How do u add more than 1 email inbox to the mail app?
slim44
Post by slim44 »
It states that u can get all your mail to 1 place yet I can't add another email address? If any1 can help it would be appreciated.
Thanks Mike
Re: How do u add more than 1 email inbox to the mail app?
Settings (the app) -> Accounts -> Add Account...
slim44
Post by slim44 »
Okay thanks. Also the new multitasking toolbar doesn't keep the app open it's just a shortcut for previous used apps. Is there a way to make sure the app stays open rather than just becoming a shortcut?
Thanks mike
slim44 wrote:Okay thanks. Also the new multitasking toolbar doesn't keep the app open it's just a shortcut for previous used apps. Is there a way to make sure the app stays open rather than just becoming a shortcut?
Thanks mike
That is indeed the running app launcher, similar to Mac OS X's Dock. The problem you may be experiencing is apps that aren't yet updated to take advantage of the multitasking system. You can use iForum as an example.
On iPhone OS 3.x and first and second generation iPhones running iOS 4 that cannot do multitasking, switching from iForum to something else and then back again will bring you to a blank globe screen and an activity indicator as iForum reloads the last location you were at. However in iOS 4 and using iForum 1.0.6+, you are instantly brought back to the last state iForum was in, including any typed text.
Multitasking in iOS 4 involves allowing background applications to perform a number of tasks in a limited state, as opposed to literally running apps in the background to the same fullness as a foreground app.
http://www.apple.com/iphone/features/multitasking.html
