MacProject
MacProject
Subject: MacProject
Date: Mon, 28-Jan-85 06:48:27 EST
Article-I.D.: uw-beave.618
Posted: Mon Jan 28 06:48:27 1985
Date-Received: Tue, 29-Jan-85 06:35:11 EST
Lines: 25
I just received a copy of MacProject as part of the "MacDraw/MacProject
Redemption" program (MacDraw, btw, is not yet ready according to the cover
letter.)
I made a copy of the MacProject disk (it is not copy protected) and
threw away the System and the Finder as I tend to keep a big system disk in
one drive and applications in the other.
Alas, MacProject doesn't work very well without "its" System file. In
particular, the chart size started out at 0 inches by 41 inches, and I found
it impossible to change the 41 inch dimension. I did not notice if anything
else was damaged.
MacProject seems to work fine with the supplied System file. So, I
suspect either (1) there is a new(?) version of the System file and/or (2)
there is some resource tucked away in the MacProject System file that it is
not in my System file.
Has anyone else noticed behavior like this? If so, any thoughts on how
to remedy things? Thanks.
Tom Wood
taw@cmu-ri-fas
