCFOAAMOCCDMKMCANOAAMNDEMCBOICBNMCKGFCNMAENKCDMJDMIA
MNDDDNECLMCLMALNJCDHMN@DNKCILJJDCNMDBMLCMMF@MLENCFBLOCCEKGMJBJMEJC
MLICFMKJCDHNNAANNDCMFCNLBKKDMDJJDDNM@MJCMKJDDMEHKEDGLMDDDNM@HNDKDD
LNDBJMMDDFELMECHOHOIOJOKOLOMONOO@@@A@B@C@D@E@F@GBLHGIIGGHJFIFKHGHH
JGGGHJLNH@JLKGAFOKFCHJIDDHJHEFKKHEHGIJFIHIHHHFHHIGHGJHHHHIIGFHHIIG
HIIHGHHHHGIIGHHIGHGHNCNDNIO@OFOJOMOO@@@A@C@E@I@NACB@DLFDLLHDELLGEE
KLEFJIFGJFKLLBCONADLGML@CNNCDGGJKDFLGDKLKDHJLKFDIMHEEJJJEGFHJGHGDI
MEFGEKMECMGIKFDLJGFIGFKIICNGNKO@OHOLONOO@@@A@B@D@HA@BAD@FFIEIMCDHL
LDGFLLDILFJEHEHKEHGLNN@DOMCCCDNEAKMBDMMDBKMMJBFMLEEGFEEHKIDCLLHHFG
LLHLCCNCLKCFLEFJDEILKEGEKMDIJINANNO@OHOLONOO@@@A@B@F@JACAKCECLJLKF
CJFFLEDFELLEDFLKKFBLJELFBMOE@DONCAANNDAGMDCMLDBFNMFAFMMJCEDLFFGFCG
KLEDDLLKFEKJFEKLCEGLJDCHLJJEDJKKOAOBOEOIOJOLOMONOO@@@A@B@D@G@J@KMC
JGHGGGGIKLIIKGHJJKLILHEIHGMNOE@JKBGMHMMCAEFEFMKKKHCEKLKLNKJGGFJLHK
MKCEEDHKGJLFEFFJJKLLHKGHJKLJKLFFHFGJNJNLNOOCOHOKONOO@@@A@B@D@H@JAB
AFBKLMIIEDFJKKJEFEGKKLEHEEKJLKLMHCCDGMOJDA@EKNNFCADJNNMHCDELMMKDDC
GJKKIEEDHIKLKHEGFILLIEEEFILGHEEHHKHJGGHHO@OAOBODOGOLOMOO@@@A@D@E@H
@M@OA@GIIHKEANIFKFCLLGDELOA@NLBJJGFJHEFLHFHJECOKDDJMEDIKGGIIGHGIKD
MENINJOEOIOLOMOO@@@A@C@E@H@NAIAOCKJGIHGKGHIGEJGHGFJIJIJDHGGJLNMCCC
@HKEMOLEFDAGKJKMDEEDEHLLKLFDDDFIKLJJDFGFJJHKFDGEHKKIKFGDGIGHKIIHGG
GIHGNNOCODOEOHOKOMOO@@@A@B@E@G@J@LABANGGGGHIJJHGJHGGGHFJJGHKFGIJNM
FGLD@FCCJMHLOJFGGCEFEJMKGLHFFEEGHKGKKKFFEFHFGJJJKFIGFGFIJHJJIIFGHG
GJHIIHHGNOOFOIOJOKOLOMONOO@@@A@B@C@F@I@M@OIHIKJJJLIHGIGHIILIKIIIFI
MMFLNFEHDAHGCHMLGMLIFHGFJIKKMJKIJEEFGEJKKJLLIGIGGHHILKGKJGHHHHIJJI
LIHKHGHKHJHKOAOIOJOKOLOMONOO@@@A@B@C@D@E@F@N@OGGGHIJGJIGHHGGHIJGJI
GFJFFKNKGLLDDGCBGHFFNJEHJEDGIHHNLIKLFFGHDFIIHHIHHEEHEHKHHMIGHHHEGI
HHJIGHIFGHHHHIJHO@OGOIOJOKOLOMONOO@@@A@B@C@D@I@OANGLGKHFMHGJKGJHIK
IFKIGJJILLJBMIFHKJMFEJIFHILLEFJJHHKLJFJIIIHJLGHHKGIIJLFHKHHJIJJFJJ
HIJGHKGJKGJHIKGIIJHJIGLJCMHKHIIHJHIKNCNDO@ODOHOLONOO@@@A@B@G@H@NAF
AGEKIEDLJFFIIHIFFIJHIIFIIGHHHFHJJFIHHFGHGJIHHHGHHIGGIHIGHHGJFHHIIH
FIHFGIIIGGIJFGHIIHGIHHGFJIGGIIGGHHJHFIGGFHJJJEKEEFHKOMDILB@CDFJKKM
LECFJICMMLJIFECBDJJJJMHJGGIEJJJKIEEHECHHGKFILHFJIGGHHJIDJHMKNFNJOA
OHOKONOO@@@A@C@E@HA@ALB@CMLBLLHMBBOLBGMDGLDDINCCKFMEDLIEHKEJIHFJDG
LKDFFFILFDIKGFFILHDKFGLJDEGLKEDFLJFDFLHDLHELEIGFLGEIHKJCHMKAJMGKM@
MMNJO@OHOLONOO@@@A@B@D@H@OAJBCDCNNCALNGFCFJLOABLNIIALNDLBCOKEDCKMM
CBMMICEJMFDDILLDDGMDEJLEDLHKEEKKDIGJLEDELJKDEHLLCIKKMBDKMMBBNKKBLL
FDGLM@MCN@O@OHOLONOO@@@A@B@D@H@LAHC@CNCLMCKGDNCDMLCFLKLBMMMCCMLLCC
NMDCDMNCEDKKKHDFLLCDMKLDCKMLCIKLGCFNDDFENCDHKNCCFMNDANNEDBNMIMALNG
JDCGOBDLBOMBNJOBOCOIOJOLONOO@@@A@B@D@H@I@NA@BNEHKIFDGKIIHFFJKGHIHG
HKFGFELNOB@BNOMABFKKCEHLEDCKLLFEDJMLIEFIHHGGIFEDFJKIEFFLKJCFIMLCEG
IIHGFFHIGGFGJGIJNMO@OBOEOHOLOMOO@@@A@B@D@H@LAAAE@OKEFEGKIIGEGJKHGF
IKJIEGHJIFHGLNLD@BFMNLD@CFKLLFEDHGILKLHFDHKLLKCDCKKKKDDEGKLKGEEILJ
KGGFHGHIIGEEFJKJHEGFNNNOOAOEOHOJONOO@@@A@B@E@H@M@NABBMHHIIIHFHGHGI
GJGHGIIIHIIGGFGJLMLKBBBFKOMGC@BDLNMKECDFJMLLKEFDGIJLGIEECFHKKJIFDG
JKKKIHFFFHIJJFFEGGIJJHGFMNNFNKOEOIOLONOO@@@A@B@C@H@MADAFCMEKHFGHFG
KFGJFKHIIIGHKJDJHFJLNL@BOLKLBCMKAMMDCKCLNCDLKKGFKLGEDFLHDEHIGHGIIH
IKIIJIIFFIKEEIHIEEJKHHGJJGIHMANBNKOAOHOLONOO@@@A@B@D@HA@B@BLEDELLL
DDJLJJFDFLKEEDLLEDFKLEDKILNE@EOMADDHNDAELKEKDCGMLKCCMMMCDGMLFDDILI
FDDELKEDDKLMCCLMKKCEKMLBEJKLFCJFMLMONNO@OHOLONOO@@@A@B@D@HA@ABBGDL
IFHFGJIEFJKFGKIHGFJKGHHDKKDLOBAJMDMHBEMCCNLDHECMKHFKKGEIKLKDDFLGFF
EIIEFKIJFHJKGIHHIGEJIFFFHJGHGJIGHKFIOBOCOEOGOHOJOMONOO@@@A@D@F@G@J
@MIJIFGLJHEILJGGFKKEJIJJIGJKEIKGJHELKFJFFKKFFIJJLCHMGHJGJJGGLIEGMJ
GHFKKEFJLJEFJNGDGMKFFGKJGGKJFFJKMCDMMHDFKLFEKJIFJLJFBKOFDFKNGBIMKE
EMJJEEOL@GLJLDFJLJDILHHJFJKEKHIHIKGGIHLJDFLJLCEMKJOCODOGOKOLOMONOO
@@@A@B@E@F@G@H@IBMFFJJGIJHGHJFGJIGHJIEIHDHJNJFNN@GJCAHJCIKGIIIEEHH
EJNHJOGGJGCEFEFHIGJJHFJHFJIFJJIHJGFJDGGFHGHJIHIHIGHHIHN@O@OHOIOJOL
OO@@@A@B@C@D@E@F@HA@DMHFHFHGGGGGGGFHGGFHFHFHFGGGGGGFHGFHGFGHFGHFGG
GHFHFGHFHFHFHFHGFHGGGGGGGGGGHFGGGHFGGHFGGGGGGGHFGGGGGGGGHFN@O@OHOI
OLOMONOO@@@A@B@C@D@G@HA@GKGFIIFIIEJJDKGHHGIGJHEJIFHIHGGLDIKDKFGJEJ
GJJGGGGKHIGHHGJGHJGHGJIHGHIGGEIIGHEIHGHGIHHFJIIGIHIHHGJGGHHGHHN@NF
NHOCOHOLONOO@@@A@B@D@H@OAFAJHIEIKHGFFHLICJLKCKLEDKJLDEIGLJFCJMDJHF
EDNKBGMKEDJEKMCCMLDCLKLECJKMDCJKLFDJILECLMCDFMKEDDJNJBEMLCFLFGIGHE
LFDLJDHLKCEMEELDDMLAJOEBKLMEALMJDCLLLDBMNE@LNICCLMKCCKMLDBLNEDEEKM
FCCNJDLCEMKDDLFKFEIHLEDKLDIJFJL@M@N@O@OHOLONOO@@@A@B@D@HA@B@D@DLHH
HHHHHIFIHHHHGIHHGIHHGIHGIHHIGIHIGHHHHHIGIHHHGHIGGHHHIFIHGIGHIGHHHI
GIGHHIGHIHGIHHGIGIGIHGIHGIGHIHGIHGIHHHHGIHIGNMOGOHOKOLOMONOO@@@A@B
@C@D@E@HAB@OGIJGGHHIGIELIFJGHHHFJGFHFMNHDNEAIHEKIGJHCDGHHHJMFGIHFJ
HILJEHHEHIIGDMIBIJGIIGKIDGKGIFJIGFIHFJGHMDJFHIHGOAOJOKOLOMONOO@@@A
@B@C@D@F@G@H@L@OJFIEGICKDIHDJFIGDIFHGFEGHKLDELCAIFFJGFIDCGEHHFJIEF
HFFHIHJFEHGDJGEFKDCJFEKFGKBGHEJGFHFGFIGEGHJCHKCEKEHFNKNLNOOCOEOLON
OO@@@A@B@D@F@J@LACEKKMC@OKBNLGFFGFKKEGHGGKKFHGFFGIJKFFFGIIIIHHGHJF
HJIGGJGHHIFHIHFIGHGIHGIGHHIGHHHIGHIHHHHGIKKDDOKBGMLDFLGHHJKLLCMLNB
NLOFOK@@@E@JA@AHBFCHE@HHIKGBFOKIC@OOIBDFNMEAHLNJCAEOMFCCINHDFFLLHD
GGLJGEFKIIIEGJKICFLLFFEKJHGGIGELMFAFNMCDFLMJDCDNLGEELMDBKNFHCIMKDC
DOMAFFMMEAJMLEDJLKCEKKLMMOO@OHOIONOO@@@A@B@D@HA@B@BJDMBOCCOANKBNCK
MBNCCOBINAOCFMBOBMKCMCLLCMCLJDLHEKKCMICMEHLCMDLDFMCJKELFFFLEFKGHJE
LELJCMGCMFKCLMBOBINAOCHLCMFCMKL@M@N@O@OHOJONOO@@@A@C@D@NACB@D@BOAL
MBMKBO@MN@OBDNBLKHCMDDNANKCIKFKIEJIJDIKDLDDMCEMDELCLCMDDMCFLCLDKEG
LCKLCIJJEJLBNCDMCKLCFNANKBNCKFKJCMECNBLMOHOIOJOKOLOMONOO@@@A@B@C@D
@E@F@G@OIGHHJHFGJHIFJGFJFIIHHGIMJCGKDHKGMGCGHFHIIKEEHHHHIKIFGHIHHH
JGGHHHHGIJFHHHHGIFKGHHGHHGIIHGHIGHHJHGGJFIHGIIFIIFIGHJFIIFHHNOO@OA
OGOHOLOO@@@A@B@C@D@F@I@LADEGKEELFFEMEGHEIIGHFEKGFNOB@LMIJDBNKDGKED
IFJKECGMLEFFEMFFIFEIIGFHEFHIIFEIKEFEGLFEKEKHFHGELELFEIFIHFEHFGHFLM
MGNMODOHOLONOO@@@A@B@E@KA@B@BODLEFFFJJGGGGJKHFFGHLEDHKGGJMOA@NNCDB
BNLBDKHFHKHFDEMLEBILLDEDKKGGFEGKGJGDJLJHCJKFKFBMKEJFEKJHFFJFKFEKDK
IFOCODOEOGOKOLOMONOO@@@A@B@C@D@E@LBOGJJFJKGIKHIIHJHIIJJGIJLNDGLFGJ
LKKDGJGGILLGEJIHJHLKGHJIIHIKJHGKHGJJKIFJKFIJIJIFLIFKGKJFHLJGIIIKGJ
IHKGIJJFLHHIKHIJFKIIIGOCODOGOHOIOLONOO@@@A@B@D@H@I@J@LAOJGKH@KJGII
KEEFLHEKIIFDLGJEJLKCEKGEFINHBFJFEIKKHDGIJFGKLDFJJGFHKIEFIJFFJKFFHI
JFFJKFEHKFIEKHFFKFIFHKFFJHIFFKHFGKEGKGIFGJNMODOEOGOKOMONOO@@@A@B@D
@G@J@L@NCMFHEIIGHGIGJJIIGFIIIKEEHGGGINOC@JKFMKAIKCBLLHHDCILHHKLDEF
JLKHEDHHGHJIGDDGKLEHHJHEEKKIFFEKGGGJIEGIHJJFFJM@MINMO@OHOLONOO@@@A
@C@D@HA@AGB@EIKFEHIIFJJEFGJJGGJGDGLKDKIEINOBALICMKDLMAEOICMEBGKELM
DDEIELLLCJEDLJIHJDCMJJJHGEGJFEFJHLEJKGDFIJEJGFHHFLNENINOO@OHOLONOO
@@@A@B@E@H@NAAANDMDGFHFJLEEJHEKLDJFDKHLFJICKLOM@CLCFFLMKGAEMDKLKDC
JEINIGFEDGLKGKEEDJKFKHEIJGIHGFJJGJHFGIHJIIFFGFGJKFHGFFOAOHOIOJOKOL
ONOO@@@A@B@E@G@H@IA@ALGHHGFKIFEJJGGGJKEGGJGGIHHINOF@JHBDFINKHBIIAF
GLGFHJIGFHFJJFJJFFHHGIIIGHFIIJGHHGIFIGJJHGIFIGGHIGJGHHHGGINHNNO@OF
OIOLONOO@@@A@B@E@H@I@MABEMLBBOGFMCKLCGKHLBDOILC@OMFECFOHCFFKNCFJEK
JFIGEIJJIDHKFKEDKKIGDEMJEHEJJIFEJKEJFHJGJHFHHHJIEFKFJEGKGJFGGGO@OD
OEOFOIOLONOO@@@A@C@E@H@L@NA@CLHGHIFIHIIHIIGIGHHGHHHGHHILODFNA@GEDI
HMGGJEEFDLKHLKHFFDJDGKHHJEGFEGKFKKIJGFEGIGHJFEHHEHKIHKEIGEIJFKFIHF
NIOEOFOGOJOKONOO@@@A@B@D@G@J@L@MDKFGKFJGIGHFGKHJIIFEJHIJEKKCJMOKCL
K@AHEIILMFDGEHFHNKJJKDCFFIIJKHFEFGIGKMFHGHFEJKKCGOCALEJLDLLCFKEFIJ
KJEKNMODOEOFOIOLOMONOO@@@A@B@E@LAAABDKJIGGJLJHKKHHJGKKGKHEKGDMDFOO
CDMF@DILHFLJGDAKMFDNLFFKIJHFLLHDGJECLLKHKIHFFLLJKKGEEEKIKKKHEFKJKI
KKHGHJIGNNOEOFOJOKOMONOO@@@A@B@D@F@G@H@M@OIFLHFHKEGHJIJGIIEEJEJIEJ
IKOEDOC@MFBNIDMEBIGEKGLMCILCHKEKLDHIDEFGKHHHJDFJJIKEKGEEIIHHJHGEIG
IGIJGGIJHHGGNFNNNOOFOIOLONOO@@@A@C@D@HAAACAJDLGFGHGHJFJHGGGHFHIJKG
EGIGFFMOKAHL@@CJLNKHMLBAEIFJJLMGDCFEDJJLLJDFFDEHKLIJFJDFEGHKJGHJFF
GJHJGIFIFFIHIHHHODOEOFOHOIOLOMONOO@@@C@D@H@MAAAHCJIKIJIFHGIHJJHJFH
HGIIJJIIEFLOL@BECAAGLNLKDDGGGFILLKICDEIJHKLJIGCDFKJKJJIIEDFIKJJIJH
GFFFIKLEJHIGGGIJIJIFOBOFOGOHOKOLONOO@@@A@B@C@F@G@K@NAMJGIHHGIGIIHH
GGGIIIIIFHHFFHMONHC@@AGNNMJCCEDKMKLHHFFDFGIKMJHFCFEIKMKIFGEFGHJIIJ
GHFHFHIJHHHHGGJIIIGHFGHFNGNJOBODOHOJOLOO@@@A@B@C@H@NADAHMAHGHKJJGG
IKIJGGFJKGGGFJGGGGLMMMFAABHMOKGAACGMNLIEDEKMLLIGEEEFFGJJHFDGFLLKLH
GIGJIJHIFECFIKLKIDEILLLFEFGINANENOODOHOKONOO@@@A@B@D@H@NAHAKLBKFHK
HIFHGIKKKDGFGKKFEFFIKHEHMONDA@ALNOLBABDKMMMFGDEFKMMMCCBCKLLKCDDHLK
KLELFKFHIKHIECDDLLLFEDELLLLEDFEHMJNCNLOAOHOKOLOO@@@B@C@E@IA@AEANMA
HGLLIEDDLKLHFDHHKJFFGIHIFGFKMONC@BDIMMICCDEFJMNKHCCGMNMEBCDIKKHEEH
FGGLLJKEDHLKIFEDEIIIGGGGGIHKLHGDFJJJNOO@OAODOIOLOMOO@@@A@B@D@H@M@O
ABM@EIIJIIGHHGJKGJEEHKKGFEHKIKEEFLONKCCADHKLIEDCDKLNLGDEELMIKDECEH
KKIFDEGLJLJGGEGKKKEGDGIJGDGIKHJGIKHEGHLFMHNLOEOGOIOLOMOO@@@A@B@D@H
@MAHB@GFKGGFGIKGIGHJHGEGJKJHDGHLGIGDKLONA@BDLLFLFDDAHMNMGADIMLLJCB
DCHMKKBDDKLLLGFEEGKLLCCDGKLHEHJDFILKLCDFKLHFOHOIOJOKOLOMONOO@@@A@B
@D@E@G@H@IDKHGGFFHIHIJIIIIFJHGHHGHGEGKOMIHLFA@CDFHEIJLHDFGGFHKMLMK
JJGCABDDEHJJKHHFIGGIKJMJIIHDDDCFGGHKIJHIIHHGJJIHOEOFOGOHOJOLONOO@@
@A@B@D@G@J@K@NDIHGIJIGIIHIIIGJHFHGHHFEHHGKOOJEFFB@@HKJKGFKGBDDKLLL
NLLEDBEECFKJKFGEFEGGKMLMIJFED@EIJIJIIFEEFIKLILKJDEEFMANHNLOCOIOLON
OO@@@A@B@D@H@KADBEANLFEHGGGJKJJHFFEFEJKLGEFGDKLNNKCBBFCFMNLGBCDEMJ
MNMKDBHDLFHMGECCDKKMLLKFDDELLKLDECDDELMLHFDFDILLLGFDGEDKNKOAODOFOH
OKOLOO@@@A@C@D@G@MAAAJDIGIJJJKGEFGIKIHGIEFKKJGFHGFKNOLC@@AGLKNLI@@
CLNNKLKEDDELMKGCDCDIJLMIIDFHJLJLJFFCDJGJIIJFHEGLJJGHGHGIHIGFOGOHOI
OJOMONOO@@@A@B@C@D@E@G@H@IBMFFEHEGHFGHGIFHIHHFGIEIMLFHOG@CHA@CDFFF
KMIJIHKGEFIJEGKJGEFGDADDDDFIJLIKLJGGGGDEFFFFEHHEFGGHFHHIGHHHGEHFOE
OFOIOJOKOLOMONOO@@@B@C@F@G@H@JIJDJFIHGJJGIJHJIJGJJGIHJGIMOLGJKGA@B
CDGEKNLJJJKGCHIKJJKLLIGFFCBBBJGKKLMLHJGIGEHIJJGJJGHFEHHIHJKKKIJIHH
GGOFOGOHOJOKOLOMONOO@@@A@B@E@I@L@ODLKHFFGHKKJJIJIJGHGJJKKIIIKMOLGC
@BBCBCKMMLHGDFIGGILMOLKGBCCCDCHKMLKJEFHIGKJLLLLFDDCFGGJKLKLHEHFJJK
LGJJGGNHNINNOBOHOKONOO@@@A@B@E@H@MABACELEGFEJJKJFFGGJJJGHGHHIHFJMO
LJC@ADHMMMHECEEFIKLLLLKDECFELLJJEDDEHJKLIKJJGEEFIKJKGFDEEJJKKJHFFF
HIJJJHFEHELMMGNDO@OHOLOMOO@@@A@B@E@HAAALBDCNBNCGMBNCDOAMLCLLDELEEK
LDFLDKEJLCMDELCMDJJDLEEKELDIKDLFELHEJHHGHIELDILCMECNBMFDLGICOAMN@O
DDLIICNBMEEKELCMFCLLMEN@O@OHOIONOO@@@A@B@G@HA@B@BIFCNCDMFCNBGOAKN@
OFBNDCNBMJELDKEHLDKFEMCJJGKDHKDGJJFJHFIGJFKDJLCMDJJDMBNGBOBNBLMBOB
HO@MN@NM@OKAODBOCEN@OCEMFCNBNHNMOEOHOKOMONOO@@@A@D@HA@AIAMCLGKIJFF
JKJIHHGJKKEFHKIKFEGJLMLD@DONDBCDLNGCADLNIBCFLMJECFMKLDDKLLDGIJHJFF
HJJHDFLKIEFIKKLECFKMJECHKLJGCFL@M@N@O@OHOLONOO@@@A@B@D@HA@B@CNDKHH
GJKEFIIKFGHJGHJHFHIGJGEGMMFAFOHBCMELNBBKNLBKFDKMFCELLGJKDDMMDCKLHK
IECLMDDGFHLFEEGLFHHFEILLCGLIIGFEHLN@NFNIO@OHOLONOO@@@A@B@D@IA@AEBD
IIIKLC@MMFLHFLFBFELLLKEEDDJKGKLGHFDDMHDEKJHIEKLEDGJGHIKKKDDKJGFGKL
FDFLLCBNFKJFKLHCDKKGKKKLCDKKDIKLHHFDELFELJEHGDKKEMMADLCKEBOOBCLBKE
FNMGDDKDCIMLKDEIFEDLKFKLEEEFGKFKJIFDILDHIKIDJKJEFKKFDLHDKGJKEEJLDD
KKKEDLLDDKKGEIKJFEJKDFLKEEGKDJKIDLM@MJN@NKOGOJONOO@@@A@B@F@IA@AIBO
GJLFBLOACODBNMAMLDHNBCOGANLCKMCKKEFLFEIKDLHDKGELIDMICDNHCMFHLCMHDG
JKLDDLELGDLFDLIEJJEKJEJIFLDEMDHIGKKON@NIO@OHOLONOO@@@A@B@E@KABANBK
GJLKACOKAKMGCLLCCMLDELDCMJGFDKNAAON@KOCBMMBCNJBLLDDJLCLJGDFMCGMCEL
IDKKDDMHCJLGCLMBDMJCMFCLLCDMFDLDDLKDFKFDLLBJLDLEJDDMFDKEFJLDEIIKGE
JDENBFLFDFMDDLDDMFDFJKEHLBLMBFMDDLJCKMDCLJEKJBMMCDKJDKMBENBELKDDMC
FLLIM@N@O@OGOLONOO@@@A@B@D@HA@B@DCFIJKMC@NO@ENAMNBLLEEGLDGLHEKLCHK
IHJKCLLDHLEDMCLLCMECMICMHDKKDJLEELDKKDLFFJHLDCMJHKDFHKGLGEEJFILEFK
EEOCODOHOIOJOKONOO@@@A@B@D@E@H@J@LGIFGGGIIIFIIGFIIIIJIFJGGHHIKLNCD
MF@DOLBINEAEKCEKKIKIFFIFFKLKGKJFEHGGJIIJIEFGHEILGFJKDFIIFKGJIIGFHJ
FHKHFGMNNENGO@OGOLONOO@@@A@B@D@IA@AFBHKICKMFBNKDKDFNDCFNLBDMKMBBOK
DDELJLCCNNBDEMLHCGFKMDDKKGDLKKCIKLKCJDLNDCCNNBDLLFEEELLK@KOCDCMLDL
DDHNGBMKEDILLDCLLKDDLKIFDFMGDDMGFFEFLKDFGLKDELIDGKNCNINOODOGOLONOO
@@@A@B@D@I@MAEAGFJJLKAAOKKODBMACNJKNDBKDDMNIBBLEKOCHLADOCLMDEKCELK
KIFDFJJHLEEKFDLFIKJCIKHJKEGKIDFKHHKEJLDEIGIMFHECJEIMFLEBIKHLHEKHDK
KFLDEFIKKEFKEHIELHEHIFKFFJOHOIOJOKOLOMONOO@@@A@B@C@D@E@F@ICKIGHHHG
GGJIFKJEIIHHFKIGGIIKMJDGLCAIOGEJJC@FGHGKHIKCEIJGHMNGGIHFEJJKHIGGGD
GKKFEJKCDHHFIJMGHFFJFINKCJLAEJN@NDNIO@OHOLONOO@@@A@C@D@HA@AJBIGHGL
DEMCKLCMDILCMDDN@MLCLIGELDIKELCLMBLLDELGCNDCNCEKLDFLGDLICMJCMDIGJD
MDBOAGNAMEGGEMBMICNAMLANECMFEELGDMCHNLOBOCOFOIOLONOO@@@A@B@D@G@J@K
@ODLIGHGFFFHJHMEDJJEIKKIFFJEGKIOOCAKK@DONFFDCEBDNMKJFHFDHNNLIKFCEE
ILIGFFCCFJKLJKHFFEHLNEKKDCKDHLHFIFCIKFKKN@O@OHOIOJOLONOO@@@A@B@C@D
@F@HA@DMHHHHHHHHHHGIHHHGIHHHGIHHHHIGHIHHGJFJGHHHHHHGIGIGIGHHHHHHHH
HGHIGHHIGHHHHHIGHIGIGIGIHHHGIHHHHIGHHHHIGHHHHHHHNANDNGNNOIOMONOO@@
@A@C@D@HAAAMBJDLGKLCBOLADNK@KNBFMFAMNBBNMAEMHCLLFEGIFGKLCKLLCHMDDJ
LDKDJKFEIGGJHFIIEFKJEHHGJEIJGEKFEJIFGKGDILEDLGELDCNFCKLEDMDCMLBMMA
IMDDLKDELLOCODOEOFOJOMONOO@@@A@B@E@G@H@I@LFFKGEJJHGDMJDFKJEDLIHEFK
FIEIJHFFKGHGDLHEKDJIGGJGNL@CNMDKEEJHCHNKCEGGLFEKIFEHJLJDEJJIHEIKED
EJMFEEJJGFIJJENKNLOCOEOIOLONOO@@@A@B@D@H@J@K@ODLFHHJFGJFJFHKEIHGIH
GHKGIFEJHIIIFFLOI@FNDFJKKJADLIHKHKFCGMLJGFFIEELJGEDHIHHKJGGEKLFILF
@IMDLJCLDBLMHIHDKKNLNOOBOCOHOKONOO@@@A@B@D@G@I@NAAEKGGGLEJJEKIEHKG
GJGEKGIKEGJKGFGHHHJFFKIFEFLOMAHOB@KEINGDKMCCGKLIENLEEFFKJEKMHFEFGE
EIKFKKEKIDIJJGKGHIFEKGODOHOIOJOKOMONOO@@@A@B@C@E@F@G@HHIGIGIGIGIGI
IHGFFIJLLDCCEJOLHDEEKJJGJGIFFFIMJAEKMKIE@FLLJIGDKJEFHIJLEFGFKEJOEB
HKIHJAEONJ@EKJLJBEHMKECJLMHDBFLKLEDGIJFEFKLGFEDKLIHGGIKHEGIKIFFGII
IEFIIIGHEINLOCODOHOKOLOM@@@A@B@C@E@G@J@L@NGKDFHHEGMGEKDFHGCKMGBMID
EGELLBJLHDEKGCGKGGLDDODALFHKFGJHDKGDLFCLGCLICNICGKBGKDIOFCMFAILDHM
CFMECLKCGKDFLEFLJGHCJL@LKEKKEJHAGNCFLIEIFGKHEGIFFGKJGEHFGFLDGJKFFK
GDFHJEJHGNBDLIBINCIJFKFFGJHDDIKFGJMEDIDEGEKOCHLFDEDJJFLLEDJFEJFIKG
ELFDGHGDLIFJFGIGCLNINMNNOCOHOKOMOO@@@A@B@E@I@M@OADGIJELEFFKGGJKGDF
LJFFFNCGJLGCGKNF@KNJJBJLFEJMCGJLJCFIMK@KKGLEHGFJJEEKNEDCNLDDENLBFK
NDCKINDDGLJDEGLLDGDJLEIJFGKGEKFKGFEGKJEJKLDFFDLLCKGELKDIFJLEAJOEHH
ELGEDKLEEGLGDKKIDEJLJDIGJKEGEKLDJEELHKHDFIKIIGFJDLEELJKDGGFLGDKEKL
FCKLDJDJLGDKKGEFFLKECMIHHDODOEOFOHOJOLONOO@@@A@B@D@H@J@L@MJGGGIFFI
FIHHJHGHGHIFKGKEIKDGJFJNOIDHKA@BFMJFILICDFHIGJMLKDGGDDEFLFKIJHFDHI
JGKKJFGFGEIFFMFKHEGJDJJIKFGHFFFHNMOEOFOGOJOKONOO@@@A@C@E@G@H@K@MAO
FFHFHJHHHHFGGJGJHGGJFKFFIGHOOECKD@GNGLGCEDDHMNHFGGGIKMMGDFEEGJJHEE
FFGJKLHHFJGDMOABLDCMFIMDCLFGKKJHEFJINCNKNOODOJOLONOO@@@A@B@E@HAAAO
BDEKJJEEDGKGIIIEFKJJKHDIIELJEGFLMHALIBELKLDCDHFHLLICEJLKKKGFCHKIJF
FDDFHLKFFFGIKKJKKI@DNCAOADM@KNBFLFEFJLLFNCNJNMO@OHOJOMONOO@@@A@D@H
A@ADAOLCLKDHKJFDHKKJGKJFFLIHJIGKIEKKMLCBMGCLKKJCDKLEJLHEDJMKKEJHHE
KLIDDFJKFKKEGGKLKHJLF@KOCDMALL@NNBGJKHKKFLECNANBNFOCOHOLONOO@@@A@B
@G@H@OAEBACKLJIKDCKKEEGGFFHJLEDLJFHJJHFKJGCHLNMC@LLCFMJICBLNEFJJCE
JMMGCFGJKFKECEEKJKDFFGJJLKEDJMFBJOBELDLKBMMCEJLENBNJNLOBOHOLONOO@@
@A@B@D@HA@ALB@HLBLLEDKIFFFGMDDKKJFHKLDDILJELND@GLIKGEEHCEMKEDHEJLI
LHEEGLKHEDGGGJKEEFIKJKFHIKFKJCGMCFLDHLDHLJDILEFLFEHFNINOO@OAOHOLON
OO@@@A@B@E@H@KACAGDKJFEHGHKKFIFHHJJJGGFEGHIJKDHOOE@CDHMIGJIDACKNMM
ECEKLKMKEDCEGKMFDDDJKKLLHEEFKFJLHDEDFLJFIGDIJKJLGEHEFKIGNAO@OGOHOI
OLONOO@@@A@C@D@H@JAFAOEJEHJHGFGHHJJHFIJIIGFHJFFGHGFMOE@AMMLLAAKKED
LJDHFDMMKFEHJKJJFEDHGIJDFEHKJFGIKKJIECLMFCGDJKHFDGGJKKEFGKKJM@MMN@
O@OHOJONOO@@@A@B@D@HACADANLLFACOMLFBJLJLGDFKKGHFFGKLKFBDNMLGBKLKLE
DGLFKHEHJCN@NKNOOCOIOMONOO@@@A@B@D@H@KACAGJEEJFHHGHJJHIJEGEFIIKJJH
GEFEFKLOMCDLCACGMMIILKCCGHKJKMMHDDDDEFJMKFKFEDHFKKKJKEEDGGJGKJKIHF
EDKHHKJJHEEFFENKODOEOFOKOLONOO@@@A@B@D@H@OAAADDJHIGHIHGIHFJHFJHGHJ
HFIIFKNDBOF@MCCLDFKKFIKFDIHDFLDIKJFJGFIFFIJFHKEJHGIFGKDKFIHHIHFIJE
JJFJHHIFIIFGHIFJGGNMOCODOEOHOLONOO@@@A@B@C@D@E@H@JEIHIGHIHHGJGGJFH
HHIIFIHGILOIDON@MIAKFELJHIKIFEKEEKIFJMFHKFFHGGHFJIHIGJHFHIEJJFHKFH
IFKHFGMEHLEJHHGIFIHFIHOAOHOIOJOLOMONOO@@@A@B@D@G@I@K@ODKEHIGHIGJGI
GHHHGJGHHHGGJGHLMDFOD@NAAIFEKJFKKDGIGCIKDGKKDKIDIHFGHGHJGIJFIIGHEJ
JDIKDIHGKFELCHKFHKBLDFKEHHOGOHOIOKOLOMONOO@@@A@B@D@E@G@L@OCKFHIGIH
HHIGHJFGIHHHGIFHKDLNDEOC@MACHCHGKFJLFHHHDGKCFLJEJLDHJFEIFIGHJHHJHF
JGFJGGJFJFGLEFMCHKCKHEJHFJFIGHODOFOGOHOIOJONOO@@@A@B@E@G@H@I@LAMHF
FJIHIJGHIGJHFIIFGJFIGGKLJFOJAFIAAJFFHLJFKHEIFFIJJKKFJJFEFFFDKJGKJH
FLDENEFKGGKFFHGHHHHIIHHGJFIIGHIIFFNENJNKO@OFOJOLOO@@@A@B@D@H@LADAE
DKKJFKHFJIFLFIKGFHIEIGIJGHKHLNFFOCALAEFDNGHNDMGCLFEJLKKKKGEDFFDGHL
KKLKIGFGFFIGKHIKHIHFGEFKFJLKGIKDJGDMEFNDNGNMOEOHOLONOO@@@A@B@D@I@N
AFAOCLKFFFIFKFIKHFGIFEIHGJGKIGEKNMDINA@EBEEEOLIMFJCBKHDLMLKJEDDBFG
HKLMKKFHECFFIGKLFIGFIJDEMDCMFDMCKLCKKFFEGJMJNGNMOBOHOMONOO@@@A@B@D
@I@NAHB@DKIHIEKHHKEGJEIFFIFGKKEKGEGEGOMCMM@ADCDIMNMKKHDCBKKEMMLHEC
DDCHLLKMIKECGFDJKKLFHJEDIKEFKKEFHLDGKEEFKGIKDLNCNOOBOEOHOMONOO@@@A
@B@E@H@K@LAADLGGEKEEKJEIHFGJIHJGFJFEKEIIJJOKANM@CLCDNMELKDGHCEKEIM
JEHJDEIIIKIGJFEFJFHKIEJFFHGEIKFIKHEHFEHJJFKIEIGEHHOAOFOGOHOIOLOMON
OO@@@A@B@E@F@H@KBNIHGJHKJHKIGJHGLGIKIFKJEKIELNNEIOA@LDCLLKKNEGIDFJ
HHMLGKIFEGJIKLFKJFHIHHKKJHJFGKFKJGMKBKN@LNAMLFIHJEGKHKODOEOFOGOIOL
ONOO@@@A@B@C@D@E@H@K@OGGHIHHJGIFIHHGKGGJGGJFFJILNEHNDDIEEMGJKIFGGE
HIFHMGIIGFIFFJJGJHGHHFIHJIGHFIGFGIIHJJFJGEIGGKHIKHGGHFFJFIOAOBOCOJ
OKOLOMONOO@@@A@B@C@D@E@LAOHKJGJIHIIIKIIJGJIHJHIIILNJFKKCJIEKKEKLFG
KHFKHGKJHJJGJJFJJIHIIIJIHJJIIGGLJDLJGJIHIJHJIHKHJHIKGJJHIJHHIHJ@LD
MFMLNHOAOFOK@@@E@KA@AHBDCHEKDMEGJGHHHHGHIHHHHGIIGGJEJGGHJKOF@DMCAM
NJLDAJMDFNMCBDLHIHKKECHLIGJJFGEFJKEHJGGGIKHHHHJFEDMHDKHHLCILFFIGHG
LONANGO@OHOLONOO@@@A@B@D@HA@AMD@DGIIJLHHGEDKJKHFEFLIGHEFKEELLMOD@A
BCKINNLJBBKLLMMCCBFLKMMEEDDFKLJLDDEDJKKKJKFEGKLIKCLLAELFLMKIKCDEFL
EGLDLJMINMOEOIOLONOO@@@A@B@D@HA@AKCAKBLGKKHHGHFGJIFHKEKDIJCLLFIGFM
OK@MDAAKMNNLFMBABNKILMECBDIMKKMLCBDDGLLLLDCDIEKLMGGFDEFDKLLEFCLFCM
KFICFGDLMLNMNOOBOGOKONOO@@@A@C@D@G@NA@AABOFIHFIIGHGHGIHJIGIGEIIEJJ
GIMOLCNF@DEAHMLOMFIEDCEJGJMLHHFDDFFKLJLHIEEFEFJJHKJHHJHEFLDGLEELHH
KEKIEGJEIHHIM@N@O@OHOLOMONOO@@@A@B@C@D@HA@B@HHGHJFHKHGHHGGGIHHJFJI
HFHGIGFJIHJHGHHGFHHIGKIGIIEFJFHHIJHHIGHIEHIFIHJGHHIHGHHGJGHGIGGJIH
FKIDJFFLHEIJGHHHGHJGGJHGIHDGJIHILGGHGEHJEIKJHGJFEHFEKKGHKJGEHHEJIF
KIHJGFEIIDJJJGHJEGIFHKHGHJHEGJFJIGIIGGHGGHJIGIHHFGNGNKNMOGOJOLONOO
@@@B@C@D@H@MACAKBNIEEIKIEGHIIFHKFEIIELECLKDHMLH@EOMBCCLMKABNLCCIFL
EEKLGFFLLFGFFLHFFEEHJFEHFGKHFEKLCLGFIGGKIFDIJHFFEKJEFKMNMONLO@OHOL
OO@@@A@B@C@D@F@KABADBOIFFEJGGFGEIIGIHEJGEJLFEFFGNNE@ENEMFCDMDDJMDH
EDIMLHFEELMLDHFEFFJGFECLKIJGFEHHKLIEEIFFIFGEGFFJGFHFFHIJGFLCN@NEO@
OHOLONOO@@@A@C@E@H@KACANEEHJGJHJHGIHGHFJHEJGIGIHJEFIFOOCAOD@LLELNC
KNBCNMKHJKDDGEJLFDKJCJKKHIIJHEDKLFELJDFDFKFFLMDDLEEJEKJGEJIFFKNBNJ
OEOGOIOKONOO@@@A@B@D@G@J@OABAOLFHIFFFGGIHIIIJGIGHHIHHGJLMMJFEEDCCC
EJLLJHGIEGDFFMLMMKJHGECCDGJIJIIHHEEFFKLLHKLHIEFDFGJGHHGKEIEIFKKJII
O@OBOEOFOIOKONOO@@@A@B@D@H@J@K@LDKIFGJKGHFFEGIIKKKGJGFGGFGIJLONLF@
BACGFGLKMKFCCCFKLMNLKLDFBBFGKLKHEEEDEFHKMLMLEDDDFLKJKFFHDEEDJKMLII
EFEJNKNOO@OEOHOLOMON@@@A@C@D@H@I@MA@AOJJHEDGFIJJJIHJHIGFGIJKIHEIMN
LKE@DBHHHJKJKJDFCDILNNLJGEFEEEHHKKJFCECEKLJLJKKHDFDJLJLJDFCFFHGJJL
JJHEDGHJN@NNOFOHOKOLONOO@@@A@B@C@D@H@OAAAOIGJFHGIGFJGHJIGHKFELEHIH
MMFINCDJCBGDDFLIIMLGLKDHGEFHGHIKJIHIGFFFEHIHJKJLHJHFDHFEGIHILIJIJG
HFHFFHHHHHJGNFNNOBOFOHOLONOO@@@A@C@D@H@J@K@MBOGIHHHGFIIFJHHIJEHIGF
FJEILOKDOL@FIADLFJLMGKLBEICDLJHLLFHIEDGEEJJJKLFHFFDGGIHJKJIIFFFEFI
JGJJIGJEFGGGGJGHNINLNMO@OHOKONOO@@@A@B@D@MA@AAADANKGHKEGGGFJJHJJFJ
GFGGGJFFKLLEEOC@KECKLFKMJDKFCEJEKLIKKIDEEFFJKKKKIFEFDHHIKKKJGFEFGF
GKKGKHFHFFGIJGKFIGFGMKNJOCOFOHOLONOO@@@A@B@D@H@LACAEAOLCFLFCKKGKIF
FIGFKFFKGEGJFMMEEOH@OBBLDKMEDKCEEFLKKMKKKDKEDIJEJFFFEEFFKGKMGKIKHD
KIDHFHKBGLEEKKHKGKIEHKHFMBNKNLNNOHOLONOO@@@A@B@D@H@MAEBAIDJFHGJKEI
KGJIHKJEGKDHGEJFELNNEAOC@MDDMDNLAEFEDELNLKLMDCKDFDFLKEDJGDFKLLEMKF
EGHFEKEDLDDMEDMDFMFEMFDKIDIKNCNDNENMOHOKONOO@@@A@B@D@H@OACBEEFFLEE
LLDHKEKJEKJFFJKDHFEJHFLONCDN@BDELHINLDBFLDDLOLGLLDCCLFEEMHGDDKFEKM
LHKLFDDKEELEELDDLJDLKELLCNEEIKFDNENFNIOCOHOLONOO@@@A@B@D@H@OAFBDDF
FLKEJLCKKFGKHGHFGKFEJHDKFHLNOCBN@BCEKKLLLFADLEDMNMLEKFCAKKEJJLGCEF
JFIMLKGKGFDHLDCJM@KMDKKDLKFDLLCKKEKFN@NCNFO@OHOLONOO@@@A@B@D@HA@AL
CAKDIDFLGELKFHHFJHEHLIEKFDIEDLKMOD@MD@BLFLMFMECALFFLMNLFJHCCDHKKGK
KDDDGKJKMLHIIEDHEFGIGIKEEFJFGKLIJHGIFEGJNMODOGOHOIOLONOO@@@A@B@D@F
@I@J@M@OKIJHHGHFFHKIJFDHJKKGFFFJIHKLNKCAEFKLLEEDFDDILLJFECILMJKJII
FEGILIHDEDHIHIHGIHHHGILJKGFGIGHHFIIFEFELGKGFOAOIOLOMONOO@@@A@B@C@D
@E@F@G@J@M@OFGDGEGFGGFFFEEEFGHGFGFDEEGKNKCAGEAAJKJFBACCCEGIMIDDFHE
GJIJFEBBDEEFHHFBEDDHGJIGDGFEEFGHGEDDFEDFIHFFEFDFNIODOGOJOMONOO@@@A
@B@C@D@E@G@KAE@OHGFEEGJIIHGFDFIGJJEDGEDHLNNCAGFDLKIIHBAEKIFIFCCEFJ
NGIDFFIKJMJDDCJGKHEEECFFIJFFEEGGHKJEEGFHKHFIEDFGIIFENJO@OCOFOGOKOM
ONOO@@@A@B@E@H@KAE@OHGGJKJKKFIHIKKJIGFJIGKLGNNABNMDLMCEMEANLECKGEI
LJHKJEIMLKIIIHKLHIJFEHJKIFFFIJHKKGGFKLJIGIKJFLIHHGIKJFIGNMNNO@OBOH
OLONOO@@@A@B@D@H@JA@AD@NHFHJGJIFKHFGKFHKEHIGHGILND@EOHELDCMMBFMECK
JDLHDEMIFJJFLIFHLFFIIIHGFEIJFFFFJFIJFEHHKKFFGJIKFHGHHIJGGFFIOBOCOD
OEOHOLOMONOO@@@A@D@G@K@LAAIHFIHGGJKGJKIJJJGJKEJIGIHEHNOJELKA@CDHHG
KMLGFHGEDHMKMLLKHECCDFDHLLKJKJGEFIKKKLHKIDCIEDKJKKKHEKFFJKJKKGHEO@
OBODOGOHOLONOO@@@A@B@E@J@NAEAIJEIFEFHJJKFGKEGIJJJHGHGEEJIELOMBCFB@
BHKMMFBEEBEHMMLLHEFCBEKLHHGEBECILLLIKHFCDHLIIJHDFDEKKKJIEEGFJLIKFF
CEL@M@N@O@OHOLONOO@@@A@B@D@HA@B@D@HHHEOCOHOKOLOMONOO@@@A@B@C@D@E@H
@I@L@OFFNAFKFHANGFHBKHFEGIDKFDJDNFCMBBJDFIJDIHBFEGJEIIEGFGELEHIFGI
CJHCFLFBJGCLDFLECJKCDJEKGBGNCBMAJFFNCAKKGBOCODOEOFOJOKOLOMONOO@@@A
@B@C@D@JBOIMIIJMGJKIMJGIKKJILIJHHLLMNLDFKLJLIJKJFHKKKJIHIJMJIKIKHL
JJKJIIKJILLFJLHHNJHJILLHGKKLHKHLKGILKKJHILKIJIKKIIIMJHN@O@OFOGOKOL
OMONOO@@@A@B@C@D@IA@BNJKFGMJGGJKHJHHJIHJJGHJHJKKLIDGLIIIIHLIFGIJKF
JIGIKIGKIGKJGIJJIHHKIHIIIHIHJKJGGIIIKJGIIKGGKILHELJFJIKKEHKIIIJGN@
O@OGOKOLOMONOO@@@A@B@C@D@G@HA@BMJHHFJKDHJFKFGJGGIHHHHHGGIIKJHCIJDI
KFIIJDFHHIJFGHHHIFJGJGGHGIKFIIGFIHEJKFHIFGGKHGHHGIIHEJKDIJFGKGGIIG
GGLFGKO@OAOBOCOKOLOMONOO@@@A@B@C@NA@AACMHIIHJIHJJHJIHGJIKKFIIGJIIJ
LLHFFJKGLIGJJHGHJIIHJHHJJHIIIJIIIHJJHILGHIIHHKJHJFIHLIFKKHIFIJLIHI
GJKGJJGKHGJJIIOBOCODOEOKOLOMONOO@@@A@B@C@D@E@KBOIJJIGJGJKGKKEHLGKI
GJIHJGIMLLEDKJHHJKHKIEGIJJJHHHJIIGLIJHIHIJJIIIKEIKGGKLIHGGIKJIGJJH
HJJGLIEJMEKJGJJIFJKHIKOCODOEOFOLOMONOO@@@A@B@C@D@E@F@KBOGGJJFFKGGH
JGGIIFHIHHIFGIKLIEFGGIIGIJJEDEIKIGHFHIHGGJKGHFGHLHFIJGFHHFHKGJFFHH
IHIGHGIHGJHGHIFHJJFGIHHIFGILOAOEOJOKOLOMONOO@@@A@B@C@D@E@G@IAOKGFI
JFHJGFJIGFKGHHIFFKHFKNJCEGHHJGHHLHBDHJIJFGFKIGDJMGIGFGJJGGIJFHGHGG
IJHGGGFJKFFKHGGIHGIIHHHFIHLFCLHHNDNENJODOGOLONOO@@@A@B@D@IACAFBBBM
KFGJHGHKFHFEHKHJFEIJKFEFFLMME@BENOGBBCKMKECCILJFHKLFDJKMKFDCKLLHCC
DLKKDFEGKHKKEJKHJIJHJHFFEJJHEEGIIGFGN@NENHO@OHOJOLOO@@@A@B@D@H@MAB
BABNLIGEJJKGFHFKGHHGHJIGFHJKFKNMI@CKOMDACHNMCDCMJKFFIKLHEKLLJDFKLI
FDEKIHDEHLFIFFKLKFGJKIKGGGHGGIHFGFKGFHJGNHNINJOAOJOMONOO@@@A@C@D@G
@M@OAC@OJJGGHJFHIHHEGIIGIFJFGGIIGJMODBBOONC@DJOHCCJLJDHEHKLEHKLJEG
LJFEFIHIDDFHJGDGHHJIJIEIJKLEDIILIDDFKKGDDFLJNBNFNJO@OHOKOLOO@@@A@B
@D@HA@AEAKBNGHGHJKGHGEIKKEEJKHGFHHIJFLMMBAIOMEBCLMLCBIMGEEFJJKJHJH
IKLIHFHILFGEEGKGFFGFKHHKFGJILJEELKIIDELLEDEJKIGDNFNGNLO@OHOLONOO@@
@A@C@D@F@OAEAICMEHGJJIHFFILIEDLKIFEEKJFEHKMMC@LOJEDCJOEAFLKEFFDLIE
KLGDLLLKDHJLJEEGGJFEFIEFJFEIKHFGKJFHJHILDHLJDFJHGFFHNFNNNOODOHOLOM
OO@@@A@B@D@HA@ACANHEEKJGEJKGIGHJIGGHJJFIIEGKGEJLMI@BONCCDFNLBAKNDC
JKDHKJJHDKLLHDGLKJEEIJIGEFHHFIGFGHKHGDLLDHKGJLDIGIKIDJGGNJO@OBOEOH
OKONOO@@@A@B@E@H@K@LAAFKJEFIFGJEFKGEIKKDJKFJJGGKHFNNA@OOEEJDCNKCFJ
EBKNDDIFGMKCGLKGKKEFLHHKFDIJJHGDEJLEDIJEIJJGHFGKLEFJKHIIFHIHNKNLNO
OFOJOKONOO@@@A@B@E@I@J@OA@MCGIGHFFFGHHJHGGJJKFHHJKEHKHMLCBJOHFKECD
JHJKF@DLJJJFCHKKKKKCFLJKKFDFKEKIFFDEIJJEEJHFFKGJHFHKKFGKGGJHIHHFOF
OGOHOIOKOLONOO@@@A@B@C@E@G@H@IOBFGFGFGIGIKGFIJIKHJIGGHKMNF@ILDEOMB
EECELKDELC@JLJKLDGKIHLNIGHFGIKGIIFBIGFJIDFJFDJLGHIGIIJHJLFGIIFIGIG
GGM@N@O@OHOLOMONOO@@@A@B@C@D@HA@B@HKFGFIGHHHIIJIGFIHHFGIHJHIFIFHGI
HIIHIFGGHKGJGGGIHHHHJIGFEGJIHHJJHGEFIHJHIGIJIGEGGHHHHHJIJHGFFIGKFH
JIHFGHFKIIJGGFEHFHJLKHGGGFGHHJIJHGEGHHHIGJIIGHHHFKHFGEIJJJFGIGGHHJ
IHGEGIIHHIIIJGFFHJGHFHGHKIIGIGIEGIHHIIGIFIIHHHFHIGHJHIEGHIHIHIJGFH
HFHIHIJJHFFEL@M@N@O@OHOLONOO@@@A@B@D@HA@B@D@HHHKL@M@N@O@OHOLONOO@@
@A@B@D@HA@B@D@HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHDKOJLILBCBABN@
EIMJLAA@BJ@@@B@BD@@@OOCMD@OOO@A@BJ@@@CFJ@@@@OJ@H@@@@@FEFNNOOML@B@@
@@CODJBNOONCFGAFABBNOONFFGA@@L@A@@@AFF@FEBD@NBDHF@@DNCD@ECD@CMD@OO
OFA@BNOONGFGDNDENNONMLG@COCDOLGOGOEALHOOOJCJCL@@GOCL@EDINM@@A@DENN
ONMLDBDBDBD@A@@EM@@EI@@F@H@B@@@@FG@HANAL@B@G@@@OF@@DANADNH@OM@CEG@
@@AL@EAJ@@ADL@EBDBKDFNOOO@FFMFDBBNOONGDJBNOONCFGBL@LBN@@@EOONHFF@F
EJBNOOOEF@AN@LBN@@AJOONHFF@@@@AF@LBN@@@JOONIFE@L@LBN@@AJOONIFD@DNB
NNOOOFA@BNOOODI@BNOOOEFG@FNH@@EJLAI@@AAMD@OONBC@BNOOOFL@NNOOO@CDBN
OOO@@LDB@@CDFMANNBDJDHLBM@HBABBNOOOEDHHAMBFNOOO@H@LAEGLAI@@ACMD@OO
OFFA@@@@JHDNGEFFC@CMGL@@@AOOOF@LFN@@@IOON@FG@HFA@@@AODFA@@@BJBFA@@
@ANLFA@@@BIJF@ALFA@@@@H@FA@@@BI@FA@@@@GHFA@@@BHH@BD@@@COCMD@OOOFFA
@@@ALJAMGL@@@AOONGDNGEABCK@@CBFG@@@@EHEBFNOOOFFK@@@ADLCBBNOON@AMGK
A@CNOOMN@LDA@@@EFGABFL@FEBDDEBD@DNGEECDDECD@FF@@@@@DEHHODNGE@@@@@@
@@@@@@@@@@@A@A@A@A@A@A@A@A@@@@@@@@@@@@@@@@OOOOOOOOOOOOOOOO@B@C@D@E
@J@@@G@D@C@BCHCL@@@BECBNOOMNFF@JC@BNOOOFFAJBCMD@OOOFABBNOONBFGAJMB
BNOOOEAMDAOOOEA@BNOOODI@@AFG@JNH@@EJLAI@@AAMD@OONBEBBNOONJA@BNOONJ
@BD@@@AOADCK@@IDMDBNOOOEDHHBFO@LA@BNOOONFA@@@@JJECDBFFODMDFNOOO@CM
DBOOOBDINM@@A@DENNONMLCJCL@@GOCL@EDBDBDBD@A@@EM@@EI@@F@H@B@@@@FG@H
ANAL@B@G@@@OF@@DANADNH@OM@CEG@@@AL@EAJ@@DJBNOOMLFG@NDBDAABABC@DANI
FAIBDHM@DANHF@ADL@FAEBEBDBKDFNOOOBFFKNECFNOOOFFF@@OODHDNGEH@HCHFHI
HLHOIBIEIHILIOJBJEJHJKJNK@KCKFKIKLKOLALDLGLILLLNMAMCMEMHMJMLMNN@NB
NDNFNHNJNLNMNOO@OBOCOEOFOGOHOIOJOKOLOLOMONONOOOOOOOOOO@LDC@@@JFF@L
ABCH@AFMKBCH@AFMFGOJF@@L@LDC@@KIFF@FBFGH@BFFDBDCDJFNOOOLFGA@AB@@I@
BNOOONAMDAOOON@F@@@@GOF@@DAMD@OOONCBBNOOOHFGAL@D@@@@GODHH@NCF@@FD@
@@GOFK@L@LD@@@OOFO@HC@CL@@OOF@@BG@@@AFH@AGD@@@@BEHHKEBDCDNGECMFNOO
OFOONDDENNONMLDINM@@A@CJCL@@GOCL@E@LFN@@@AOOOFFGABECBNOOMNFF@LC@BN
OONDFA@@ONBHCMD@OONDDBDBDBD@A@@EM@@EI@@F@H@B@@@@FG@HANAL@B@G@@@OF@
@DANADNH@OM@CEG@@@AL@EAJ@@AEH@B@@@FA@@OODBEBDBKDFNOOO@FFLNECFNOOND
FFJBDNGE@@@F@LABAHANBDBJC@CFCLDBDHDNEDEJF@FFFLGBGHGNHDHJI@IFILJBJH
JNKDKJL@LFLLMBMHMNNDNJO@OFOL@MAJBGCDDADNEKFHGEHBHOILJIKFLCM@MMNJOG
AMCJEGGDIAJNLKNH@F@@CDBNOOO@ECDBDENNONMLDBD@A@CBB@@@FA@@ONMFEALJOO
ODDNGE@@@@@F@@@L@@AB@@AH@@AN@@BD@@BJ@@C@@@DH@@OOOOOOOODN@@OOOOOOOO
OOOOF@@@OOOOGB@@GH@@GN@@HD@@HJ@@KD@@MB@@O@@@@B@A@H@A@N@AAD@AAJ@AOO
OOB@@ABF@ABL@ACB@ADJ@AEL@AFB@AFH@AHF@AJD@AOOOOOOOOOOOOOOOOOOOOOOOO
HA@@@@@H@@@@EJKL@@@@@@BEBDECCDDDDHDADEGDDIDHGJECCBCCFNDADHGDECCDG@
GBDAEHCFFNDAEGFNCDGCDAEHFBCCEMFL@@@@@@AK@@AM@@A@@ADO@AO@@@@AOOOO@@
@@@@@@@@@@@@@A@FDDFIFAFLFOFG@@@@@CBH@@@N@@@@@@@@@@LO@@@H@@NA@@DH@D
@DEAGEFIGD@@@@@@@@@@@O@@@H@@BA@@DH@D@GECG@FEFAFKB@DA@@@@@@@@@@@@FO
@@@H@@HA@@DH@D@GECG@FEFAFKB@DBNF@@@@@@@@@@A@@@EH@@F@@AM@A@@@@@@@@@
@@@@G@@@EH@@L@@AM@A@NDCCECCBDEEIB@FBDIEIB@CGGCDIEIB@FDDIEIB@CHDIEI
B@DEDHFFB@CGFJDIEIB@B@B@B@ECCECEDEEIDCDHB@DAEIB@CDFJDEEIB@FKDEEIB@
CCECCGDEDHFLB@DEDHFMB@DEDHFNB@DOEGFHB@CAG@DIEIB@B@B@B@ECCDCFFKGIEE
EGB@DADHGBB@CEDEDHGCB@B@B@B@GDDIEIB@GIEEEGB@CDGFDIEIB@B@B@CFFDDADH
FBFLGIEEEGB@B@B@CEDEDHFKGJB@B@B@CFGGDAEIB@B@B@CAGJDIEIB@B@B@B@B@B@
ECCFCBFNDAEGB@DAEIB@CGFNDOEGB@FMDAEIB@CHDEEIB@FBDIEIB@CGGCEMDIEIGJ
B@B@B@B@CFGDDEDHFLB@FMDIEIB@CEGGDADHGDB@GIEEEGB@CDEDDHDIDHFNFKB@DA
DHGFB@CBEMFMDIEI@@@@@@@@@@BO@@@H@@DA@@DH@D@FDOG@FEFNB@DA@@@@@@@@@@
HO@@@H@@JA@@DH@D@FDOG@FEFNB@DB@@@@@@@@@@DO@@@H@@FA@@DH@D@FECFAGFFE
B@DA@@@@@@@@@@JO@@@H@@LA@@DH@D@FECFAGFFEB@DB@@@@@@@@@@M@@@ED@@N@@A
NH@HCFDADEB@G@DAGDBODEEIB@DAGDFEBODEDHB@G@DEGDBODIEIB@FBDEBODIDHB@
FHDIGDBODAEIB@GCDIGJFEBODADAB@FCDOGDBODOEGB@FGDO@@@@@@@@@@N@@@ED@@
O@@ANH@HCIDADHB@FCEEGDBOEEEGB@FCDODOBODADOB@FFDOGBBOEEDHB@GDDODOFK
BODAEHB@GDFHDEBODOEIB@FBDOEIBODAEGB@FLDOEEFDBODEEBB@FFEEEBGH@@@@@@
@@@@O@@@ED@A@@@ANH@HCDFBB@DBFIFBBODCDHB@DCDHFEGGBOFDB@DDFEFEDDBOFF
B@DFFIGDBOFGB@DGFADGBOFHB@DHFAGDBOFJB@DJGEGCGDBOFKB@DKFIDCDK@@@@@@
@@@A@@@@ED@AA@@ANH@HCFFLB@GCFEDLFFBOFMB@DMGEDMBOFNB@DNFOBOG@B@E@FO
E@BOGBB@EBGEFNBOGCB@ECFAGEDCFEBOECDHB@ECDHGIBOEJDHB@GFFIECFIFOFN@@
@@@@@@@AA@@@ED@AB@@ANH@HCDGDB@EDFOBOEDDHB@EDDHFIFNBODDDHB@EDDHFEBO
GFB@FODFBOGGB@EGFAFGBOEGDHB@EGDHFEGBFEBOGIB@EIFEGCBOGJB@GCFIEJFE@@
@@@@@@@AB@@@ED@AC@@ANH@HCEDNDGB@GCFIDNDGBOEFBCB@GFFOFLBOECBCB@GCG@
FEFEFDBOBCB@G@FIGDFCFHBODBB@FBFAGCFEBOEDB@GDGBFEFBBOEMBOEKBOELBOBO
@B@@@@@A@@@@@@GFCF@@@@GECF@@@@@@IJ@@@@DNAL@@GJ@@@@@@AL@@IJ@@@DDCDO
DDDE@@@B@@BJDMECE@DK@@@@@@DNECEDEBB@@@@@@@EJDDDLDODG@@@@@@FFDDDIED
DL@@@@@@GB@@OOOOOOB@@@AEMD@@@@DOFH@@@AOOOOB@@@@@AL@@@@DOF@@@@@OOOO
B@@@@@@@@@@@EAFD@@@AOOOOB@@@AFOF@@@@@@@@@@@AOOOO@@@@GALB@@@@@@@@@@
@AOOOO@@@@GANK@@@@@@@@@@@AOOOO@@@@GB@J@@@@@@@@|@@CK@AGO
