Download: http://archive.info-mac.org/dev/lib/png-10-c.hqx
This is the source to the following applications and is the result of my
port of PNG libraries and PNG utilities, the original source is from
Portable Network Graphics Group.
It contains Codewarrier DR8 project file and libraries for reading and
writing PNG files.
Comments can be directed to:
Mark Fleming ,
For updates and other program: http://ccsamcinfo.ccs.queensu.ca/Mark/
Compiled 68K applications:
pngCheck - test to see if file is a correct PNG file.
pngtest - test png library, requires "pngtest.png" file in the same folder
as this application.
Compiled 68K & PPC applications:
PNG to TIFF converter
Description: convert PNG file to TIFF files.
gif2png:
Description: convert GIF files to PNG files. Supports Drag and Drop and
AppleScript via Drop Shell V2.0.
