Bootcamp alternative?
ssgalileo
4 MB
Post by ssgalileo » April 3rd, 2019, 4:26 am
Bootcamp keeps popping up errors when trying to create a Windows 10 installation disk. What's the good alternative on Mojave?
Re: Bootcamp alternative?
Post by Turboladdade » April 3rd, 2019, 8:48 am
There really isn't any alternative to Boot Camp, which directly boots your Mac into Winodws. What are the errors you receive?
If you prefer, you can use virtualization solutions like Parallels or VirtualBox, however they're very slow. You're better off just picking up an inexpensive PC IMHO.
ssgalileo
4 MB
Post by ssgalileo » April 7th, 2019, 2:45 am
Turboladdade wrote:There really isn't any alternative to Boot Camp, which directly boots your Mac into Winodws. What are the errors you receive?
The startup disk does not have enough space to be partitioned.
Post by Turboladdade » April 8th, 2019, 11:03 am
And how much free space is currently available on your Mac's startup disk? This is probably a sign that your storage is too full to be efficiently used with Boot Camp, which must have its own partition for Windows and of course, install a completely copy of Windows 10 onto it.
ssgalileo
4 MB
Post by ssgalileo » April 9th, 2019, 4:37 am
Turboladdade wrote:And how much free space is currently available on your Mac's startup disk? This is probably a sign that your storage is too full to be efficiently used with Boot Camp, which must have its own partition for Windows and of course, install a completely copy of Windows 10 onto it.
The problem is that I don't install Windows on my Mac. instead, it will be installed on another PC so there is nothing to do with Startup disk
Post by Turboladdade » April 9th, 2019, 4:58 am
Boot Camp requires a Windows partition on your Mac to work.
Waiiery
Post by Waiiery » April 11th, 2019, 2:09 am
I do know Bootcamp is able to do,but it is not the only way to creating a Windows 10 installtion disk.Making a Windows 10 installtion disk is not difficult to do,why not try something else?
Post by Turboladdade » April 11th, 2019, 7:44 am
If you're trying to create Windows installation media for another PC, you can download a Windows 10 ISO directly from Microsoft and simply burn it using your DVD burner (if you have one).
ssgalileo
4 MB
Post by ssgalileo » April 19th, 2019, 1:07 am
No, I am creating bootable USB for another PC.
I do know Bootcamp is able to do, but it is not the only way to creating a Windows 10 installation disk.Making a Windows 10 installation disk is not difficult to do, why not try something else?
So you recommendation is?
Already downloaded the Windows 10 ISO and used Bootcamp to make it bootable but failed.
Post by Turboladdade » April 19th, 2019, 2:12 am
I wouldn’t say it failed — it’s working exactly as expected. BootCamp’s sole purpose is to partition your startup disk and install Windows natively on your Mac with proprietary Apple drivers to support Apple hardware.
BootCamp will not be able to do what you want, however you can maybe try and use the free VirtualBox software to create a Windows virtual machine, from which you can create your USB stick. This still requires your Mac have enough space to install Windows, but possibly less than what BootCamp requires.
