Edit Comment CW 1.5
Edit Comment CW 1.5
Download: http://archive.info-mac.org/dev/cw/edit ... emo-cw.hqx
Announcing Edit Comment for Code Warrior:
email: [email protected]
Do you use source control, such as Projector, SourceSafe, Source Manager,
or SourceServer? If so, do you use Code Warrior as your editor? If you
answered yes to both, you will definitely want this utility, so read on:
(An equivalent version of this program is available for Think environments)
What it does:
This add-on to the Think or Code Warrior environments adds an "Edit
Comment..." item to the Edit menu. When you choose it, it will present an
editing window which shows the revision comment of the front window's file
(and other source control information). Of course, the file must be under
source control (Projector , SourceServer, or SourceSafe). These programs
accomplish their source control by attaching a resource of type 'ckid' to
each file they control. The information in the 'ckid' resource includes the
current revision number and a comment about the changes in that revision.
This is what Edit Comment edits. It extracts the comment text from the
'ckid' of the file you're currently editing and puts up an editing window
that shows the current revision and displays the comment text in an
editable field.
(This demo version doesn't save changes, but is otherwise fully functional)
Having Edit Comment makes it possible (and easy) to create your comments
about the changes you make to a file AS YOU'RE MAKING THEM, without
switching to another app. And these comments go right into the 'ckid',
meaning the file is ready to check in, so you don't have to enter any
comment during checkin. The result: accurate comments, no pre-check-in
diffing to recall what you did to the file, and no comment entering needed
at check in time.
Besides the main advantages above, another very useful thing about Edit
Comment is just that you can see, at any time, which project a file lives
in, and what revision it is. This is really helpful if you want to then
query the database to look at previous revisions.
And yet another advantage: Edit Comment can also change a "mod-read-only"
file back to "Read-Only" (something no one else let's you do). How many
times have you made a file "mod read only" only to later change your mind
about changing the file...too late, from this point on, the source control
system will demand you either check it in or trash it (it won't write over
it). Edit Comment to the rescue. All you have to do is make it
"Read-Only" again, by choosing this in your host environment's Edit Menu
(courtesy of Edit Comment).
Like I said, I think you'll really find Edit Comment essential. But you
try it yourself and see what you think. The price is $25. When you're
ready to order, just send me an email and tell me the check's in the mail
(and put the check in the mail!), and I'll send you a registered version
immediately via email.
P.S. For the coolest (and possibly the ONLY) Projector/SourceServer and
SourceSafe front end GUI, check out the demo of "Source Manager" also
available here on AOL. It is only $25, and is a royal pleasure to use,
being feature rich, colorful, and intuitive. No other product on the
market makes using source control for the Mac so easy and even fun.
Larry Gerndt
