Weight Tracker 1.1.0
Download: http://archive.info-mac.org/app/weight-tracker-11.hqx
Weight Tracker is a simple program which helps you track your weight losses
or gains. It allows you to graph any measurement (weight, waist, hips, etc)
you desire, and graphs them. It also keeps track of your rate of loss or
gain, and evaluates your time to goal based on that rate. The more
information entered, the more accurate the program becomes.
Requires: Color Mac
Shareware: $10
Chris Smolinski
Black Cat Systems
