Download: http://archive.info-mac.org/app/tech-tr ... osx-12.hqx
Welcome to TechTracker Pro! TechTracker Pro is a new application from
TechTracker that integrates the power of the VersionTracker.com web site
with an exciting new application for tracking your installed software.
With this release, you can now keep all of your Mac OS X software up to
date. Running as a Carbon app, TechTracker Pro automatically creates a list
of your installed software, and proactively notifies you when software on
your list is updated. Using TechTracker Pro, you can then connect to
VersionTracker's Web site and find out more about updates you need or
download updates directly to your hard drive.
TechTracker Pro for OS X will track updates for Carbon/Cocoa appliations, as
well as for all of your Classic applications, control panels, and
extensions.
TechTracker Pro is not installed as a login item. You will need to set
TechTracker Pro to launch at system startup manually. To do this:
Open the System Preferences Application
Click on the Login icon
Click the add button and add TechTracker Pro to your login items
Requires: Mac OS X 10.0 or higher
