Re: Using the Font Editor
Subject: Re: Using the Font Editor
Date: Tue, 18-Dec-84 02:40:48 EST
Article-I.D.: uw-beave.249
Posted: Tue Dec 18 02:40:48 1984
Date-Received: Wed, 19-Dec-84 02:31:48 EST
Lines: 169
THE FONT EDITOR
Documentation
Bernard J. Haan
Institute for Research in Information and Scholarship (IRIS)
Brown University, Box 1946
Providence, RI 02912
bjh%[email protected]
copyright 1984 Brown University (IRIS)
may be copied but not sold without permission
___________________________________________________________________________
Getting Started:
The fonts of the system and those created by the user are stored
in resource files. The system fonts reside in the system resource file
while the user created fonts are in an applications resource file called
Fonts. Resources are used by applications and the system, residing as
separate entities so that they may be changed without recompiling code.
Before entering the Font Editor, it is necessary to have created
the correct type of Fonts file. This file is different from a standard
document file and is created through the Font Mover application. If this
file does not exist, the fonts will be saved to a standard document file
named Fonts, but it will not be useable. This file can be created by going
into the Font Mover and inserting any font from the system into the Fonts
file. This will create the correctly formatted file and should appear in
the directory.
Upon entering the Font Editor, the user will be prompted with a dialog
box. It is not possible to get a font from a resource file from this point.
Therefore, it is necessary to bypass this step in order to get the proper
menu which gives the option of reading a font from a resource file. This
is done by picking the Cancel option.
The next screen will be a blank standard Font Editor screen. Choosing
the Load From Resource... option from the File menu will cause a display
similar to the one above to appear. The name block will be highlighted and
the name of the desired font is to be entered at this point. If the a new
font is to be created, one of the standard fonts should be used as a basis.
If the font size to be worked on is 12 point (the type size being used in
this document), then the OK option is picked and the font is displayed.
If the font to be worked on is another size, then both the Current Size
and the Newsize boxes must be changed to that size. If scaling is being
done, the Current Size should be set to the size of the font that exists
and is being scaled from. The NewSize is the size to be scaled to.
Changing Current Size and NewSize is done by selecting the entire box and
then typing in the size desired.
The Editing Process:
The font editor allows new fonts to be created by the user. This is
done by editing a blown up image of the character. This image is shown in
'fat bits' format which simply represents the character's bits at several
times their actual size. The actual editing process is simply a matter of
turning those bits on and off. A bit will be turned on if a blank space
was picked and will be turned off if a filled-in bit was picked. The
screen of the Font Editor is divided into two windows, one containing the
blown up images and the other containing the actual characters as they
appear when typed. The character currently being edited is demarked by a
box that surrounds it. There are two ways to select a new character to
edit; picking a character from the fat bits window and picking a character
from the character set window.
It is possible to copy a character into a different position, but it
is necessary that the position that the character is being copied into be
empty. This is done by choosing the Delete Character option from the Edit
menu. The character currently being edited will be deleted when this
option is chosen. Copying a character is done by using the Insert
Character option from the Edit menu. Note that when inserting a character
it is necessary to have something to copy into the slot (it would be nice
to just be able to insert without copying if a new character is being
created). If no character is specified to be copied, it will not be
possible to edit the new character position.
NOTE: Do not choose the Undo All Changes option from the File menu.
It will cause a system crash.
Scaling the Fonts:
MacWrite provides some automatic scaling of fonts which means that a
font can be entered at a single size and will be automatically scaled up
and down to fill in for all the sizes available. The problem with this is
that the scaling is done in a rather crude way which does not yield
acceptable results in many cases. Therefore, it is mostly up to the
person creating the font to touch it up in as many of the sizes as s/he
foresees working in. It should also be noted that when a font is being
printed out, it is printed at twice its size. So if a 12-point font is
being printed out, it will actually be printed at 24-point. So if a
24-point font has been created by the user, it will be used, otherwise it
will be an automatically scaled version. The sizes used in MacWrite are 9,
10, 12, 14, 18, and 24-point. If a the font has been created at a certain
point size, that size will be displayed in outline form (12 point) in the
Style menu. If the font is automatically scaled, it appears in standard
type in the menu.
Saving The Font:
Once the font has been completed, there are two ways to save it. It
can be saved into the resource file or into a separate document file.
It is most useful to save the font to the resource file which is done
by choosing the Install Font option from the File menu. This will
automatically save the font and place it in the Fonts resource file. To
install a scaled font, it is necessary to specify the new size in both
the Current Size and the NewSize boxes. Choosing the Save Font In.. option
allows the font to be stored in a document specified by the user. This is
a useful backup tool.
Installing the font into MacWrite:
In order to get the font that has been created into the Font menu in
MacWrite, it is necessary to use the Resource Mover application or the Font
Mover. The Font Mover simply copies fonts into the System Resource. The
fonts are then available for use in any application that supports multiple
fonts.
The Resource Mover allows the user to copy files from one resource to
another. So in this situation there now exist new files in the Fonts
resource which need to be copied into the resource file for MacWrite. This
is done with simple cutting from the Fonts file and pasting into the
MacWrite file. Opening the files is just a matter of picking the file name
and choosing the Open option from the File menu.
If more than one font is to be installed, there is an additional step
that must be taken. When a new font is installed from the Font Editor, it
automatically gets the ID 1536 for the font at slot 0 and 1548 for the
12-point font at slot 12 (installing a new font will automatically also put
the 0 slot font in the file). The problem is that all new fonts are
installed with these ID's which means that the first font installed will
be overwritten. This is solved by changing the ID of the fonts using
Change ID from the Edit menu. Each font requires 128 copies for the
different sizes and styles. These correspond to the ID number of the
font. So if the 0 slot font is installed at 1536, the new font id should
be 128 greater for the 0 slot and 140 greater for the 12-point size. Any
other size should be placed in its appropriate slot relative to the 0 slot.
It is important to place the 0 slot font at a position that is a factor
of 128 greater than 1536. This will result in the proper placement of
the new font and will mean that all of the different sizes and styles
will automatically be available for the new font.
The Font Table
The font table is the place in which the characters of a font are
stored. Each character is assigned a position in the table which
will be the position that must be addressed if the character is to be
generated. The process of addressing a character from the font table is
called key-mapping. A position in the font table is returned when a key
or sequence of keys is pressed. There are 256 slots in the font table of
which about 230 can be accessed. These slots are reached from four
different keyboard combinations. There is the standard keyboard that
generates all of the unshifted characters, the shifted keyboard, a keyboard
with the [Option] key depressed, and a keyboard with the [Option] key and
[A copy of this has been saved as FONTEDIT.DOC -jma ]
