hypercard
ray
hypercard
Post by ray » April 2nd, 2015, 2:55 pm
Hi,
HyperCard is just about the best piece of software written. Been wanting to do something with it for years. I would like to make a 3D squad leader in HyperCard. I did a small section of a board in a cad program and the pict of it looks good but I just cant seem to get all of the hexes to align. I tried this hexing in the amazon or google cad program. Cant remember the name of it off hand. Not successful there either.
So if there is someone who can help me get the 3D background into HyperCard and dialog me through some of the intricacies would appreciate it.
Thanks RAy.
Re: hypercard
Post by Turboladdade » April 2nd, 2015, 8:24 pm
I don't think that would be a worthwhile thing to do in HyperCard. You would probably be way better off doing it in a Classic version of RealBasic IMHO. Those are readily available on old MacWorld and MacAddic magazine CDs.
ray
Re: hypercard
Post by ray » April 8th, 2015, 2:10 pm
Hi,
I have RealBasic but haven't done anything with it. HyperCard with the scripting for each card avoids lots of extra coding. So any hypercarders like to give me a hand would appreciate it.
RAy.
seppe
Re: hypercard
Post by seppe » May 8th, 2015, 6:34 pm
Hi Ray,
I programmed Hyperscripts for more then 10 years, and wrote externals for PPC.
Can you describe what you want the script to do?
Seppe
Arkas
Re: hypercard
Post by Arkas » March 1st, 2017, 6:00 pm
You really should try SuperCard!!
So similar to hypercard with much more options!
