SemiModal Windows Pack
External modules for 4D.
Download: http://archive.info-mac.org/dev/db/a4d/ ... ws-ext.hqx
To: [email protected]
X-VMS-To: IN%"[email protected]"
SemiModal
SemiModal is a task and package that allows semi modal windows in 4D.
The meaning of this is when you bring up a window in 4D mouse downs
will only affect the front window, the menu bar and the system window.
System window being other apps and all.
All you have to do is install it with the external mover into any
database you wish to use it in and go. It runs in the background with
no additional calls needed.
I use up as little CPU time as possible so it shouldn't be a problem
to use. If you experience any time problems let me know on
compuserve.
