Hi,
I am producing a 4 screen video installation as part of my final year college project and just wondering whether ArraySync would work for what I'm trying to do. I need to be able to play 4 separate videos on 4 iMacs and for them all to play in sync.
Would it be possible to get a demo version or something to try out, as the project is on a very tight budget.
Any help would be greatly appreciated.
Thanks
James
Video Installation
jamesmcgee44
- 2 MB
Re: Video Installation
Hello,
Yes ArraySync is designed to do exactly what you describe, and yes there is a demo version available! Visit the ArraySync homepage to find the 10-day trial download (this is not possible with Mac App Store version).
jamesmcgee44
- 2 MB
That's great. So to use ArraySync do I have to set up a local network for the 4 MacBooks I'm using or how does it work?Turboladdade wrote:Hello,
If so, it's something I am not familiar in at all. Is there any guidance you could provide in creating a network?
There is a basic setup guide located here and if you have additional questions I'll be happy to answer them on this website or via email to [email protected]
