Problem with a Flashplayer on Lion
reuven
Post by reuven »
Hi, not long ago upgraded my Mac and I've got a Lion with it. Soon after realized that my Flashplayer and funtions does not work as before. Example: cannot do multiple flash photo upload and cannot take picture with webcam. I've tried to enable but I simply just can't click to it.
I've called a support team at Apple care and they couldn't help at all, they just instructed same as I've done before, uninstalled and installed again but nothing.
I've tried to remove all of the Adobe apps and reinstall but helped nothing!
Anyone could help me please with this issue?
Thanks a lot.
Re: Problem with a Flashplayer on Lion
Check if this problem is only with your user account/settings. Create a temporary new user account in System Preferences -> Users & Groups, log out and login to that account and see if Flash player works on it or not. If it does, we know there is a problem isolated to your user account. If not, we know it's a global problem.
reuven
Post by reuven »
Turboladdade wrote:Check if this problem is only with your user account/settings. Create a temporary new user account in System Preferences -> Users & Groups, log out and login to that account and see if Flash player works on it or not. If it does, we know there is a problem isolated to your user account. If not, we know it's a global problem.
I've tried it but doesn't work. All the time it is redirect me to the flaw downloader site. Not sure what could be the a next step.
reuven
Post by reuven »
The new update has arrived and i was hoping my problem gonna be solved but notting. Never mind. I'm working on it.
