iCloud and My Docs
iCloud and My Docs
Macbook Pro, OS 10.11.6. When I click system prefs < iCloud < iCloud Drive < options, there is no Desktop & Documents folder option or check box. How do I get it to display as an option? The other expected options do display.
Re: iCloud and My Docs
This was a feature introduced with macOS 10.12 Sierra. If your MacBook is compatible, upgrade it for free from the Mac App Store.
Thanks, didn't appreciate it was only available in Sierra. Laptop is only two years old so upgrade is viable.
- kriegvision
- 32 MB
If it's not something you need this instant, it might be worth holding off on as the High Sierra update will be available in the fall sometime.
I only just found that out too. Time for an upgrade!Altoon wrote:Thanks, didn't appreciate it was only available in Sierra. Laptop is only two years old so upgrade is viable.
