Installers!.sit.hqx
Installers!.sit.hqx
Download: http://archive.info-mac.org/dev/installers.hqx
This upload is a set of two drag-and-drop AppleScript applications I have
created. One is for installing a new control panel; the other installs a
new extension. Just leave them on your desktop; whenever you want to
install a new extension on your Mac, drag it to 'Install Extension'. To
install any new Control Panel, drag it to 'Install Control Panel.' Both
will automatically move (or copy) the file to the appropriate folder, then
automatically restart the computer with the new extension or control panel
installed!
These installers together are $5 US shareware. For an additional $15,
software developers can redistribute either or both of them with their
own extensions or control panels. The installers may be included in the
Info-Mac CD-ROM.
