INFO-MAC Digest V5 #80
Path: utzoo!mnetor!seismo!rutgers!ames!ucbcad!ucbvax!SUMEX-AIM.STANFORD.EDU!INFO-MAC
Subject: INFO-MAC Digest V5 #80
Date: Mon, 20-Apr-87 23:25:00 EST
Article-I.D.: ucbvax.8704210555.AA11143
Posted: Mon Apr 20 23:25:00 1987
Date-Received: Wed, 22-Apr-87 00:39:21 EST
Distribution: world
Lines: 660
INFO-MAC Digest Tuesday, 21 Apr 1987 Volume 5 : Issue 80
Re: Control key
Re: juggler
Thanks for the help and synopsis of Page size hasle...
Re: Megamax incompatibility
re: MEGAMAX C compatibility with MAC SE
MacWrite/MacLighting interaction problem?
contouring programs
Source code for FKey fun
Re: bigscreen
Re: digest V5#79 - optical mice
Request for TeX macros
PostScript interpreters
Request info on networking Macs
MacFair II and the Macintosh II
Usenet Mac Digest V3 #31
Usenet Mac Digest V3 #32
Delphi Mac Digest V3 #23
Date: Mon, 20 Apr 87 07:40:55 PST
Subject: Re: Control key
I don't have an SE or II yet, but my understanding is that the
Control key changes the ASCII value and not the keycode (I don't
know about the modifier).
The ADB section of IM Vol. V (at least the developer edition) has some
info about the KCHR and KMAP resources. Between that, a copy of DeRez,
and a System 4.0 disk (to get the resources) you should have enough to
figure out what's going on.
Joel West
Date: Mon, 20 Apr 87 07:43:15 PST
Subject: Re: juggler
Apple has a new team working on Juggler. My understanding is that
not a line of Servant was used in that product, although it does
owe considerably to Switcher for its design.
But then, my information could also be wrong, since I'm not officially
in the know, either...
Joel West
Date: Mon, 20 Apr 87 10:03:11 PST
Subject: Thanks for the help and synopsis of Page size hasle...
This is a letter of thanks... and to say what I have found in making
a page that is 17" long and 11" wide.
The file that was found in the last info-mac for 17"x11" did the
trick, all that had to be done was to copy and paste the resource
using ResEdit (what is the most recent version?). The other Utility
that exists on the MACSERVE@PUCC location is also useable. It
offers a template to follow when changing the page size, but it
appears that alot of dec-hex calculation is needed (So VERY tedious).
One comment was "Find the most recent version of ResEdit". That
sounds easier then it is around here... ANYWAYS, once you have this
most recent version you can access the PREC resource in the
ImageWriter driver file and it will ask you for the information that
you wish to place in the PREC for page size, name,etc.
Thanks to all who helped me change the page size.
(P.S.: Steve Armstrong : Received your letter but can't return via
that path it came by...)
Marc Grondin ,
Date: Mon, 20 Apr 87 07:49:30 PST
Subject: Re: Megamax incompatibility
The problem with Megamax C was a 'bug'. It is, I believe, an incompatibility
across the board with System 4.0. It was reported on comp.sys.mac (see
Usenet Mac Digest V3 #29) for the Macintosh II as well.
Despite what they might want you to believe, it was their fault: they used
a low-memory global not documented as available, about #3 on Apple's
all-time incompatibility list. It's good to see they're reacting
so quickly to correct the mistake.
Apple makes mistakes like anyone else. Sometimes they introduce an
unintentional incompability. Sometimes they introduce one that they
could have warned us about. Sometimes they deliberately introduce
an incompatibility (like restrictions on OS trap calls under A/UX)
because it provides signficant benefits and there's no technical
alternative.
However, it's very easy to blame Apple for many things that are actually
the developer's own fault, and I don't think it's fair to give Apple the
rap because they're a convenient target. If someone blames Apple for an
incompatibility, ask them (or yourself) these questions:
1) Does most other software show this problem?
2) If not, why not? Did the developer make an unreasonable
assumption?
For example, it was always a reasonable assumption that the screen
was rectangular and monochrome. It was never a reasonable assumption
that it was 342x512.
Joel
Date: 20 Apr 87 11:30 PST
Subject: re: MEGAMAX C compatibility with MAC SE
I'm shocked that the Megamax problem affects the SE, I thought it
was only the Mac II. In any case, does this problem affect the applications
produced by MM C or is it just the compiler itself. If it is the applications
that are affected then there is surely a whole crop of software out there
which breaks on the II (and perhaps the SE?) only because it was compiled
with Megamax. I consider this to be a problem.
David Gelphman
Date: Mon, 20 Apr 87 13:14:43 edt
Subject: MacWrite/MacLighting interaction problem?
I'm having a problem with MacWrite 4.5, and I'm wondering if the problem is
shared. I'm using System 3.2, Finder 5.3 (96K Cache), and MacLighting (the
release that came free with the Mac a while back). With 'Lighting set in
interactive mode, as I got past the 6th or so page, I'd get an occasional
extra page break, or a new ruler with VERY, VERY garbled tab settings inserted
IMMEDIATELY before another ruler. The new ruler deletes ok, but if you try to
move a tab, you get a permanent watch.
Query: whose problem is this? I'm inclined to believe 'lighting, since
everything was peachy after I turned it off, but then I was also finished with
the heavy-duty formatting at that point. Any suggestions about where to go
from here (I'm thinking of Word 3.0, which is $90 with the Ed. discount...)
Jonathan
Date: Mon, 20 Apr 87 11:10:31 CST
Subject: contouring programs
I have been working on a contouring program that does a 20 by 20 square
grid of points in a minute or so. It uses integer math which is adequate
for the mac screen resolution. One can scroll around and zoom in on
any area of the plot. Other options: shaded contours and 3-D views
with adjustable viewing angle.
The program needs alot of work still. E.g., there is no data entry yet.
I would be willing to work with someone to improve the program and
distribute it as shareware or some otherware.
Daniel LaLiberte 217-333-7937
University of Illinois, Urbana-Champaign
Department of Computer Science
1304 W Springfield
Urbana, IL 61801
uiucdcs!liberte
Date: Mon, 20 Apr 87 14:43:21 EDT
Subject: Source code for FKey fun
Title: myDialogSansRscr*
Author: Paul Nevai
Version: 1.0
Date: April 16, 1987
It's an FKey! It's a (Lightspeed) Pascal example of a Dialog created in
memory with no resource templates whatsoever! It's instructional! It's fun!
To simplify life, two compressed projects are included: one for programming,
experimenting and debugging, and another for building the FKey source code.
In addition, I also included zFKey ready to be installed into your system,
or activated by a MasterKey type FKey.
Thanks to: Lofty Becker, Steve Brecher, Carlos Weber, Joel West, the guys
on the Net, How to Write Macintosh Software, Inside Macintosh, Lightspeed
Pascal, Macintosh Revealed and MacTutor.
This is a Use&EnjoyNetWare product, that is if you like it you must drop me a
Thank Paul note.
Have Orthogonal Polynomials
Will Travel
Paul Nevai [email protected] ( PREFERRED )
Department of Mathematics [email protected]
The Ohio State University ...!ihnp4!cbatt!osupyr!pgn
231 West Eighteenth Avenue [email protected]
Columbus, OH 43210, U. S. A. 1-614-292-5688
This material is based upon work supported by the National Science
Foundation under Grant No. DMS 84-19525.
archived as
[SUMEX-AIM.Stanford.EDU]FKEY-SANSRSCR-EXAMPLE.HQX
DoD
Date: Mon, 20 Apr 87 12:47:26 EST
Subject: Re: bigscreen
The Bigscreen which was posted does not work in conjunction with the screen
saver that styles itself as Macsbug.
Mark
P.S. At least not on my Mac+.
Date: Sun, 19 Apr 87 20:17:24 pst
Subject: Re: digest V5#79 - optical mice
I agree with Jeffrey Hallett that MOST of the optical mice are inconvenient
to use. All of them (that I've seen) have been Mouse Systems Corp. designs
that require an orientation sensitive mouse pad.
Xerox optical mice, however, are great. They require only some sort of
patterned surface: wood-grain, your jeans, etc., and their "contact point"
is near the fingertip end rather than the palm end -- which I find more
natural for drawing purposes.
Too bad Xerox doesn't sell these on the open market, with an interface
compatible with the ubiquitous MSC optimice or the equally ubiquitous
mechanical Logimice. (Xerox marketing folks, are you listening?)
Mike Khaw
Date: Mon, 20 Apr 87 11:03:03 pst
Subject: Request for TeX macros
I've recently purchased a copy of TeXtures for the Macintosh, and am
generally pleased with it, finding it far superior to Word 3.0 in terms
of its stability and power, although it is of course a much more complex
product.
I'm wondering if anyone out there has a nice set of macros to number figures,
do sections, etc. , or knows where to get source code for same.
Date: Mon, 20 Apr 87 07:44:58 PDT
Subject: PostScript interpreters
Does anyone out there in NetLand know of any public domain PostScript
interpreter source code? We've got this Dicomed, you see, and we'd like to be
able to PostScript to it. It would certainly save me a lot of work if I could
find a PostScript interpreter shell. Then I could just write the back end for
it.
Reply to me directly if convenient.
Steve Lamont
San Diego Supercomputer Center
Date: Thursday 16 Apr 87 5:05 PM CT
Subject: Request info on networking Macs
Hello MacNetland!
We're considering networking our Macs (enhanced 512, plus, and beyond?)
to a laserwriter. The Macs (currently numbering about 10) are used by faculty
members and are located in offices throughout a 3 story building. Any
suggestions / recommendations on a good network? I've used Appletalk but
nothing else. I've heard of a network called "Phonenet" (by Falon Software?)
Are any other networks available which use existing phone wiring? Comments
(good or bad) about any network will be greatly appreciated!
Also, anybody out there use Cricket Draw? Any comments are appreciated.
Please E-Mail responses to me. I'll summarize for the net.
Thanks!
Jay Cook
BITNET: cedjrcpa@UIAMVS
Phone: (319) 335-5587
USMail: 378 Lindquist Center
The University of Iowa
Iowa City, IA 52242
Date: Sun, 19 Apr 87 13:16 EST
Subject: MacFair II and the Macintosh II
Sorry I am late in posting this, but this has been a busy week for me.
Nevertheless, I felt that this information was significant news for the
Macintosh community. This (very extensive) report is by no means inclusive.
Since it is based on my own notes and developer technical materials, I make
no guarantee to the accuracy of the information presented here.
Last Saturday (April 11, 1987) the DUsers, Drexel University's Macintosh
user group, in conjunction with Drexel University, Apple Computer, and the
University of Pennsylvania MUG, held the second MacFair on the campus
of Drexel University in Philadelphia, PA. This event was the most major
Macintosh-related event on the entire east coast this year, and it was one
of the first general public exhibitions to demonstrate the pre-release
Macintosh II in its full glory (more on that later).
Over thirty Macintosh hardware and software developers had booths at
MacFair II:
Apple Computer was showing off the Macintosh II with a SuperMac 19" color
monitor (1024x768 resolution). This machine is much more than you've
heard. You have to see it to believe it. The graphics processing in
eight-bit color mode was competetive with the Digital VAXstation GPX.
You can change the font of an entire 85-page document in Microsoft Word 3.0
from 10-point Geneva to 24-point NewYork in less than 5 seconds!
Unfortunately, the MacII in the Apple booth did not have a sound chip
installed (Apple has recalled it, again).
SuperMac, sporting their DataFrame 40/XP, was also showing their new line
of 19" monochrome and color monitors and display cards for the MacSE
(only monochrome) and Macintosh II. Retail price for their 19" color
monitor (1024x768) for the Macintosh II is $3000, with their "Spectrum"
video card (required) costing $1500. The display quality of the Spectrum
19" color monitor was absolutely fantastic, rivalling the clarity of the
standard Macintosh Plus 9" screen! SuperMac is also offering a video
card (with socket for an optional 68881 math co-processor) for the
Macintosh SE. This card will drive monochrome monitors up to 21" and
1024x1365 resolution. SuperMac was also giving out free updates of
their DataFrame utilities (the new Intializer was version 2.5).
Ashton Tate had a SlideShow demonstration of dBASE Mac, but no actual
product. We were told that the product is too slow, and is being modified.
According to their sales brochures, however, it should be a really nice
product when released (if it's fast enough). Imagine the power of dBASE III
or Omnis3, the intuitive relational capabilities of Reflex, and the layout
capabilities of FileMaker Plus with a consistent, highly visual interface.
AnnArbor Softworks followed the vaporware tradition of Ashton-Tate by
handing out colorful brochures on Full-Write Professional, but showing
no product. This looks like the word processor that Word 3.0 should have
been. It includes an outliner, glossary, 80000 word spelling checker, 40000
word thesaurus, automatic indexing and table of contents, kerning, leading,
gutting, border lines, automatic text wrapping around irregularly shaped
objects, multiple-column on-screen editing, and MUCH, MUCH more. Imagine
search/replace by font, type size, justification, or just plain text! It
even has a built-in graphics editor with a MacDraw-like interface with tools
for: pointer, text, lines (horizontal, vertical, or freehand), rectangles,
rounded rectangles, ovals, and curves. It looks like the graphics editor is
limited to creating screen-sized images, though.
Microsoft said that the next version of Excel (1.04) will support the Apple
Filing Protocol (defined by AppleShare), among other enhancements, and will
be FREE to registered owners, but no release date was mentioned.
Other displays were less monumental. Borland international sold 300
copies of Mac TurboPascal for $20. Letraset is offering a $99 "upgrade"
to PageMaker owners when they send in their manual cover. Of course, no
mention was made of MacPublisher III owners.
In addition to the developer floor, numerous lectures were given by guest
speakers as notable as RonHochsprung (chief hardware engineer for the
Macintosh II), John McEnerey (one of the developers of Lightspeed Pascal),
and Michael Green (author of Zen and the Art of Macintosh), among others.
Unfortunately, I only had enough time to listen to Ron Hochsprung's
presentation:
Much of Mr. Hochsprung's speech centered around the technical implementation
of the Macintosh II hardware and software. This information is covered in a
17-page product preview in the April 1987 issue of BYTE magazine. But
Mr. Hochsprung mentioned several things not covered in the BYTE article:
The Macintosh II was developed over an 18-month period (organized during
Sculley's reorganization) by a team of only 4 (yes 4) hardware engineers
and 150 software engineers. In addition, a team of 90 people tested every
piece of Macintosh software in the Apple library at every major revision
of the machine, and accessing blame to problems in the MacII or programmer
mistakes.
The Macintosh II is truly revolutionary. Software written to take advantage
of the 68881 math coprocessor chip will operate faster than a VAX 11/780
minicomputer with a floating point accelerator and over 40 times faster than
the MacPlus. The SANE library has been rewritten for the 68881, and programs
that use SANE will operate 3 to 4 times faster than the MacPlus.
The power supply is fully international: it automatically configures itself
to the input power (all you have to provide is a plug adapter) from 80 to
270 volts, 42 to 62Hz. Since a receptacle is provided on the back of the
MacII for plugging in a monitor, you have only one power cord and one power
switch.
Apple has removed the power switch from this machine. You turn it on by
pressing a key on the top rear of the keyboard. The only way to turn it off
is to select "Shutdown" from the Finder. This assures that all volumes will
be flushed and dismounted properly before power-off. If all else fails,
you can use the main power switch in the back of the machine.
Apple is aiming for 95% software compatibility when the MacII is finally
released, which may be wishful thinking. However, Apple has done their best
to maximize compatibility with older software. Since the video card is an
option on the Macintosh II, a "fake" VBL interrupt is now generated from the
second versatile interface adapter chip (VIA2) at the standard rate of 60Hz.
This means that software can run on the MacII without a monitor (as would be
the case in a dedicated fileserver). In addition, each NuBus card is capable
of posting an interrupt. For further compatibility, the Macintosh II can
operate in either 32-bit or 24-bit (compatibility) mode. See the BYTE article
for more detail.
Many enhancements are present in the new 256K ROMs: support for 24/32 bit
modes, the 68881 and 68851, NuBus support (config ROM, booting, and slot
interrupts), 6 new VBL queues, AppleDesktopBus, new drivers, and color
QuickDraw.
QuickDraw has been enhanced to support 48-bit color, and is independent of
the output device. Color QuickDraw will automatically adjust itself to
different output devices (pixel densities, color capabilities, screen sizes),
and can split the Macintosh desktop between up to 6 monitors. You can even
split windows between screens of different capabilities. Since QuickDraw
has been rewritten to take advantage of the 68020, it is considerably
faster than the standard (MacPlus) QuickDraw. You can scroll a monochrome
image (ala MacPaint) quickly with absolutely NO screen flicker. It looks as
if you're dragging a piece of paper on the screen.
A color lookup table of 16.7 million colors can be modified by individual
programs (if, for example, more emphasis is needed in certain color ranges).
Apple still has not standardized an interface for building your pallette from
the 16.7 million available colors. Mr. Hochsprung demonstrated one proposed
interface that allowed fundamental colors to be mixed exactly like an artists
pallete: more strokes of a color make it darker, "pulling" streaks of color
from several different color pools generates a color that is a mixture of the
colors, in proportion to the amount you mix. Since this program modifies the
RAM-resident lookup table, all applications run subsequently would use the
pallette you created. If needed, the default pallette can be restored from
the control panel.
In addition, the SCSI port now supports hardware handshaking. This realizes
a twofold performance increase over the MacPlus. In addition, a program
cannot read data that is not on a peripheral (unlike the MacPlus SCSI).
Internal Apple benchmarks place the speed of the new SCSI bus at 1.4MBytes/sec.
Also, the new SCSI Manager has the capability of partitioning physical volumes
into separate, bootable (logical) volumes. Thus, you can partition a hard
disk drive on the MacII into a volume for Unix, and one for Macintosh, with
direct file-transfer capabilities.
Here are some of Mr.Hochsprung's responses to questions from the audience:
concerning differences between the 256K ROM's on the MacII and the MacSE:
Apple has one large master source-code file for the Macintosh operating
system, with conditional assembly directives for the different incarnations
of the Macintosh ROM. Thus, when a specific ROM routine is modified, it
will be modified on the ROM of ALL Macintoshes. The 256K ROM on the MacII
is VERY different from the 256K ROM on the MacSE. The MacII ROM has many
things not in the MacSE ROM: color QuickDraw, NuBus support for example.
The MacSE ROM, on the otherhand, contains more resources normally found in
the system file (such as font collections) than the MacII ROM.
concerning 3.5-inch drives with capacities greater than 800K:
"I can't reveal future products, but the IWM disk controller chip is
socketed."
concerning the graphics capabilities of IBM's PC/System 2 family:
the PC/System 2 graphics are only capable of 4-bit color. The Macintosh II
uses 32-bit internal color representation, rounded to the nearest available
color for output devices less than 32 bits
concerning new versions of Apple system and application software:
a final, stable version of the System and Finder will be released with the
Macintosh II. This software should be used on all newer Macintoshes: 512e,
Plus, SE and II. New versions of MacPaint, MacWrite, and MacDraw will also
be released. (both MacPaint 1.5 and MacWrite 4.5 do not work on the MacII)
concerning multi-tasking:
not available until next year at the earliest. Possibly coincident with the
release of the Macintosh II will be a new version of the Finder, with an
interface similar to Servant and rudimentary background tasking. This
Servant-like Finder will work on ALL newer Macintoshes (512e, Plus, SE, II)
and will not require the 68851 PMU chip (as InfoWorld claimed this week).
concerning Apple's A/UX UNIX:
A/UX is a FULL implementation (TCP/IP networking and all) of Unix system 5.2
with Berkely 4.2 enhancements and direct support for the entire Macintosh
toolbox. One day before Apple's March announcements, one developer took the
entire source code for Unix X-Windows and compiled it on the Macintosh II.
He was demonstrating the working X-Windows the next day at AppleWorld.
To boot Unix from the Macintosh II, you must launch a Macintosh application.
You may not quit to the Macintosh environment, though. You must first shut
off the machine. However, because of A/UX's Macintosh toolbox support, Apple
*may* release an object library that will allow WELL-BEHAVED Macintosh
executable images to be transferred directly to Unix! Unfortunately, barely
2% of existing Macintosh software is "well-behaved" enough to survive this
transfer.
Unfortunately, the Unix shell cannot access the Macintosh toolbox. Thus, a
user must launch a Unix application from the shell, and if it is written for
the toolbox, the program itself will have a Macintosh interface. The Mac
interface is lost when the user returns to the shell environment.
That's my report on Horizons: MacFair II!
Please direct any questions/comments to:
Paul Christensen
CSNET: [email protected]
Date: Mon, 20 Apr 87 08:59 EDT
Subject: Usenet Mac Digest V3 #31
Usenet Mac Digest Sunday, April 19, 1987 Volume 3 : Issue 31
Optimal Cache Size?
Appleshare -- why a MacPlus?
Postscript does work with RSG3.0...
Re: Runlist from Finder
icons
Hard disk survey
Help, I can't print!
Dark Castle on an SE
reducing the video-refresh processor burden
SCSI cable question, please HELP!
Re: UPDATE: MAC SE Mouse Double-Clicking problem
Graphing Programs (2 messages)
Re: SCSI cable question, please HELP!
TML Pascal
Optimal Cache/RamDisk Size?
Disappearing print drivers?
DMCS
Re: 1200 baud modems
YA MacFortran Bug - TRIM(), blanks, and relational exp...
Okidata Laserline w/Mac?
Re: DMCS
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-31.ARC
DoD
Date: Mon, 20 Apr 87 09:00 EDT
Subject: Usenet Mac Digest V3 #32
Usenet Mac Digest Sunday, April 19, 1987 Volume 3 : Issue 32
Servant
Re: Hard Disk Backup blunder
Neat Control Panel bug
Summary: MacFans
Re: Optimal Cache Size? (long)
How to use 'non-include-ed' ROM calls in MSFortran?
Re: DMCS
Can MAC II export to Japan?
Picky chooser
Summary: Master Dir Block Trashings
HELP!! Interchanging Spreadsheet Files ie DIF SYLK or WKS??
Modula-2 on a Mac?
HD Backup directories
Mac SE terminal emulation
RE: STUDIO SESSION ON MAC SE
Re: DF problems
archived as [SUMEX-AIM.Stanford.EDU]USENETV3-32.ARC
DoD
Date: Mon, 20 Apr 87 09:01 EDT
Subject: Delphi Mac Digest V3 #23
Delphi Mac Digest Sunday, April 19, 1987 Volume 3 : Issue 23
Administrivia - Oooops :-)
RE: Bernouli Box (2 messages)
RE: AppleShare
RE: 4th Dimension (1st report) (6 messages)
DF 20 & Human Touch/etc.
Fragmented Disks (2 messages)
Mac Parallel Printing
re: Optical Mouse for the Mac ? (2 messages)
RE: Rolodex and Quickfile
re Optical Mouse for the Mac ?
serial port
Keyboards (2 messages)
Init File (2 messages)
Request for Donations
weird (Finder?) bugs...
Halftone
tmon
Debugging on the Mac II (2 messages)
sound problem (2 messages)
MPW
how can you tell if a font will download
RE: how can you tell if a font will down
IDD/MacDraft (2 messages)
DiskTop 2.0 bug
archived as [SUMEX-AIM.Stanford.EDU]DELPHIV3-23.ARC
DoD
