drag and drop C++
drag and drop C++
Download: http://archive.info-mac.org/dev/lib/dra ... op-cpp.hqx
Have you ever wished the barrier to entry to programming on the mac was not so
high? Did you ever sit down and hack for hours just to get a simple utility such
as a file filter going on the mac ? If so, drag and drop C++ is for you.
The basic idea is that files you drag and drop onto your application are
immediately available as files which you can use standard C and C++ functions to
operate on.
The clever bit is that the C/C++ compiler itself is also a drag-and-drop file
filter, so to generate your new application, you just drop the source code on the
'gcc' application !
Be sure to read the file INSTALLATION and the file COPYING (especially the
section NO WARRANTY) before using this program.
