MacWrite to Troff converter for Vax Unix
Path: utzoo!watmath!clyde!cbosgd!ulysses!mhuxr!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: MacWrite to Troff converter for Vax Unix
Date: Sun, 30-Dec-84 18:27:02 EST
Article-I.D.: uw-beave.311
Posted: Sun Dec 30 18:27:02 1984
Date-Received: Mon, 31-Dec-84 03:17:51 EST
Lines: 33
Attached is a version of Mike Caplinger's MacWrite-to-Troff converter
that will run on a Vax (i.e., it has byte swaps inserted at appropriate
points). This version should also work on a Sun (the byteswap is done
with the "ntohs" network routine with should be a nop on a Sun).
In addition to the byte swaps:
- a translation table that maps all the special characters in the
standard Mac Geneva font into appropriate troff characters has
been added.
- lines bracketed by .TS/.TE or .EQ/.EN are treated specially so
tbl tables and eqn equations can be embedded in the MacWrite
document.
- there's a "-p" flag that saves space for pictures that were in the
MacWrite document (to help make a `paste-up' final document).
- a couple of minor bugs were squashed.
A complete shar archive follows. Most files are self explanatory. The
file "write2troff.dl" is a tohex'd MacWrite document describing the
program. The fromhex'd .data version of it can be used as a test case
and/or downloaded to the Mac & inspected with MacWrite (you should
macput it with type "WORD" and owner "MACA").
Happy new year.
- Van ([email protected])
[filed on writetotroff.sh]
