Path: utzoo!utgpu!water!watmath!clyde!cbosgd!osu-cis!tut!tut.cis.ohio-state.edu!orange@greely
Newsgroups: comp.sys.mac.hypercard
Subject: Re: Hypercard Bug!
Date: Fri, 4-Dec-87 00:42:46 EST
Article-I.D.: tut.2801
Posted: Fri Dec 4 00:42:46 1987
Date-Received: Sun, 6-Dec-87 22:49:30 EST
References:
Sender: [email protected]
Organization: Swashbuckler Associates, Unc.
Lines: 22
Another bug: Run the sample stack PLOTS. Go to the "numbers" field (not
*named* numbers, just where you put them). Type several carriage returns
(enough to scroll the bottom number to the top of the field). Scroll to the
bottom of the field. Delete the extra carriage returns. The scroll button
will move to the top of the field, and you will be unable to see all of the
numbers (or scroll). This seems to be just a display problem, which goes
away if you generate a display update (cover the field with a window/da/menu).
-j
"... 'cause they're Vampire Hookers, ...!cbosgd!osu-cis!tut!orange!greely
and blood is not all they suck!" [email protected]
-- from "Vampire Hookers" (one of these ought to work)
(theme song to "Vampire Hookers")
Disclaimer:
None of the opinions expressed above are, in fact,
opinions. The superficial resemblance to what is commonly
termed an "opinion" is purely coincidental, and the above
message actually consists entirely of line noise.
