EasyDialogLists.sit.hqx - Makes dialog lists easy
Download: http://archive.info-mac.org/dev/lib/eas ... -lists.hqx
Totally Freeware-
Here's a little demo library and source code to get your dialog lists up
and running in about two minutes. We use it at AtoZnet.com for quick
turn around where fancier Dialog Lists aren't called for, and now you
can too!
There are only three functions for you to call in the whole library, but
that's everything you need to do fast, working, and attractive dialog lists.
The source code is fully commented, so I guarantee that even the most
novice programmer will benefit from it's use.
Enjoy.
