Download: http://archive.info-mac.org/dev/lib/spe ... 960312.hqx
SpectFFT is a library for performing integer FFT. It is made from
SoundVision FFT, and is almost identical to SoundVision FFT. It is real
fast (take a look at SoundVision and you see its speed), and real easy to
use.
SpectFFT is intended to be used with Metrowerks CodeWarrior.
A 68K sample project is included.
SHAREWARE. License fee depends on your usage.
Masafumi Ueda
