OSA Menu 1.2.2
OSA Menu 1.2.2
Download: http://archive.info-mac.org/dev/osa/osa-menu-122.hqx
"OSA Menu is an iconic system menu (like the Help menu) that appears on the
right side of the menu bar. Its menu items are scripts: choose an item from
the menu and the script will run. Some commands are always available, and
some are only available within particular applications. Generally the
target of the script is the active application, and scripts that operate on
the user selection are particularly useful. Scripts in the OSA Menu act
like extensions to the command set of the application." - Leonard
Rosenthol, author
New in this version: further support for OS 9, bug fixes. The author
recommends that all users, on OS 9 or earlier, update to this version.
Free. Further information available at
http://www.lazerware.com/software.html
John Rethorst
