Weight OK? 1.2
Weight OK? 1.2
Download: http://archive.info-mac.org/app/weight-ok-12.hqx
Weight OK? 1.2
What it is: Tool to check your weight and comment on it.
Author: Ton Brand
Company: Ton's Software
License: Freeware
Computer: any Mac
Mac OS: 7.0 or later plus HyperCard Player
Abstract:
Weight OK? is a freeware HyperCard color stack that checks your weight and
comments on it. Enter your weight and height to have your Body Mass Index
calculated. Your Ideal Weight within its limits is also given. If your
weight exceeds those limits, you will get good advice. The program works
with both metric and non-metric input.
